Promblème avec mon imprimante 3d Prusa i3 Rework 1.5 de eMotion Tech
Bonjour a tous,
Cela fait plusieurs années que mon père a une imprimante 3d Prusa i3 Rework 1.5 mais il n'as jamais eu le courrage de finir de l'assemblé.
Je l'ai donc assemblé il y a 3 jours et la lors de l’installation je n'avais plus le disque d’installation (Arduino,marlin et Repetier-Host). J'ai donc installé tous ses logiciels via internet mais la il se trouve que j'ai un problème lors du transfert de Marlin vers la Carte arduino :
Arduino : 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Carte : "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\SdBaseFile.cpp:24:0:
SdBaseFile.h:38:8: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
In file included from sketch\Marlin.h:10:0,
                 from sketch\SdBaseFile.cpp:21:
c:\program files\windowsapps\arduinollc.arduinoide_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
 __extension__ typedef long long fpos_t;
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::getpos(fpos_t*)':
SdBaseFile.cpp:298:8: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->position = curPosition_;
SdBaseFile.cpp:299:8: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->cluster = curCluster_;
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::setpos(fpos_t*)':
SdBaseFile.cpp:1496:23: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curPosition_ = pos->position;
SdBaseFile.cpp:1497:22: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curCluster_ = pos->cluster;
In file included from sketch\SdFile.h:27:0,
                 from sketch\SdFile.cpp:23:
 struct fpos_t {
                 from sketch\SdFile.cpp:20:
sketch\Marlin_main.cpp:2108:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
         LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF".");
                 from sketch\cardreader.h:8,
                 from sketch\cardreader.cpp:2:
 struct fpos_t {
                 from sketch\cardreader.cpp:1:
                 from sketch\Marlin_main.cpp:44:
 struct fpos_t {
                 from sketch\Marlin_main.cpp:30:
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Voilà je ne sais pas a quoi cela correspond, ni quoi faire, si j'ai mal fixé quelque chose ou si c'est juste un des logiciels qui est trop récent. En tous cas dans le logiciel Repetier-Host aucun paramètre de l’imprimante ne s'affiche, que faire ?
Lien vers le commentaire
bonjour
pour ma part, j'ai réussi a injecter le Marlin 1.x dans mon modèle identique (ou presque ?) en utilisant le soft Arduino IDE 1.08.
Je n'ai pas réussi à compiler en utilisant un soft Arduino récent. Ni d'ailleurs a utliser une version Marlin v2. (objet de mon dernier post justement)
Bien, merci pour ton message j'ai réussi a transférer le Marlin 1.x en utilisant le soft 1.0.6. 😄
Sauf que la c'est Repeter-Host qui me dit toujours :
No signal detected - forcing start
puis
Comunication timout - reset and send buffer block
Je suis toujours bloquer mais peut être que la V2.1.6 de ce logiciel est trop récente elle aussi ?
Hello
Ne gaspillez pas votre énergie à utiliser Arduino IDE
Surtout que maintenant Marlin 2 ne passe plu dessus, essayez Visual Studio, ça va tout seul
@Quentinox007: Ta machine devrait être détectée en tant que port COM: . Vu que tu as téléverser Marlin sans soucis, cela doit fonctionner de ce côté la.
Dans Repetier Host tu dois régler deux choses : le port et la vitesse (baudrate). Le baudrate est indiqué dans Marlin au début du listing. Pour le port, regardes dans arduino ou dans gestionnaire de périphériques. Si l'un des deux est mal réglé, ça ne fonctionne pas 🙂
Il y a 3 heures, Jmguilbert@carbodebit.net a dit :
il y a une phase assez importante d'apprentissage à son usage.
La courbe d'apprentissage de VSC n'est pas plus pentue que celle d'Arduino.
Une fois platformio installé en greffon de VSC (mieux encore est d'installer AutoBuildMarlin (qui se charge d’installer platformio si ce n'était pas encore fait)), le principe reste le même éditer deux fichiers : configuration.h et configuration_adv.h (et un troisième si ABM n'est pas installé : platformio.ini). De nombreux tutoriels existent (y compris en français) sous forme textuelles ou de vidéos.
