PID extrudeur impossible
tontonchow
Suite à mon changement de bloc chauffe et de sonde de température, j'ai donc voulu refaire le pid de mon extrudeur mais la problème, dès que j'envoie un M303 j'ai directement une erreur
Send: M303 E0 S230 C8
Recv: PID Autotune start
Recv:  T:38.19 /0.00 B:46.38 /0.00 @:125 B@:0
Recv: Error:Heating failed, system stopped! Heater_ID: 0
Recv: Error:Printer halted. kill() called!
WARNING! Received an error from the printer's firmware, ignoring that as configured but you might want to investigate what happened here! Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!
No response from printer after 4 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Operational" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
Connection closed, closing down monitor
Pourtant aucun souci pour changer la température manuellement, avez-vous une idée de ce qui pourrais provoquer ça ? je suis sur un marlin 1.1.8
