Bonjour , suite au bug du forum je republis mes annonces
vend scanner sense 3d v1 nue , de toute facon il est pas vendu sans rien de plus il me semble
vous devrez ecrire a sens poiur mettre la licence a votre nom , c'est pas compliqué mais ils repondent aux heures americaines.
  • prix du neuf 350€
  • mon prix : 250€
envois : Mondial Relay 5€
The Sense 3D scanner delivers best-in-class accuracy of close to 1 mm with resolution at 1 mm.
Life goes on
Sense has an unprecedented color resolution of 1920 x 1080 pixels for perfect color texture mapping.
Zero in
Sense has a generous scan range of between 7 and 72 inches to allow for rapid 3D scanning of a wide range of objects.
Capture
The Sense 3D scanner includes software to rapidly edit your 3D scan data and solidify for immediate 3D printing.
Life is Better
Save data out to four industry standard formats: OBJ, WRL, STL, and PLY, for downstream uses.
Sense 3D scanner Tech specs
Supported operating systems
64-bit Windows 8 or later
Scan volume
Min: 0.2m x 0.2m x 0.2m
Max: 2m x 2m x 2m
Dimensions
5.08(w) x 7.08(h) x 1.3(d) inches
12.9(w) x 17.8(h) x 3.3(d) cm
Operating range
Min: 0.2m
Max: 1.6m
Depth image size
640(w) x 480(h) px
Color image size
1920(w) x 1080(h) px
Field of view
Horizontal: 45°
Vertical: 57.5°
Diagonal: 69°
Spatial x/y resolution @ 0.5m
0.9mm
Depth resolution @ 0.5m
1mm
Operating temperature
10-40° C
Data interface
USB 3.0
USB cord length
6 feet
Maximal image throughput
30 fps
Hardware recommendations
Intel® Core i5™ 5th Gen or equivalent processor (click here for details)
RAM: 2 GB minimum
1280 x 1024 minimum screen resolution
4 GB available hard disk space
