Jean-Pierre Lorge
    Artillery SideWinder X1
Récompenses de Jean-Pierre Lorge
  1. Tout fonctionne merci beaucoup.
  2. Je vais tout remonté, je pense que cà a fonctionné, j'ai de nouveau un retour sur le terminal: 17:40:30.015 -> start 17:40:30.015 -> echo:Marlin 1.1.9 17:40:30.015 -> 17:40:30.015 -> echo: Last Updated: 2018-08-01 | Author: (none, default config) 17:40:30.049 -> echo:Compiled: Aug 4 2020 17:40:30.049 -> echo: Free Memory: 5260 PlannerBufferBytes: 1488 17:40:30.049 -> echo:Hardcoded Default Settings Loaded 17:40:30.049 -> echo: G21 ; (mm) 17:40:30.049 -> 17:40:30.049 -> echo:Filament settings: Disabled 17:40:30.049 -> echo: M200 D1.75 17:40:30.049 -> echo: M200 D0 17:40:30.049 -> echo:Steps per unit: 17:40:30.049 -> echo: M92 X80.12 Y80.12 Z399.78 E445.00 17:40:30.049 -> echo:Maximum feedrates (units/s): 17:40:30.049 -> echo: M203 X300.00 Y300.00 Z50.00 E40.00 17:40:30.049 -> echo:Maximum Acceleration (units/s2): 17:40:30.049 -> echo: M201 X2000 Y2000 Z100 E10000 17:40:30.049 -> echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel> 17:40:30.049 -> echo: M204 P800.00 R10000.00 T2000.00 17:40:30.049 -> echo:Advanced: Q<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk> 17:40:30.049 -> echo: M205 Q20000 S0.00 T0.00 X8.00 Y8.00 Z0.30 E5.00 17:40:30.049 -> echo:Home offset: 17:40:30.049 -> echo: M206 X0.00 Y0.00 Z0.00 17:40:30.049 -> echo:PID settings: 17:40:30.083 -> echo: M301 P14.58 I1.14 D46.57 17:40:30.083 -> echo: M304 P244.21 I45.87 D325.08 17:42:10.242 -> Error:EEPROM disabled 17:42:10.242 -> ok 17:42:18.475 -> echo: G21 ; (mm) 17:42:18.475 -> 17:42:18.475 -> echo:Filament settings: Disabled 17:42:18.475 -> echo: M200 D1.75 17:42:18.475 -> echo: M200 D0 17:42:18.475 -> echo:Steps per unit: 17:42:18.475 -> echo: M92 X80.12 Y80.12 Z399.78 E445.00 17:42:18.475 -> echo:Maximum feedrates (units/s): 17:42:18.475 -> echo: M203 X300.00 Y300.00 Z50.00 E40.00 17:42:18.475 -> echo:Maximum Acceleration (units/s2): 17:42:18.475 -> echo: M201 X2000 Y2000 Z100 E10000 17:42:18.475 -> echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel> 17:42:18.475 -> echo: M204 P800.00 R10000.00 T2000.00 17:42:18.475 -> echo:Advanced: Q<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk> 17:42:18.510 -> echo: M205 Q20000 S0.00 T0.00 X8.00 Y8.00 Z0.30 E5.00 17:42:18.510 -> echo:Home offset: 17:42:18.510 -> echo: M206 X0.00 Y0.00 Z0.00 17:42:18.510 -> echo:PID settings: 17:42:18.510 -> echo: M301 P14.58 I1.14 D46.57 17:42:18.510 -> echo: M304 P244.21 I45.87 D325.08 17:42:18.510 -> ok
  3. La suite, J'ai débranché la nappe de l'axe X comme et un peu plus démonté le capot et regardé la carte qui connecte la sonde, la chauffe, le ventilateur avant, en fait tout sur cette axe.
  4. Je suppose que c'est les deux mesures sur la photo que tu voulais ? sur les bornes AC avec la prise j'ai le 220-230 V et rien interrupteur sur off (heureusement) Et sur les 2 bornes V+ et V- 24 V et rien si int. off
  5. Déjà un tout grand merci @ ewaca et @ Jojo3D. Je vais évidemment espérer un peu et faire les tests. Je poste le suite de l'histoire.
  6. Bonjour à vous tous, Je pense que j'ai fait une grosse erreur. J'ai un Artillery sidewider X1 depuis une semaine tout allait bien mais j'ai essayé de flasher l'eeprom et maintenant je n'ai plus les capteurs de température, tout est à zéro, les mouvements ne fonctionnent plus, les ventilateurs ne fonctionnent plus, et la tête chauffante a augmenté en température que tout à commencer à fumer... Voilà ce que j'ai fait (un peu sans savoir) avec l'IDE Arduino, j'ai chargé le firmware : "sidewinder-x1-firmware-master" du github d'artillery avec le fichier .ino et fait les différents réglages : Type de carte sur Mega 2560, Processeur ATmega2560... choix port com (COM5) Programmateur AVRISP MKII charger la bib U8glib Vérifier/Compiler et puis j'ai téléverser, là timeout : Using Port : COM5 Using Programmer : wiring Overriding Baud Rate : 115200 avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout Une erreur est survenue lors du transfert du croquis avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer J'ai appuyé sur le reset et beep quelque chose c'est passé mais... fumée de la buse et puis ben j'ai tout stoppé attendu et rallumé, mais plus rien (l'écran affiche toujours mes les données sont à zéro et le reste est comme indiqué plus haut... Évidemment après quelques secondes la tête chauffe à nouveau et il faut arrêter. Je suis dégouté. Quelqu'un me guider, le renvoyer mais est-ce que la garantie est de toute façon perdue, changer des pièces ? par quoi commencer? Merci d'avance. Jean-Pierre
  7. Bonjour à Vous tous, Je viens d'acheter une Artillery side Sinder X1, pour l'instant 3 impressions de test, par de problème; Je viens ici pour essayer d'avoir quelques informations sur cette machine et apprendre des anciens (en années d'impression) pleins d'expériences. A bientôt, je vais parcourir le forum avant de poser mes questions. jplorge
