manux88100
Récompenses de manux88100
  1. Je te remercie je teste tout ceci et je te retiens au courant mille merci pour ton aide je viens de testé voici les messages d'erreur qui me sont affiché : * Executing task: C:\Users\manu\.platformio\penv\Scripts\platformio.exe run --target upload Warning! Ignore unknown configuration option `monitor_flags` in section [env] Warning! `src_filter` configuration option in section [env:DUE] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:STM32F4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:STM32F7] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_build_flags` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_flags` instead Warning! `src_filter` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Warning! `src_filter` configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use `build_src_filter` instead Processing LPC1768 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1768; framework: arduino) ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option *** missing SConscript file 'buildroot\\share\\PlatformIO\\scripts\\common-dependencies.py' File "C:\Users\manu\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 167, in <module> ======================================================================================== [FAILED] Took 1.68 seconds ======================================================================================== Environment Status Duration ------------- -------- ------------ LPC1768 FAILED 00:00:01.680 ================================================================================== 1 failed, 0 succeeded in 00:00:01.680 ================================================================================== * The terminal process "C:\Users\manu\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
  2. Bonjour a tous , voila j'ai un souci j'essaie depuis plus de 15j a complié marlin mais sans grand résultat , je possède une U20, avec une ancienne SKR 1.3 mais celle-ci a griller , pour la peine j'ai voulu retrouver ce modèle mais j'ai eu seulement les 1.4 donc j'ai du refaire marlin pour celle ci elle est monter avec tmc 2208 et un écran TFT35 _E3 si quelqu'un pourrais m'aider dans mon périples . Configuration.h Configuration_adv.h
