Complicyte1
    base de geetech prusa
Récompenses de Complicyte1
Explorer
Explorer (4/14)
  1. il faudrait bien plus que cela
  2. un super grand merci tous fonctionne maintenant imprimante a régler mais vous avez été vraiment super genial !!!!!!
  3. trop fort la compile ok je mat cela sur mon imprimante juste a inversé le x et y qui vont a l'envers
  4. { "resource": "/e:/HDD Papa/IMPRIMANTE 3D/Marlin-bugfix-2.0.x/Marlin/src/inc/SanityCheck.h", "owner": "cpp", "severity": 8, "message": "#error \"Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue.\"", "startLineNumber": 1404, "startColumn": 6, "endLineNumber": 1404, "endColumn": 6 } In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\HAL.cpp:24: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\HAL_SPI.cpp:51: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../core/../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\../../core/serial.h:24, from Marlin\src\HAL\LPC1768\DebugMonitor.cpp:25: Marlin\src\HAL\LPC1768\../../core/../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\include\digipot_mcp4451_I2C_routines.c.o In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\eeprom_flash.cpp:39: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\eeprom_sdcard.cpp:25: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\eeprom_wired.cpp:24: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\include\i2c_util.c.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\DebugMonitor.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_flash.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_sdcard.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_wired.cpp.o] Error 1 In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\main.cpp:34: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ *** [.pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o] Error 1 =================================================================================================== [FAILED] Took 6.17 seconds =================================================================================================== Environment Status Duration ------------- -------- ------------ LPC1769 FAILED 00:00:06.172 ============================================================================================== 1 failed, 0 succeeded in 00:00:06.172 ==============================================================================================Arrêt du processus de terminal "C:\Users\christian et valerie\.platformio\penv\Scripts\pio.exe 'run'". Code de sortie : 1. Le terminal sera réutilisé par les tâches, appuyez sur une touche pour le fermer. > Executing task: C:\Users\christian et valerie\.platformio\penv\Scripts\pio.exe run < Processing LPC1769 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1769; framework: arduino) -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html PLATFORM: NXP Arduino LPC176x (0.1.3) > NXP LPC1769 HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink) PACKAGES: - framework-arduino-lpc176x 0.2.6 - toolchain-gccarmnoneeabi 1.90301.200702 (9.3.1) Converting Marlin.ino LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf LDF Modes: Finder ~ off, Compatibility ~ strict Found 3 compatible libraries Scanning dependencies... Dependency Graph |-- <Servo> 1.0.0 |-- <TMCStepper> 0.7.1 |-- <U8glib-HAL> 0.4.3 Building in release mode error:Command 'cmd /C dir H:\' returned non-zero exit status 1. error:Command 'cmd /C dir I:\' returned non-zero exit status 1. error:Command 'cmd /C dir J:\' returned non-zero exit status 1. error:Command 'cmd /C dir K:\' returned non-zero exit status 1. error:Command 'cmd /C dir L:\' returned non-zero exit status 1. Unable to find destination disk (Autodetect Error) Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1769/firmware.bin) manually to the appropriate disk Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\DebugMonitor.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_flash.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_sdcard.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_wired.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\tft\tft_spi.cpp.o In file included from Marlin\src\HAL\LPC1768\../../core/../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\../../core/serial.h:24, from Marlin\src\HAL\LPC1768\DebugMonitor.cpp:25: Marlin\src\HAL\LPC1768\../../core/../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\HAL_SPI.cpp:51: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\HAL.cpp:24: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\eeprom_flash.cpp:39: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\eeprom_sdcard.cpp:25: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\main.cpp:34: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\eeprom_wired.cpp:24: Marlin\src\HAL\LPC1768\../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ In file included from Marlin\src\HAL\LPC1768\tft\../../../inc/MarlinConfig.h:49, from Marlin\src\HAL\LPC1768\tft\tft_spi.cpp:23: Marlin\src\HAL\LPC1768\tft\../../../inc/SanityCheck.h:1404:6: error: #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." 1404 | #error "Z_SAFE_HOMING is recommended when homing with a probe. Enable it or comment out this line to continue." | ^~~~~ *** [.pio\build\LPC1769\src\src\HAL\LPC1768\DebugMonitor.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_flash.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_sdcard.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_wired.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\tft\tft_spi.cpp.o] Error 1 =================================================================================================== [FAILED] Took 5.40 seco
  5. tout allait bien jusqu'a bltouch et bilinear desactivé puis erreur
  6. il ne faut pas activé //#define BLTOUCH et //#define AUTO_BED_LEVELING_BILINEAR
  7. jusqu'a la compil ok je vais sur avd ok avec le configuration adv.h
  8. pas valider bltouch bilinear
  9. jusqu'a maintenant tout ok mais avec carte mega2560 sur le config et sur pio.ini je suppose que je met le lpc1769 sur pio et je change les configs
  10. et marlin ouvert avec PIO bon je vais sur marlin re re telechargé marlin 2 (j'ai conservé les 2 config) le bugfix ou le 2.0.7
  11. et desinstaler et instaler VS
  12. je n'ai meme pas le martien de pio je suis vraiment un boulet avec ce logiciel vola ce que j'ai quand j'ouvre VS alors ensuite je galere pour trouver PIO
  13. oui absolument tout fonctionne avec le firmware le BL fonctionne l'imprimante n'est plus régler car j'avais tout repris depuis le départ avec les données que je me rappelais mais je ne peut rien régler avec Visual car erreur de compil avec le config.h que vous m'avez envoyé oui absolument le fichier BIN fonctionne !!! je suis vos conseil et je reviens vous dire Mais un très très grand merci a vous
  14. j'avoue que si je connais bien arduino ide, Visual basic et PlatformIO je galère grave
  15. Bonsoir, alors là !! je ne comprends pas quand je compil l'imprimante n'est pas branché et donc il ne peut savoir si les fils sont bien branchés (mais oui les fils sont au bon endroit ) j'ai donc installer le firmware sur la carte et incroyable le 3d touch ce déploie l'extrudeur descend normalement et lorsque que l'épingle touche le plateau l'extrudeur remonte par contre j'ai tout a re-regler je suis a 1cm du plateau et platformIO ne compile pas avec le votre remis sur marlin
