nico.pro
Récompenses de nico.pro
  1. bonjour à tous , désolé d'avoir mis le problème avant de me présenter , je savais pas comment m'y prendre comme vous l'aurez compris, j'essais de passer à marlin sur mon ANET A8 pour utiliser un bl touch. mais j'obtiens le rapport d'erreurs si dessus à la compilation dans arduino. si quelqu'un à une idée ou un début de piste ...
  2. Arduino : 1.8.10 (Windows 10), Carte : "Anet V1.0" In file included from sketch\Marlin_main.cpp:320:0: sketch\endstop_interrupts.h: In function 'void setup_endstop_interrupts()': endstop_interrupts.h:128:7: error: non-constant condition for static assertion static_assert(digitalPinToPCICR(X_MIN_PIN) != NULL, "X_MIN_PIN is not interrupt-capable"); ^~~~~~~~~~~~~ In file included from C:\Users\Nico\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.1\cores\arduino/Arduino.h:257:0, from sketch\MarlinConfig.h:37, from sketch\Marlin.h:36, from sketch\Marlin_main.cpp:244: D:\programm files\Arduino\hardware\anet\avr\variants\sanguino/pins_arduino.h:117:66: error: reinterpret_cast from integer to pointer #define digitalPinToPCICR(p) ( (((p) >= 0) && ((p) <= 31)) ? (&PCICR) : ((uint8_t *)0) ) ~^~~~~~~ sketch\endstop_interrupts.h:128:21: note: in expansion of macro 'digitalPinToPCICR' static_assert(digitalPinToPCICR(X_MIN_PIN) != NULL, "X_MIN_PIN is not interrupt-capable"); ^~~~~~~~~~~~~~~~~ In file included from sketch\Marlin_main.cpp:320:0: endstop_interrupts.h:148:7: error: non-constant condition for static assertion static_assert(digitalPinToPCICR(Y_MIN_PIN) != NULL, "Y_MIN_PIN is not interrupt-capable"); ^~~~~~~~~~~~~ In file included from C:\Users\Nico\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.1\cores\arduino/Arduino.h:257:0, from sketch\MarlinConfig.h:37, from sketch\Marlin.h:36, from sketch\Marlin_main.cpp:244: D:\programm files\Arduino\hardware\anet\avr\variants\sanguino/pins_arduino.h:117:66: error: reinterpret_cast from integer to pointer #define digitalPinToPCICR(p) ( (((p) >= 0) && ((p) <= 31)) ? (&PCICR) : ((uint8_t *)0) ) ~^~~~~~~ sketch\endstop_interrupts.h:148:21: note: in expansion of macro 'digitalPinToPCICR' static_assert(digitalPinToPCICR(Y_MIN_PIN) != NULL, "Y_MIN_PIN is not interrupt-capable"); ^~~~~~~~~~~~~~~~~ In file included from sketch\Marlin_main.cpp:320:0: endstop_interrupts.h:168:7: error: non-constant condition for static assertion static_assert(digitalPinToPCICR(Z_MIN_PIN) != NULL, "Z_MIN_PIN is not interrupt-capable"); ^~~~~~~~~~~~~ In file included from C:\Users\Nico\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.1\cores\arduino/Arduino.h:257:0, from sketch\MarlinConfig.h:37, from sketch\Marlin.h:36, from sketch\Marlin_main.cpp:244: D:\programm files\Arduino\hardware\anet\avr\variants\sanguino/pins_arduino.h:117:66: error: reinterpret_cast from integer to pointer #define digitalPinToPCICR(p) ( (((p) >= 0) && ((p) <= 31)) ? (&PCICR) : ((uint8_t *)0) ) ~^~~~~~~ sketch\endstop_interrupts.h:168:21: note: in expansion of macro 'digitalPinToPCICR' static_assert(digitalPinToPCICR(Z_MIN_PIN) != NULL, "Z_MIN_PIN is not interrupt-capable"); ^~~~~~~~~~~~~~~~~ Plusieurs bibliothèque trouvées pour "LiquidCrystal.h" Utilisé : D:\programm exit status 1 non-constant condition for static assertion Ce rapport pourrait être plus détaillé avec l'option "Afficher les résultats détaillés de la compilation" activée dans Fichier -> Préférences.
