Franckshao
Tout ce qui a été posté par Franckshao
  1. Voila mes configuration et le ventilateur est un 5015 basic. Il tourne tous le temps à la même vitesse qu'il soit à 255 ou à 0. Dans l'immédiat sa ne me dérange pas plus que sa, je ne fait que du pla mais j'aimerais comprendre pour si un jour je me lance sur des matière plus technique. -La copie de la conversation avec MKS : moi : hello thank you for your answer everything works correctly, but there is something that I do not understand. for the fans I can't control the speed of the one for the filament. I logged in as follows fan for the heatsink on pin J5 (1st port 12/24v) and the one for the filament in J10 (fan1) with sub marlin * Extruder cooling fans * * Extruder auto fans automatically turn on when their extruders' * temperatures go above EXTRUDER_AUTO_FAN_TEMPERATURE. * * Your board's pins file specifies the recommended pins. Override those here * or set to -1 to disable completely. * * Multiple extruders can be assigned to the same pin in which case * the fan will turn on when any selected extruder is above the threshold. */ #define E0_AUTO_FAN_PIN -1 #define E1_AUTO_FAN_PIN -1 #define E2_AUTO_FAN_PIN -1 #define E3_AUTO_FAN_PIN -1 #define E4_AUTO_FAN_PIN -1 #define E5_AUTO_FAN_PIN -1 #define E6_AUTO_FAN_PIN -1 #define E7_AUTO_FAN_PIN -1 #define CHAMBER_AUTO_FAN_PIN -1 #define COOLER_AUTO_FAN_PIN -1 #define COOLER_FAN_PIN -1 #define EXTRUDER_AUTO_FAN_TEMPERATURE 50 #define EXTRUDER_AUTO_FAN_SPEED 255 // 255 == full speed #define CHAMBER_AUTO_FAN_TEMPERATURE 30 #define CHAMBER_AUTO_FAN_SPEED 255 #define COOLER_AUTO_FAN_TEMPERATURE 80 #define COOLER_AUTO_FAN_SPEED 255 but it does not stop and I cannot reduce the speed do you have an idea to solve my problem MKS: The speed of the fan can be controlled on the control interface, can you not control the speed of the fan on the control interface? moi:not in the interface whether it is at 0 or 100% it runs at the same speed la suite vous la connaissé
  2. salut à tous, je suis toujours coincé sur mon control de ventilation pour le filament, malgré plusieurs essai infructueux j'ai contacter MKS directement mais leur réponse est incompréhensible pour moi. MKS : It should be that the mos tube is burnt, and it should not be automatically opened. The controlled fan interface you are receiving is still open. google trad : Il faut que le tube mos soit brûlé, et il ne doit pas s'ouvrir automatiquement. L'interface de ventilateur contrôlé que vous recevez est toujours ouverte. es qu'il parle d'un cavalier a mettre sur la carte ? si des fois sa vous parle, moi je suis largué merci d'avance
  3. ok merci donc je vais tester comme suit radiateur sur J5 buse sur J10 avec marlin à -1 sur les pin de fan merci en tous cas a vous deux pour votre aide j'aurais fini par abandonné
  4. ha oups si je reprend de base PC14 et PB1 s'utilise pour un ventilateur sur la buse J5 et J4 pour le radiateur donc oui le mieux serai d'utiliser le fan 1 PC14 pour la buse et PB1 pour le radiateur
  5. ok donc j'ai compris l'inverse alors. si je reprend de base PC14 et PB1 s'utilise pour un ventilateur sur la buse J5 et J4 pour la buse donc si j'inverse mes branchement et que je remet les pin a -1 dans marlin je devrais être bon?
  6. Donc vous avec compris comme moi les pin fan1 et 2 correspond à E0 et E1 et les port 12/24v pour la buse cependant il ne ce contrôle pas. Es qu'il est possible d'utiliser le pin PB1 pour la buse ? À part ces 4 port je ne vois nulle part ou les connectés, y a un truc que J'ai du loupé je pense
  7. bonjour encore moi je pense que celui la est mon dernier souci (du moins je l'espère car je suis encours d'impression) je n'arrive pas a configuré un ventilateur pour le filament, sur les port fan il tourne tout le temps sur marlin je n'arrive pas a savoir ou sa ce règle, je vous met mes fichier de configuration et la carte des pins si une âme charitable veux bien m'aidé édite : pour le heatbreak il est connecté en pc14 et pour le filament en j5 merci d'avance Configuration.h Configuration_adv.h MKS Eagle V1.0_001 PIN.pdf
  8. Merci et pour le problème du ventilos tu à une idée ou pas ?
  9. Je ne l'ai pas en négatif mais si je lui demande de chauffe à 60 sa va monter jusque 50 pas plus de même pour 70 (60)
  10. je continue de régler au petit oignon, mais la je suis bloqué mon bed ne chauffe pas jusqu'à le température demandé, il reste -10° et je n'arrive pas à activé le ventilateur pour le filament ( pour le heatbreak ok) il ne me reste plus que cela pour lancer une impression. merci par avance Configuration.h Configuration_adv.h
  11. Je viens de check, je n'ai pas mis ces port la, je fait une fait la modification et je relance edit : je viens de recompilé et sa fonctionne, je vais bien dormir ce soir ^^
  12. J'ai tenté la connections au PC mais rien, j'ai bien le bruit deC'est encore moi j'ai reçu ma carte et l'écran mais je n'arrive à rien voila ce que sa me fait. J'ai testé plusieurs micro SD de mettre à jour l'écran comme dit sur https://github.com/makerbase-mks/MKS-H43 mais rien l'écran reste noir Même avec une carte sd avec marlin direct sur la carte rien comme sur la photo J'ai tenté la connections au PC mais rien, j'ai bien le bruit de connections mais même pronterface ne parvient pas à ce connecté. Avez vous une idée ? J'avoue la je désespère
  13. ho mais bien sur que si je remercie tous ceux qui m'ont apporté leur aide
  14. merci pommeverte ca a fonctionné, comme ca je vais pourvoir flash la cm directement sorti du carton demain matin
  15. oui certes mais je ne vois pas pourquoi car dans configuration.h et dans boards.h y a t-il un moyen de résoudre ce problème ? (je ne mis connais pas du tout)
  16. bonjour, pour ne pas prendre risque j'ai décidé de compilé sur la version 2.093 mais c'est : failed la je suis totalement paumé help plz
  17. ok je serrai sa en milieu de semaine, quand j'aurai reçu le kit. Surprise............... Sinon je doit suivre quel procédure pour passé sur la 2.0.9 merci d'avance
  18. après la moi j'ai prit celui qui correspondais à l'écran https://github.com/makerbase-mks/Marlin-V2.X-MKS-H43
  19. bonjour à tous , première compilation de marlin pour ma part. compilation terminé avec succès mais il me dit 7 avertissement je vous donne le détail du code pour les 2 groupe d'erreurs es que ces avertissent peuvent être problématique ou pas? si oui quelqu'un peut -il m'aidé ? toute la configuration vient du github de MKS, la carte va contrôler une alfawise U20 ONE merci par avance franck
  20. bonjour tout le monde, franck 34ans j'ai 2 imprimante, une ender5 qui va recevoir le kit BIGTREETECH Raspberry Pad 5Raspberry Pad 5 + SKR MINI E3 V3.0 et une alfawise U20 ONE qui n'en est plus une la carte mère ma lâché. Elle sera remplacer par une MKS Eagle v1 avec un MKS h43. voili voilou @+ les printers
