  1. Taille originale du fichier 363834
  2. Type MIME image/jpeg
  3. Hauteur de l'image 1980
  4. Largeur de l'image 926
  5. Couleur VRAIE
  6. Byte Order Motorola TRUE
  7. Aperture f/2.0
  8. COMPUTED.Thumbnail.Height 512
  9. COMPUTED.Thumbnail.Width 288
  10. Camera Model PLK-L01
  11. Orientation The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
  12. Image Description dav
  13. IFD0.DeviceSettingDescription ipp�
  14. Last Modified 2017:02:27 08:24:43
  15. IFD0.ImageWidth 926
  16. YCbCr Positioning centered
  17. Resolution Unit 2
  18. IFD0.ImageLength 1980
  19. Y-Resolution 72/1
  20. Software PLK-L01C432B380
  21. X-Resolution 72/1
  22. Camera Make HUAWEI
  23. THUMBNAIL.ImageWidth 288
  24. THUMBNAIL.ImageLength 512
  25. Color Space sRGB
  26. Date Digitized 2017:02:27 08:17:34
  27. F Number 200/100
  28. Distance Range 0
  29. Focal Length 4620/1000
  30. Aperture Value 200/100
  31. Light Source Daylight
  32. Exposure Mode Auto exposure
  33. Image Length 5152
  34. Focal Length (35mm equiv) 27
  35. Scene Capture Type Standard
  36. Digital Zoom Ratio 100/100
  37. Saturation Normal
  38. EXIF.DocumentName
  39. Exposure Program Normal program
  40. Sharpness Normal
  41. White Balance Auto white balance
  42. Image Width 2896
  43. EXIF.SubSecTime 290697
  44. Shutter Speed 199315/10000
  45. Metering Mode Average
  46. Date Taken 2017:02:27 08:17:34
  47. Gain Control None
  48. Flash 25
  49. Version EXIF 0210
  50. Contrast Normal
  51. Interoperability Offset 895
  52. Exposure Bias Value 0/10
  53. Brightness Value 0/1
  54. ISO Speed Ratings 64
  55. Sensing Method One-chip color area sensor
  56. Flashpix Version Flashpix Format Version 1.0
  57. Exposure Time 59993/1000000
  58. Inter-operability Index R98
  59. Inter-operability Version 0100
