djscholas
Tout ce qui a été posté par djscholas
  1. Marlin firmware 2.1, now i have TFT firmware from Artillery www site and printer works well. But before that i tried install an firmware from your tutorial on this forum, dedicated to GD tft chipset i think Gioto or cioto GitHub - something like that
  2. @MrMagounet Artillery send me whole New tft module, after i changed it - pronter worked fine so i decied i’ll try an update, and… now update works, but…. After install i have an info on my screen „No printer atrached”… omg i have only problems with that printer could you Help me with that ?
  3. I bought it few weeks ago. Also saw that on your firmware printer doesnt work - nothing works when i put whatever on tft (axis movement, temp. Up/down etc). That firmware works well https://blog.freakydu.de/posts/2022-09-30-flash_marlin_sidewinderx2/ . So I should wait I think ?
  4. Still the same, damaged, mirrored and upsidedown @MrMagounet any ideas ? I also flashed your marlin firmware to check it but nothing changed
  5. Maybe you know also why when i stop print (for example print unstick from table) with stop button on display (in printer), my Z axis go to 0 position making collision with print on table ?
  6. Ok thank you in advance Now I`m back to Artillery TFT 3.2.6 firmware, but this firmware is lagging very much ... I dont like it
  7. Installed and have something like this its upsidedown and mirrored, and looks like something wrong
  8. @MrMagounet I made some pictures for you looks like GD32F305
  9. How can i check it ? I mean Marlin baudrate? MCU i have 3.0.5v
  10. @MrMagounet i have marlin 2.1.2 flashed into printer so it looks like newest Which version BTT needs? im waiting when you back home for Z-0 and Extruder instructions.
  11. @MrMagounet perfect. I’m waiting for your response in Z-0 and extruder settings. Btw. do you have a link to TFT firmware in English maybe ?
  12. @MrMagounet yes it works when i put off bridge. OMG thank you. last 2 questions: 1. Because before upgrade 1 time firmware i dont wrote parameters of origin z-0 and extrude ... then i made M502 and M500 Do you have some tutorials how to properly set them now ? 2. Do you have your software for sidewinder in English ?
  13. @MrMagounet ok, that works - i mean I flashed software info printer successfully like in PDF, next I turn off power and turn on and ... pronterface still dont see a printer... also any axis, heating, nothing works when i try to do it via printer display. Do you know what can i do ? i read that i should reset eprom after flashing, but i cant because pronterface dont see printer ehh... hope you can help
  14. Ok. Everything is Clear. Thank you very much. Do you have an PayPal or something where i give you an tip for a beer :)?
  15. Tell me Please If i understood good i should find on motherboard sign “pin 3v” and then put a cable to signed by you place ? need I an extra cable for this or I use only cables that are there already ? sorry for asking like an extra noob, but I don’t want to damage anything
  16. Omg. You gave me hope that it will work Thanks a lot. But should I bridge them like this: Or like that: And 2nd question - should i bridge them with some specific kind of cable ? Because i dont have any special item to bridge them. Could you also tell me what you mean "2 pins 3v"| ?
  17. Hello, Im here because of the movie with firmware update where i found this link: I need help because during firmware flashing electricity in my house was turned off and i cant do anything with printer :( Just tried to update Marlin firmware from freakydude from GitHub update via pronterface and stm35. After I download firmware via stm32 and install to printe, then reset it, and was great but I didn’t save my Z offset and Extrusion data before… so I tried to go a step back and install old backup firmware again via stm32. So Conner to pronterface, M997, than stm32 and install backup firmware. then reset printer and… I tried to connect with pronterface to reset eprom and… protnerface can’t see printer via usb cable… also any tryouts to axis movement via touch screen on printer asp doesn’t work. Looks like everything failed… how can I put into printer firmware again when pc don’t see it via cable ? @MrMagounet Help me please
