olivmouth Posté(e) Janvier 28, 2018 Posté(e) Janvier 28, 2018 Bonjour , suite au bug du forum je republis mes annonces =============== vend scanner sense 3d v1 nue , de toute facon il est pas vendu sans rien de plus il me semble vous devrez ecrire a sens poiur mettre la licence a votre nom , c'est pas compliqué mais ils repondent aux heures americaines. prix du neuf 350€ mon prix : 250€ localisation : Nimes envois : Mondial Relay 5€ The Sense 3D scanner delivers best-in-class accuracy of close to 1 mm with resolution at 1 mm. Sense has an unprecedented color resolution of 1920 x 1080 pixels for perfect color texture mapping. Sense has a generous scan range of between 7 and 72 inches to allow for rapid 3D scanning of a wide range of objects. The Sense 3D scanner includes software to rapidly edit your 3D scan data and solidify for immediate 3D printing. Save data out to four industry standard formats: OBJ, WRL, STL, and PLY, for downstream uses. Sense 3D scanner Tech specs Supported operating systems 64-bit Windows 8 or later Scan volume Min: 0.2m x 0.2m x 0.2m Max: 2m x 2m x 2m Dimensions 5.08(w) x 7.08(h) x 1.3(d) inches 12.9(w) x 17.8(h) x 3.3(d) cm Operating range Min: 0.2m Max: 1.6m Depth image size 640(w) x 480(h) px Color image size 1920(w) x 1080(h) px Field of view Horizontal: 45° Vertical: 57.5° Diagonal: 69° Spatial x/y resolution @ 0.5m 0.9mm Depth resolution @ 0.5m 1mm Operating temperature 10-40° C Data interface USB 3.0 USB cord length 6 feet Maximal image throughput 30 fps Hardware recommendations Intel® Core i5™ 5th Gen or equivalent processor (click here for details) RAM: 2 GB minimum 1280 x 1024 minimum screen resolution 4 GB available hard disk space
