  1. Taille originale du fichier 235180
  2. Type MIME image/jpeg
  3. Hauteur de l'image 1089
  4. Largeur de l'image 1452
  5. Couleur VRAIE
  6. Byte Order Motorola TRUE
  7. Aperture f/1.7
  8. Camera Make samsung
  9. Camera Model SM-G930F
  10. Orientation The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
  11. X-Resolution 72/1
  12. Y-Resolution 72/1
  13. Resolution Unit 2
  14. Software G930FXXU1APEQ
  15. Last Modified 2016:09:02 20:32:27
  16. YCbCr Positioning centered
  17. Exposure Time 1/50
  18. F Number 17/10
  19. Exposure Program Normal program
  20. ISO Speed Ratings 125
  21. Version EXIF 0220
  22. Date Taken 2016:09:02 20:32:27
  23. Date Digitized 2016:09:02 20:32:27
  24. Shutter Speed 564/100
  25. Aperture Value 153/100
  26. Brightness Value 202/100
  27. Exposure Bias Value 0/10
  28. Max Aperture Value 153/100
  29. Metering Mode Pattern
  30. Flash Flash did not fire
  31. Focal Length 420/100
  32. EXIF.SubSecTime 0282
  33. Flashpix Version Flashpix Format Version 1.0
  34. Color Space sRGB
  35. Image Width 4032
  36. Image Length 3024
  37. Interoperability Offset 704
  38. Exposure Mode Auto exposure
  39. White Balance Auto white balance
  40. Focal Length (35mm equiv) 26
  41. Scene Capture Type Standard
  42. EXIF.ImageUniqueID 714f10379846767d0000000000000000
  43. GPS.GPSLatitudeRef N
  44. GPS.GPSLongitudeRef E
  45. GPS.GPSAltitude 0/1
  46. GPS.GPSDateStamp 2016:09:02
  47. Inter-operability Index R98
  48. Inter-operability Version 0100
