  1. Taille originale du fichier 510990
  2. Type MIME image/jpeg
  3. Hauteur de l'image 3120
  4. Largeur de l'image 4160
  5. Couleur VRAIE
  6. Byte Order Motorola TRUE
  7. IFD0.ImageWidth 4160
  8. IFD0.ImageLength 3120
  9. IFD0.PhotometricInterpretation 2
  10. Image Description sdr
  11. Camera Make HUAWEI
  12. Camera Model GEM-702L
  13. Orientation The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
  14. IFD0.SamplesPerPixel 3
  15. X-Resolution 720000/10000
  16. Y-Resolution 720000/10000
  17. Resolution Unit 2
  18. Software Adobe Photoshop CS6 (Windows)
  19. Last Modified 2016:05:21 19:29:06
  20. YCbCr Positioning centered
  21. IFD0.DeviceSettingDescription ipp�
  22. Exposure Time 29988/1000000
  23. Exposure Program Normal program
  24. ISO Speed Ratings 80
  25. Version EXIF 0210
  26. Date Taken 2016:05:21 19:16:27
  27. Date Digitized 2016:05:21 19:16:27
  28. Shutter Speed 199315/10000
  29. Brightness Value 0/1
  30. Exposure Bias Value 0/10
  31. Metering Mode Spot
  32. Light Source Daylight
  33. Flash 24
  34. Focal Length 2380/1000
  35. EXIF.SubSecTime 929045
  36. Flashpix Version Flashpix Format Version 1.0
  37. Color Space sRGB
  38. Image Width 4160
  39. Image Length 3120
  40. Interoperability Offset 844
  41. Sensing Method One-chip color area sensor
  42. Exposure Mode Auto exposure
  43. White Balance Auto white balance
  44. Digital Zoom Ratio 100/100
  45. Scene Capture Type Standard
  46. Gain Control None
  47. Contrast Normal
  48. Saturation Normal
  49. Sharpness Normal
  50. Distance Range 0
  51. Inter-operability Index R98
  52. Inter-operability Version 0100
