nikolas
Récompenses de nikolas
  1. Hi, with the help of a friend, we managed to make the btt tft24 screen to work, with uart connection and touch mode. I am able to perform homing, to set temperatures for the nozzle and the bed, and to start/stop fans. There is a problem now with the calibration probe. I cannot perform levelling using the probe. Have you any idea what is happening and how to overcome this problem? Thank you in advance
  2. I have connect with uart mode, based on a scheme I found here on another post. I connected the cables except the reset, but the screen dont open. I prefer to use this screen as 12864 mode, but have difficult time to figure out the right cables. When I connect with parallel mode, the screen works on uart mode, but there is no communication with the printer. When I change to 12864 mode, the screen is black. I am attaching the pins for the new screen and the pins of the motherboard, if anyone could help me, I will appreciate that. Thank you
  3. And here is the problem that I have with the original screen: When I insert an external sd card, the light of LCD screen turns off (the light and the brightness almost to zero), the fans turns off, and I am not able to do anything, it just freezes the whole printer. When I remove the sd card, the screen lights up again but the machine does not respond. The printer seems to work ok without the external sd card. The sd card is the same that I use for all of my prints on that machine. I haven't changed anything, and I haven't this problem in the past.
  4. Dear friends hi! I need your valuable help. I have a microdelta rework 3d printer and I am trying to connect a new lcd screen, because the original appears to have a problem with the external sd card reader. I get a Bigtreetech TFT24 v1.1 lcd screen that says it has two working modes. One is uart touch mode, and the other is 12864 mode. Could you please help me to make this work with my printer? Thank you all in advance. (Sorry that I write in English, but I dont understand French language. I try with translator)
