bonjour jais fait la mise a jour de mon firmware sur une imprimante DIY  ,
matériel
carte  arduino ( model non marquer je dirais une mega 2560 a la taille)
board : GPL3 de bigtreetech
contrôleur : A4988
LCD RepRapDiscount Full Graphic Smart Controller
2 moteur pour l'axe z
brancher a la carte / hotend/rien /bed
voila :
fichier configuration:
 * Marlin 3D Printer Firmware
 * Copyright (C) 2016 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
 * Based on Sprinter and grbl.
 * Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
 * Configuration.h
 * Basic settings such as:
 * - Type of electronics
 * - Type of temperature sensor
 * - Printer geometry
 * - Endstop configuration
 * - LCD controller
 * - Extra features
 * Advanced settings can be found in Configuration_adv.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define CONFIGURATION_H_VERSION 010109
//============================= Getting Started =============================
 * Here are some standard links for getting your machine calibrated:
 * http://reprap.org/wiki/Calibration
 * http://youtu.be/wAL9d7FgInk
 * http://calculator.josefprusa.cz
 * http://reprap.org/wiki/Triffid_Hunter%27s_Calibration_Guide
 * http://www.thingiverse.com/thing:5573
 * https://sites.google.com/site/repraplogphase/calibration-of-your-reprap
 * http://www.thingiverse.com/thing:298812
//============================= DELTA Printer ===============================
// For a Delta printer start with one of the configuration files in the
// example_configurations/delta directory and customize for your machine.
//============================= SCARA Printer ===============================
// For a SCARA printer start with the configuration files in
// example_configurations/SCARA and customize for your machine.
//============================= HANGPRINTER =================================
// For a Hangprinter start with the configuration file in the
// example_configurations/hangprinter directory and customize for your machine.
// @section info
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
#define STRING_SPLASH_LINE2 WEBSITE_URL         // will be shown during bootup in line 2
 * *** VENDORS PLEASE READ ***
 * Marlin allows you to add a custom boot image for Graphical LCDs.
 * With this option Marlin will first show your custom screen followed
 * by the standard Marlin logo with version number and web URL.
 * We encourage you to take advantage of this new feature and we also
 * respectfully request that you retain the unmodified Marlin boot screen.
// Enable to show the bitmap in Marlin/_Bootscreen.h on startup.
//#define SHOW_CUSTOM_BOOTSCREEN
// Enable to show the bitmap in Marlin/_Statusscreen.h on the status screen.
//#define CUSTOM_STATUS_SCREEN_IMAGE
// @section machine
 * Select the serial port on the board to use for communication with the host.
 * This allows the connection of wireless adapters (for instance) to non-default port pins.
 * Serial port 0 is always used by the Arduino bootloader regardless of this setting.
 * :[0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT 0
 * This setting determines the communication speed of the printer.
 * 250000 works in most cases, but you might try a lower speed if
 * you commonly experience drop-outs during host printing.
 * You may try up to 1000000 to speed up SD file transfer.
 * :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000]
#define BAUDRATE 250000
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
  #define MOTHERBOARD BOARD_RAMPS_14_EFB
#endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD "Ready" message
//#define CUSTOM_MACHINE_NAME "3D Printer"
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg http://www.uuidgenerator.net/version4)
//#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
// @section extruder
// This defines the number of extruders
// :[1, 2, 3, 4, 5]
#define EXTRUDERS 1
// Generally expected filament diameter (1.75, 2.85, 3.0, ...). Used for Volumetric, Filament Width Sensor, etc.
#define DEFAULT_NOMINAL_FILAMENT_DIA 3.0
// For Cyclops or any "multi-extruder" that shares a single nozzle.
//#define SINGLENOZZLE
 * Průša MK2 Single Nozzle Multi-Material Multiplexer, and variants.
 * This device allows one stepper driver on a control board to drive
 * two to eight stepper motors, one at a time, in a manner suitable
 * for extruders.
 * This option only allows the multiplexer to switch on tool-change.
 * Additional options to configure custom E moves are pending.
//#define MK2_MULTIPLEXER
#if ENABLED(MK2_MULTIPLEXER)
  // Override the default DIO selector pins here, if needed.
  // Some pins files may provide defaults for these pins.
  //#define E_MUX0_PIN 40  // Always Required
  //#define E_MUX1_PIN 42  // Needed for 3 to 8 steppers
  //#define E_MUX2_PIN 44  // Needed for 5 to 8 steppers
#endif
// A dual extruder that uses a single stepper motor
//#define SWITCHING_EXTRUDER
#if ENABLED(SWITCHING_EXTRUDER)
  #define SWITCHING_EXTRUDER_SERVO_NR 0
  #define SWITCHING_EXTRUDER_SERVO_ANGLES { 0, 90 } // Angles for E0, E1[, E2, E3]
  #if EXTRUDERS > 3
    #define SWITCHING_EXTRUDER_E23_SERVO_NR 1
  #endif
#endif
// A dual-nozzle that uses a servomotor to raise/lower one of the nozzles
//#define SWITCHING_NOZZLE
#if ENABLED(SWITCHING_NOZZLE)
  #define SWITCHING_NOZZLE_SERVO_NR 0
  #define SWITCHING_NOZZLE_SERVO_ANGLES { 0, 90 }   // Angles for E0, E1
  //#define HOTEND_OFFSET_Z { 0.0, 0.0 }
#endif
 * Two separate X-carriages with extruders that connect to a moving part
 * via a magnetic docking mechanism. Requires SOL1_PIN and SOL2_PIN.
//#define PARKING_EXTRUDER
#if ENABLED(PARKING_EXTRUDER)
  #define PARKING_EXTRUDER_SOLENOIDS_INVERT           // If enabled, the solenoid is NOT magnetized with applied voltage
  #define PARKING_EXTRUDER_SOLENOIDS_PINS_ACTIVE LOW  // LOW or HIGH pin signal energizes the coil
  #define PARKING_EXTRUDER_SOLENOIDS_DELAY 250        // Delay (ms) for magnetic field. No delay if 0 or not defined.
  #define PARKING_EXTRUDER_PARKING_X { -78, 184 }     // X positions for parking the extruders
  #define PARKING_EXTRUDER_GRAB_DISTANCE 1            // mm to move beyond the parking point to grab the extruder
  #define PARKING_EXTRUDER_SECURITY_RAISE 5           // Z-raise before parking
  #define HOTEND_OFFSET_Z { 0.0, 1.3 }                // Z-offsets of the two hotends. The first must be 0.
#endif
 * "Mixing Extruder"
 *   - Adds G-codes M163 and M164 to set and "commit" the current mix factors.
 *   - Extends the stepping routines to move multiple steppers in proportion to the mix.
 *   - Optional support for Repetier Firmware's 'M164 S<index>' supporting virtual tools.
 *   - This implementation supports up to two mixing extruders.
 *   - Enable DIRECT_MIXING_IN_G1 for M165 and mixing in G1 (from Pia Taubert's reference implementation).
//#define MIXING_EXTRUDER
#if ENABLED(MIXING_EXTRUDER)
  #define MIXING_STEPPERS 2        // Number of steppers in your mixing extruder
  #define MIXING_VIRTUAL_TOOLS 16  // Use the Virtual Tool method with M163 and M164
  //#define DIRECT_MIXING_IN_G1    // Allow ABCDHI mix factors in G1 movement commands
#endif
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define HOTEND_OFFSET_Y {0.0, 5.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
// @section machine
 * Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
 * 0 = No Power Switch
 * 1 = ATX
 * 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
 * :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 0
#if POWER_SUPPLY > 0
  // Enable this option to leave the PSU off at startup.
  // Power to steppers and heaters will need to be turned on with M80.
  //#define PS_DEFAULT_OFF
  //#define AUTO_POWER_CONTROL        // Enable automatic control of the PS_ON pin
  #if ENABLED(AUTO_POWER_CONTROL)
    #define AUTO_POWER_FANS           // Turn on PSU if fans need power
    #define AUTO_POWER_E_FANS
    #define AUTO_POWER_CONTROLLERFAN
    #define POWER_TIMEOUT 30
  #endif
#endif
// @section temperature
//============================= Thermal Settings ============================
 * --NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
 * Temperature sensors available:
 *    -4 : thermocouple with AD8495
 *    -3 : thermocouple with MAX31855 (only for sensor 0)
 *    -2 : thermocouple with MAX6675 (only for sensor 0)
 *    -1 : thermocouple with AD595
 *     0 : not used
 *     1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
 *     2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
 *     3 : Mendel-parts thermistor (4.7k pullup)
 *     4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
 *     5 : 100K thermistor - ATC Semitec 104GT-2/104NT-4-R025H42G (Used in ParCan & J-Head) (4.7k pullup)
 *   501 : 100K Zonestar (Tronxy X3A) Thermistor
 *     6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
 *     7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
 *    71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
 *     8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
 *     9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
 *    10 : 100k RS thermistor 198-961 (4.7k pullup)
 *    11 : 100k beta 3950 1% thermistor (4.7k pullup)
 *    12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
 *    13 : 100k Hisens 3950  1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE"
 *    15 : 100k thermistor calibration for JGAurora A5 hotend
 *    20 : the PT100 circuit found in the Ultimainboard V2.x
 *    60 : 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
 *    66 : 4.7M High Temperature thermistor from Dyze Design
 *    70 : the 100K thermistor found in the bq Hephestos 2
 *    75 : 100k Generic Silicon Heat Pad with NTC 100K MGB18-104F39050L32 thermistor
 *       1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k.
 *                              (but gives greater accuracy and more stable PID)
 *    51 : 100k thermistor - EPCOS (1k pullup)
 *    52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
 *    55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
 *  1047 : Pt1000 with 4k7 pullup
 *  1010 : Pt1000 with 1k pullup (non standard)
 *   147 : Pt100 with 4k7 pullup
 *   110 : Pt100 with 1k pullup (non standard)
 *         Use these for Testing or Development purposes. NEVER for production machine.
 *   998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below.
 *   999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
 * :{ '0': "Not used", '1':"100k / 4.7k - EPCOS", '2':"200k / 4.7k - ATC Semitec 204GT-2", '3':"Mendel-parts / 4.7k", '4':"10k !! do not use for a hotend. Bad resolution at high temp. !!", '5':"100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '501':"100K Zonestar (Tronxy X3A)", '6':"100k / 4.7k EPCOS - Not as accurate as Table 1", '7':"100k / 4.7k Honeywell 135-104LAG-J01", '8':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9':"100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10':"100k / 4.7k RS 198-961", '11':"100k / 4.7k beta 3950 1%", '12':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13':"100k Hisens 3950  1% up to 300°C for hotend 'Simple ONE ' & hotend 'All In ONE'", '20':"PT100 (Ultimainboard V2.x)", '51':"100k / 1k - EPCOS", '52':"200k / 1k - ATC Semitec 204GT-2", '55':"100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '60':"100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '66':"Dyze Design 4.7M High Temperature thermistor", '70':"the 100K thermistor found in the bq Hephestos 2", '71':"100k / 4.7k Honeywell 135-104LAF-J01", '147':"Pt100 / 4.7k", '1047':"Pt1000 / 4.7k", '110':"Pt100 / 1k (non-standard)", '1010':"Pt1000 / 1k (non standard)", '-4':"Thermocouple + AD8495", '-3':"Thermocouple + MAX31855 (only for sensor 0)", '-2':"Thermocouple + MAX6675 (only for sensor 0)", '-1':"Thermocouple + AD595",'998':"Dummy 1", '999':"Dummy 2" }
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
#define TEMP_SENSOR_BED 0
#define TEMP_SENSOR_CHAMBER 0
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 100
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10  // (seconds)
#define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 10  // (seconds)
#define TEMP_BED_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_BED_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define HEATER_4_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define HEATER_4_MAXTEMP 275
#define BED_MAXTEMP 150
//============================= PID Settings ================================
// PID Tuning Guide here: http://reprap.org/wiki/PID_Tuning
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255     // Limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // Limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#define PID_K1 0.95      // Smoothing factor within any PID loop
#if ENABLED(PIDTEMP)
  //#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
  //#define PID_DEBUG // Sends debug data to the serial port.
  //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
  //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
  //#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
                                  // Set/get with gcode: M301 E[extruder number, 0-2]
  #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
                                  // is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
  // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
  // Ultimaker
  #define DEFAULT_Kp 22.2
  #define DEFAULT_Ki 1.08
  #define DEFAULT_Kd 114
  // MakerGear
  //#define DEFAULT_Kp 7.0
  //#define DEFAULT_Ki 0.1
  //#define DEFAULT_Kd 12
  // Mendel Parts V9 on 12V
  //#define DEFAULT_Kp 63.0
  //#define DEFAULT_Ki 2.25
  //#define DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
 * PID Bed Heating
 * If this option is enabled set PID constants below.
 * If this option is disabled, bang-bang will be used and BED_LIMIT_SWITCHING will enable hysteresis.
 * The PID frequency will be the same as the extruder PWM.
 * If PID_dT is the default, and correct for the hardware/configuration, that means 7.689Hz,
 * which is fine for driving a square wave into a resistive load and does not significantly
 * impact FET heating. This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W
 * heater. If your configuration is significantly different than this and you don't understand
 * the issues involved, don't use bed PID until someone else verifies that your hardware works.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
 * Max Bed Power
 * Applies to all forms of bed control (PID, bang-bang, and bang-bang with hysteresis).
 * When set to any value below 255, enables a form of PWM to the bed that acts like a divider
 * so don't use it unless you are OK with PWM on your bed. (See the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
  //#define PID_BED_DEBUG // Sends debug data to the serial port.
  //120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
  //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
  #define DEFAULT_bedKp 10.00
  #define DEFAULT_bedKi .023
  #define DEFAULT_bedKd 305.4
  //from pidautotune
  //#define DEFAULT_bedKp 97.1
  //#define DEFAULT_bedKi 1.41
  //#define DEFAULT_bedKd 1675.16
  // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
 * Prevent extrusion if the temperature is below EXTRUDE_MINTEMP.
 * Add M302 to set the minimum extrusion temperature and/or turn
 * cold extrusion prevention on and off.
 * *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
#define PREVENT_COLD_EXTRUSION
#define EXTRUDE_MINTEMP 170
 * Prevent a single extrusion longer than EXTRUDE_MAXLENGTH.
 * Note: For Bowden Extruders make this large enough to allow load/unload.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 200
//======================== Thermal Runaway Protection =======================
 * Thermal Protection provides additional protection to your printer from damage
 * and fire. Marlin always includes safe min and max temperature ranges which
 * protect against a broken or disconnected thermistor wire.
 * The issue: If a thermistor falls out, it will report the much lower
 * temperature of the air in the room, and the the firmware will keep
 * the heater on.
 * If you get "Thermal Runaway" or "Heating failed" errors the
 * details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED     // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment one of these options to enable CoreXY, CoreXZ, or CoreYZ kinematics
// either in the usual order or reversed
//#define COREXY
//#define COREXZ
//#define COREYZ
//#define COREYX
//#define COREZX
//#define COREZY
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
//#define USE_ZMAX_PLUG
// Enable pullup for all endstops to prevent a floating state
#define ENDSTOPPULLUPS
#if DISABLED(ENDSTOPPULLUPS)
  // Disable ENDSTOPPULLUPS to set pullups individually
  //#define ENDSTOPPULLUP_XMAX
  //#define ENDSTOPPULLUP_YMAX
  //#define ENDSTOPPULLUP_ZMAX
  //#define ENDSTOPPULLUP_XMIN
  //#define ENDSTOPPULLUP_YMIN
  //#define ENDSTOPPULLUP_ZMIN
  //#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
 * Stepper Drivers
 * These settings allow Marlin to tune stepper driver timing and enable advanced options for
 * stepper drivers that support them. You may also override timing options in Configuration_adv.h.
 * A4988 is assumed for unspecified drivers.
 * Options: A4988, DRV8825, LV8729, L6470, TB6560, TB6600, TMC2100,
 *          TMC2130, TMC2130_STANDALONE, TMC2208, TMC2208_STANDALONE,
 *          TMC26X,  TMC26X_STANDALONE,  TMC2660, TMC2660_STANDALONE,
 *          TMC5130, TMC5130_STANDALONE
 * :['A4988', 'DRV8825', 'LV8729', 'L6470', 'TB6560', 'TB6600', 'TMC2100', 'TMC2130', 'TMC2130_STANDALONE', 'TMC2208', 'TMC2208_STANDALONE', 'TMC26X', 'TMC26X_STANDALONE', 'TMC2660', 'TMC2660_STANDALONE', 'TMC5130', 'TMC5130_STANDALONE']
#define X_DRIVER_TYPE  A4988
#define Y_DRIVER_TYPE  A4988
#define Z_DRIVER_TYPE  A4988
//#define X2_DRIVER_TYPE A4988
//#define Y2_DRIVER_TYPE A4988
//#define Z2_DRIVER_TYPE A4988
#define E0_DRIVER_TYPE A4988
//#define E1_DRIVER_TYPE A4988
//#define E2_DRIVER_TYPE A4988
//#define E3_DRIVER_TYPE A4988
//#define E4_DRIVER_TYPE A4988
// Enable this feature if all enabled endstop pins are interrupt-capable.
// This will remove the need to poll the interrupt pins, saving many CPU cycles.
//#define ENDSTOP_INTERRUPTS_FEATURE
 * Endstop Noise Filter
 * Enable this option if endstops falsely trigger due to noise.
 * NOTE: Enabling this feature means adds an error of +/-0.2mm, so homing
 * will end up at a slightly different position on each G28. This will also
 * reduce accuracy of some bed probes.
 * For mechanical switches, the better approach to reduce noise is to install
 * a 100 nanofarads ceramic capacitor in parallel with the switch, making it
 * essentially noise-proof without sacrificing accuracy.
 * This option also increases MCU load when endstops or the probe are enabled.
 * So this is not recommended. USE AT YOUR OWN RISK.
 * (This feature is not required for common micro-switches mounted on PCBs
 * based on the Makerbot design, since they already include the 100nF capacitor.)
//#define ENDSTOP_NOISE_FILTER
//============================== Movement Settings ============================
// @section motion
 * Default Settings
 * These settings can be reset by M502
 * Note that if EEPROM is enabled, saved values will override these.
 * With this option each E stepper can have its own factors for the
 * following movement settings. If fewer factors are given than the
 * total number of extruders, the last value applies to the rest.
//#define DISTINCT_E_FACTORS
 * Default Axis Steps Per Unit (steps/mm)
 * Override with M92
 *                                      X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
#define DEFAULT_AXIS_STEPS_PER_UNIT   { 80, 80, 4000, 105 }
 * Default Max Feed Rate (mm/s)
 * Override with M203
#define DEFAULT_MAX_FEEDRATE          { 500, 500, 2, 25 }
 * Default Max Acceleration (change/s) change = mm/s
 * (Maximum start speed for accelerated moves)
 * Override with M201
#define DEFAULT_MAX_ACCELERATION      { 3000, 3000, 100, 10000 }
 * Default Acceleration (change/s) change = mm/s
 * Override with M204
 *   M204 P    Acceleration
 *   M204 R    Retract Acceleration
 *   M204 T    Travel Acceleration
#define DEFAULT_ACCELERATION          3000    // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION  3000    // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION   3000    // X, Y, Z acceleration for travel (non printing) moves
 * Default Jerk (mm/s)
 * Override with M205 X Y Z E
 * "Jerk" specifies the minimum speed change that requires acceleration.
 * When changing speed and direction, if the difference is less than the
 * value set here, it may happen instantaneously.
#define DEFAULT_XJERK                 16.0
#define DEFAULT_YJERK                 16.0
#define DEFAULT_ZJERK                  0.4
#define DEFAULT_EJERK                  5.0
 * S-Curve Acceleration
 * This option eliminates vibration during printing by fitting a Bézier
 * curve to move acceleration, producing much smoother direction changes.
 * See https://github.com/synthetos/TinyG/wiki/Jerk-Controlled-Motion-Explained
//#define S_CURVE_ACCELERATION
//============================= Z Probe Options =============================
// @section probes
// See http://marlinfw.org/docs/configuration/probes.html
 * Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
 * Enable this option for a probe connected to the Z Min endstop pin.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
 * Z_MIN_PROBE_ENDSTOP
 * Enable this option for a probe connected to any pin except Z-Min.
 * (By default Marlin assumes the Z-Max endstop pin.)
 * To use a custom Z Probe pin, set Z_MIN_PROBE_PIN below.
 *  - The simplest option is to use a free endstop connector.
 *  - Use 5V for powered (usually inductive) sensors.
 *  - RAMPS 1.3/1.4 boards may use the 5V, GND, and Aux4->D32 pin:
 *    - For simple switches connect...
 *      - normally-closed switches to GND and D32.
 *      - normally-open switches to 5V and D32.
 * WARNING: Setting the wrong pin may have unexpected and potentially
 * disastrous consequences. Use with caution and do your homework.
//#define Z_MIN_PROBE_ENDSTOP
 * Probe Type
 * Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
 * Activate one of these to use Auto Bed Leveling below.
 * The "Manual Probe" provides a means to do "Auto" Bed Leveling without a probe.
 * Use G29 repeatedly, adjusting the Z height at each point with movement commands
 * or (with LCD_BED_LEVELING) the LCD controller.
//#define PROBE_MANUALLY
//#define MANUAL_PROBE_START_Z 0.2
 * A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
 *   (e.g., an inductive probe or a nozzle-based probe-switch.)
//#define FIX_MOUNTED_PROBE
 * Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_PROBE_SERVO_NR 0   // Defaults to SERVO 0 connector.
//#define Z_SERVO_ANGLES {70,0}  // Z Servo Deploy and Stow angles
 * The BLTouch probe uses a Hall effect sensor and emulates a servo.
//#define BLTOUCH
#if ENABLED(BLTOUCH)
  //#define BLTOUCH_DELAY 375   // (ms) Enable and increase if needed
#endif
 * Enable one or more of the following if probing seems unreliable.
 * Heaters and/or fans can be disabled during probing to minimize electrical
 * noise. A delay can also be added to allow noise and vibration to settle.
 * These options are most useful for the BLTouch probe, but may also improve
 * readings with inductive probes and piezo sensors.
//#define PROBING_HEATERS_OFF       // Turn heaters off when probing
#if ENABLED(PROBING_HEATERS_OFF)
  //#define WAIT_FOR_BED_HEATER     // Wait for bed to heat back up between probes (to improve accuracy)
#endif
//#define PROBING_FANS_OFF          // Turn fans off when probing
//#define DELAY_BEFORE_PROBING 200  // (ms) To prevent vibrations from triggering piezo sensors
// A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
//#define SOLENOID_PROBE
// A sled-mounted probe like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5  // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// For Z_PROBE_ALLEN_KEY see the Delta example configurations.
 *   Z Probe to nozzle (X,Y) offset, relative to (0, 0).
 *   X and Y offsets must be integers.
 *   In the following example the X and Y offsets are both positive:
 *   #define X_PROBE_OFFSET_FROM_EXTRUDER 10
 *   #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
 *      +-- BACK ---+
 *    L |    (+) P  | R <-- probe (20,20)
 *    E |           | I
 *    F | (-) N (+) | G <-- nozzle (10,10)
 *    T |           | H
 *      |    (-)    | T
 *      O-- FRONT --+
 *    (0,0)
#define X_PROBE_OFFSET_FROM_EXTRUDER 10  // X offset: -left  +right  [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 10  // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0   // Z offset: -below +above  [the nozzle]
// Certain types of probes need to stay away from edges
#define MIN_PROBE_EDGE 10
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 8000
// Feedrate (mm/m) for the first approach when double-probing (MULTIPLE_PROBING == 2)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Feedrate (mm/m) for the "accurate" probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
// The number of probes to perform at each point.
//   Set to 2 for a fast/slow probe, using the second probe result.
//   Set to 3 or more for slow probes, averaging the results.
//#define MULTIPLE_PROBING 2
 * Z probes require clearance when deploying, stowing, and moving between
 * probe points to avoid hitting the bed and other hardware.
 * Servo-mounted probes require extra space for the arm to rotate.
 * Inductive probes need space to keep from triggering early.
 * Use these settings to specify the distance (mm) to raise the probe (or
 * lower the bed). The values set here apply over and above any (negative)
 * probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
 * Only integer values >= 1 are valid here.
 * Example: `M851 Z-5` with a CLEARANCE of 4  =>  9mm from bed to nozzle.
 *     But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE   10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES  5 // Z Clearance between probe points
#define Z_CLEARANCE_MULTI_PROBE     5 // Z Clearance between multiple probes
//#define Z_AFTER_PROBING           5 // Z position after probing is done
#define Z_PROBE_LOW_POINT          -2 // Farthest distance below the trigger-point to go before stopping
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// Enable the M48 repeatability test to test probe accuracy
//#define Z_MIN_PROBE_REPEATABILITY_TEST
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled.
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR true
#define INVERT_Z_DIR false
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
// @section homing
//#define NO_MOTION_BEFORE_HOMING  // Inhibit movement until all axes have been homed
//#define UNKNOWN_Z_NO_RAISE // Don't raise Z (lower the bed) if Z is "unknown." For beds that fall when Z is powered off.
//#define Z_HOMING_HEIGHT 4  // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
                             // Be sure you have this distance over your Z_MAX_POS in case.
// Direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
// @section machine
// The size of the print bed
#define X_BED_SIZE 200
#define Y_BED_SIZE 200
// Travel limits (mm) after homing, corresponding to endstop positions.
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 200
 * Software Endstops
 * - Prevent moves outside the set machine bounds.
 * - Individual axes can be disabled, if desired.
 * - X and Y only apply to Cartesian robots.
 * - Use 'M211' to set software endstops on/off or report current state
// Min software endstops constrain movement within minimum coordinate bounds
#define MIN_SOFTWARE_ENDSTOPS
#if ENABLED(MIN_SOFTWARE_ENDSTOPS)
  #define MIN_SOFTWARE_ENDSTOP_X
  #define MIN_SOFTWARE_ENDSTOP_Y
  #define MIN_SOFTWARE_ENDSTOP_Z
#endif
// Max software endstops constrain movement within maximum coordinate bounds
#define MAX_SOFTWARE_ENDSTOPS
#if ENABLED(MAX_SOFTWARE_ENDSTOPS)
  #define MAX_SOFTWARE_ENDSTOP_X
  #define MAX_SOFTWARE_ENDSTOP_Y
  #define MAX_SOFTWARE_ENDSTOP_Z
#endif
#if ENABLED(MIN_SOFTWARE_ENDSTOPS) || ENABLED(MAX_SOFTWARE_ENDSTOPS)
  //#define SOFT_ENDSTOPS_MENU_ITEM  // Enable/Disable software endstops from the LCD
#endif
 * Filament Runout Sensors
 * Mechanical or opto endstops are used to check for the presence of filament.
 * RAMPS-based boards use SERVO3_PIN for the first runout sensor.
 * For other boards you may need to define FIL_RUNOUT_PIN, FIL_RUNOUT2_PIN, etc.
 * By default the firmware assumes HIGH=FILAMENT PRESENT.
//#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
  #define NUM_RUNOUT_SENSORS   1     // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each.
  #define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
  #define FIL_RUNOUT_PULLUP          // Use internal pullup for filament runout pins.
  #define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
//=============================== Bed Leveling ==============================
// @section calibrate
 * Choose one of the options below to enable G29 Bed Leveling. The parameters
 * and behavior of G29 will change depending on your selection.
 *  If using a Probe for Z Homing, enable Z_SAFE_HOMING also!
 * - AUTO_BED_LEVELING_3POINT
 *   Probe 3 arbitrary points on the bed (that aren't collinear)
 *   You specify the XY coordinates of all 3 points.
 *   The result is a single tilted plane. Best for a flat bed.
 * - AUTO_BED_LEVELING_LINEAR
 *   Probe several points in a grid.
 *   You specify the rectangle and the density of sample points.
 * - AUTO_BED_LEVELING_BILINEAR
 *   The result is a mesh, best for large or uneven beds.
 * - AUTO_BED_LEVELING_UBL (Unified Bed Leveling)
 *   A comprehensive bed leveling system combining the features and benefits
 *   of other systems. UBL also includes integrated Mesh Generation, Mesh
 *   Validation and Mesh Editing systems.
 * - MESH_BED_LEVELING
 *   Probe a grid manually
 *   The result is a mesh, suitable for large or uneven beds. (See BILINEAR.)
 *   For machines without a probe, Mesh Bed Leveling provides a method to perform
 *   leveling in steps so you can manually adjust the Z height at each grid-point.
 *   With an LCD controller the process is guided step-by-step.
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
//#define AUTO_BED_LEVELING_UBL
//#define MESH_BED_LEVELING
 * Normally G28 leaves leveling disabled on completion. Enable
 * this option to have G28 restore the prior leveling state.
//#define RESTORE_LEVELING_AFTER_G28
 * Enable detailed logging of G28, G29, M48, etc.
 * Turn on with the command 'M111 S32'.
 * NOTE: Requires a lot of PROGMEM!
//#define DEBUG_LEVELING_FEATURE
#if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_BILINEAR) || ENABLED(AUTO_BED_LEVELING_UBL)
  // Gradually reduce leveling correction until a set height is reached,
  // at which point movement will be level to the machine's XY plane.
  // The height can be set with M420 Z<height>
  #define ENABLE_LEVELING_FADE_HEIGHT
  // For Cartesian machines, instead of dividing moves on mesh boundaries,
  // split up moves into short segments like a Delta. This follows the
  // contours of the bed more closely than edge-to-edge straight moves.
  #define SEGMENT_LEVELED_MOVES
  #define LEVELED_SEGMENT_LENGTH 5.0 // (mm) Length of all segments (except the last one)
   * Enable the G26 Mesh Validation Pattern tool.
  //#define G26_MESH_VALIDATION
  #if ENABLED(G26_MESH_VALIDATION)
    #define MESH_TEST_NOZZLE_SIZE    0.4  // (mm) Diameter of primary nozzle.
    #define MESH_TEST_LAYER_HEIGHT   0.2  // (mm) Default layer height for the G26 Mesh Validation Tool.
    #define MESH_TEST_HOTEND_TEMP  205.0  // (°C) Default nozzle temperature for the G26 Mesh Validation Tool.
    #define MESH_TEST_BED_TEMP      60.0  // (°C) Default bed temperature for the G26 Mesh Validation Tool.
  #endif
#endif
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
  // Set the number of grid points per dimension.
  #define GRID_MAX_POINTS_X 3
  #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
  // Set the boundaries for probing (where the probe can reach).
  //#define LEFT_PROBE_BED_POSITION MIN_PROBE_EDGE
  //#define RIGHT_PROBE_BED_POSITION (X_BED_SIZE - MIN_PROBE_EDGE)
  //#define FRONT_PROBE_BED_POSITION MIN_PROBE_EDGE
  //#define BACK_PROBE_BED_POSITION (Y_BED_SIZE - MIN_PROBE_EDGE)
  // Probe along the Y axis, advancing X after each column
  //#define PROBE_Y_FIRST
  #if ENABLED(AUTO_BED_LEVELING_BILINEAR)
    // Beyond the probed grid, continue the implied tilt?
    // Default is to maintain the height of the nearest edge.
    //#define EXTRAPOLATE_BEYOND_GRID
    // Experimental Subdivision of the grid by Catmull-Rom method.
    // Synthesizes intermediate points to produce a more detailed mesh.
    //#define ABL_BILINEAR_SUBDIVISION
    #if ENABLED(ABL_BILINEAR_SUBDIVISION)
      // Number of subdivisions between probe points
      #define BILINEAR_SUBDIVISIONS 3
    #endif
  #endif
#elif ENABLED(AUTO_BED_LEVELING_UBL)
  //========================= Unified Bed Leveling ============================
  //#define MESH_EDIT_GFX_OVERLAY   // Display a graphics overlay while editing the mesh
  #define MESH_INSET 1              // Set Mesh bounds as an inset region of the bed
  #define GRID_MAX_POINTS_X 10      // Don't use more than 15 points per axis, implementation limited.
  #define UBL_MESH_EDIT_MOVES_Z     // Sophisticated users prefer no movement of nozzle
  #define UBL_SAVE_ACTIVE_ON_M500   // Save the currently active mesh in the current slot on M500
  //#define UBL_Z_RAISE_WHEN_OFF_MESH 2.5 // When the nozzle is off the mesh, this value is used
                                          // as the Z-Height correction value.
#elif ENABLED(MESH_BED_LEVELING)
  //=================================== Mesh ==================================
  #define MESH_INSET 10          // Set Mesh bounds as an inset region of the bed
  #define GRID_MAX_POINTS_X 3    // Don't use more than 7 points per axis, implementation limited.
  //#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest Z at Z_MIN_POS
#endif // BED_LEVELING
 * Points to probe for all 3-point Leveling procedures.
 * Override if the automatically selected points are inadequate.
#if ENABLED(AUTO_BED_LEVELING_3POINT) || ENABLED(AUTO_BED_LEVELING_UBL)
  #define PROBE_PT_1_X 15
  #define PROBE_PT_1_Y 180
  #define PROBE_PT_2_X 15
  #define PROBE_PT_2_Y 20
  #define PROBE_PT_3_X 170
  #define PROBE_PT_3_Y 20
#endif
 * Add a bed leveling sub-menu for ABL or MBL.
 * Include a guided procedure if manual probing is enabled.
//#define LCD_BED_LEVELING
#if ENABLED(LCD_BED_LEVELING)
  #define MBL_Z_STEP 0.025    // Step size while manually probing Z axis.
  #define LCD_PROBE_Z_RANGE 4 // Z Range centered on Z_MIN_POS for LCD Z adjustment
#endif
// Add a menu item to move between bed corners for manual bed adjustment
//#define LEVEL_BED_CORNERS
#if ENABLED(LEVEL_BED_CORNERS)
  #define LEVEL_CORNERS_INSET 30    // (mm) An inset for corner leveling
  //#define LEVEL_CENTER_TOO        // Move to the center after the last corner
#endif
 * Commands to execute at the end of G29 probing.
 * Useful to retract or move the Z probe out of the way.
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10"
// @section homing
// The center of the bed is at (X=0, Y=0)
//#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
//#define MANUAL_Z_HOME_POS 0
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
  #define Z_SAFE_HOMING_X_POINT ((X_BED_SIZE) / 2)    // X point for Z homing when homing all axes (G28).
  #define Z_SAFE_HOMING_Y_POINT ((Y_BED_SIZE) / 2)    // Y point for Z homing when homing all axes (G28).
#endif
// Homing speeds (mm/m)
#define HOMING_FEEDRATE_XY (50*60)
#define HOMING_FEEDRATE_Z  (4*60)
 * Bed Skew Compensation
 * This feature corrects for misalignment in the XYZ axes.
 * Take the following steps to get the bed skew in the XY plane:
 *  1. Print a test square (e.g., https://www.thingiverse.com/thing:2563185)
 *  2. For XY_DIAG_AC measure the diagonal A to C
 *  3. For XY_DIAG_BD measure the diagonal B to D
 *  4. For XY_SIDE_AD measure the edge A to D
 * Marlin automatically computes skew factors from these measurements.
 * Skew factors may also be computed and set manually:
 *  - Compute AB     : SQRT(2*AC*AC+2*BD*BD-4*AD*AD)/2
 *  - XY_SKEW_FACTOR : TAN(PI/2-ACOS((AC*AC-AB*AB-AD*AD)/(2*AB*AD)))
 * If desired, follow the same procedure for XZ and YZ.
 * Use these diagrams for reference:
 *    Y                     Z                     Z
 *    ^     B-------C       ^     B-------C       ^     B-------C
 *    |  A-------D          |  A-------D          |  A-------D
 *    +-------------->X     +-------------->X     +-------------->Y
 *     XY_SKEW_FACTOR        XZ_SKEW_FACTOR        YZ_SKEW_FACTOR
//#define SKEW_CORRECTION
#if ENABLED(SKEW_CORRECTION)
  // Input all length measurements here:
  #define XY_DIAG_AC 282.8427124746
  #define XY_DIAG_BD 282.8427124746
  #define XY_SIDE_AD 200
  // Or, set the default skew factors directly here
  // to override the above measurements:
  #define XY_SKEW_FACTOR 0.0
  //#define SKEW_CORRECTION_FOR_Z
  #if ENABLED(SKEW_CORRECTION_FOR_Z)
    #define XZ_DIAG_AC 282.8427124746
    #define XZ_DIAG_BD 282.8427124746
    #define YZ_DIAG_AC 282.8427124746
    #define YZ_DIAG_BD 282.8427124746
    #define YZ_SIDE_AD 200
    #define XZ_SKEW_FACTOR 0.0
    #define YZ_SKEW_FACTOR 0.0
  #endif
  // Enable this option for M852 to set skew at runtime
  //#define SKEW_CORRECTION_GCODE
#endif
//============================= Additional Features ===========================
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings".  You still need to store them in EEPROM afterwards if you want to.
//#define EEPROM_SETTINGS // Enable for M500 and M501 commands
//#define DISABLE_M503    // Saves ~2700 bytes of PROGMEM. Disable for release!
#define EEPROM_CHITCHAT   // Give feedback on EEPROM commands. Disable to save PROGMEM.
// Host Keepalive
// When enabled Marlin will send a busy status message to the host
// every couple of seconds when it can't accept commands.
#define HOST_KEEPALIVE_FEATURE        // Disable this if your host doesn't like keepalive messages
#define DEFAULT_KEEPALIVE_INTERVAL 2  // Number of seconds between "busy" messages. Set with M113.
#define BUSY_WHILE_HEATING            // Some hosts require "busy" messages even during heating
// M100 Free Memory Watcher
//#define M100_FREE_MEMORY_WATCHER    // Add M100 (Free Memory Watcher) to debug memory usage
// G20/G21 Inch mode support
//#define INCH_MODE_SUPPORT
// M149 Set temperature units support
//#define TEMPERATURE_UNITS_SUPPORT
// Preheat Constants
#define PREHEAT_1_TEMP_HOTEND 180
#define PREHEAT_1_TEMP_BED     70
#define PREHEAT_1_FAN_SPEED     0 // Value from 0 to 255
#define PREHEAT_2_TEMP_HOTEND 240
#define PREHEAT_2_TEMP_BED    110
#define PREHEAT_2_FAN_SPEED     0 // Value from 0 to 255
 * Nozzle Park
 * Park the nozzle at the given XYZ position on idle or G27.
 * The "P" parameter controls the action applied to the Z axis:
 *    P0  (Default) If Z is below park Z raise the nozzle.
 *    P1  Raise the nozzle always to Z-park height.
 *    P2  Raise the nozzle by Z-park amount, limited to Z_MAX_POS.
//#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
  // Specify a park position as { X, Y, Z }
  #define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
  #define NOZZLE_PARK_XY_FEEDRATE 100   // X and Y axes feedrate in mm/s (also used for delta printers Z axis)
  #define NOZZLE_PARK_Z_FEEDRATE 5      // Z axis feedrate in mm/s (not used for delta printers)
#endif
 * Clean Nozzle Feature -- EXPERIMENTAL
 * Adds the G12 command to perform a nozzle cleaning process.
 * Parameters:
 *   P  Pattern
 *   S  Strokes / Repetitions
 *   T  Triangles (P1 only)
 * Patterns:
 *   P0  Straight line (default). This process requires a sponge type material
 *       at a fixed bed location. "S" specifies strokes (i.e. back-forth motions)
 *       between the start / end points.
 *   P1  Zig-zag pattern between (X0, Y0) and (X1, Y1), "T" specifies the
 *       number of zig-zag triangles to do. "S" defines the number of strokes.
 *       Zig-zags are done in whichever is the narrower dimension.
 *       For example, "G12 P1 S1 T3" will execute:
 *         |  (X0, Y1) |     /\        /\        /\     | (X1, Y1)
 *       A |           |   /    \    /    \    /    \   |
 *         |  (X0, Y0) | /        \/        \/        \ | (X1, Y0)
 *                       |________|_________|_________|
 *                           T1        T2        T3
 *   P2  Circular pattern with middle at NOZZLE_CLEAN_CIRCLE_MIDDLE.
 *       "R" specifies the radius. "S" specifies the stroke count.
 *       Before starting, the nozzle moves to NOZZLE_CLEAN_START_POINT.
 *   Caveats: The ending Z should be the same as starting Z.
 * Attention: EXPERIMENTAL. G-code arguments may change.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
  // Default number of pattern repetitions
  #define NOZZLE_CLEAN_STROKES  12
  // Default number of triangles
  #define NOZZLE_CLEAN_TRIANGLES  3
  // Specify positions as { X, Y, Z }
  #define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
  #define NOZZLE_CLEAN_END_POINT   {100, 60, (Z_MIN_POS + 1)}
  // Circular pattern radius
  #define NOZZLE_CLEAN_CIRCLE_RADIUS 6.5
  // Circular pattern circle fragments number
  #define NOZZLE_CLEAN_CIRCLE_FN 10
  // Middle point of circle
  #define NOZZLE_CLEAN_CIRCLE_MIDDLE NOZZLE_CLEAN_START_POINT
  // Moves the nozzle to the initial position
  #define NOZZLE_CLEAN_GOBACK
#endif
 * Print Job Timer
 * Automatically start and stop the print job timer on M104/M109/M190.
 *   M104 (hotend, no wait) - high temp = none,        low temp = stop timer
 *   M109 (hotend, wait)    - high temp = start timer, low temp = stop timer
 *   M190 (bed, wait)       - high temp = start timer, low temp = none
 * The timer can also be controlled with the following commands:
 *   M75 - Start the print job timer
 *   M76 - Pause the print job timer
 *   M77 - Stop the print job timer
#define PRINTJOB_TIMER_AUTOSTART
 * Print Counter
 * Track statistical data such as:
 *  - Total print jobs
 *  - Total successful print jobs
 *  - Total failed print jobs
 *  - Total time printing
 * View the current statistics with M78.
//#define PRINTCOUNTER
//============================= LCD and SD support ============================
// @section lcd
 * LCD LANGUAGE
 * Select the language to display on the LCD. These languages are available:
 *    en, an, bg, ca, cn, cz, cz_utf8, de, el, el-gr, es, es_utf8,
 *    eu, fi, fr, fr_utf8, gl, hr, it, kana, kana_utf8, nl, pl, pt,
 *    pt_utf8, pt-br, pt-br_utf8, ru, sk_utf8, tr, uk, zh_CN, zh_TW, test
 * :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cn':'Chinese', 'cz':'Czech', 'cz_utf8':'Czech (UTF8)', 'de':'German', 'el':'Greek', 'el-gr':'Greek (Greece)', 'es':'Spanish', 'es_utf8':'Spanish (UTF8)', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'fr_utf8':'French (UTF8)', 'gl':'Galician', 'hr':'Croatian', 'it':'Italian', 'kana':'Japanese', 'kana_utf8':'Japanese (UTF8)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt-br':'Portuguese (Brazilian)', 'pt-br_utf8':'Portuguese (Brazilian UTF8)', 'pt_utf8':'Portuguese (UTF8)', 'ru':'Russian', 'sk_utf8':'Slovak (UTF8)', 'tr':'Turkish', 'uk':'Ukrainian', 'zh_CN':'Chinese (Simplified)', 'zh_TW':'Chinese (Taiwan)', 'test':'TEST' }
#define LCD_LANGUAGE fr
 * LCD Character Set
 * Note: This option is NOT applicable to Graphical Displays.
 * All character-based LCDs provide ASCII plus one of these
 * language extensions:
 *  - JAPANESE ... the most common
 *  - WESTERN  ... with more accented characters
 *  - CYRILLIC ... for the Russian language
 * To determine the language extension installed on your controller:
 *  - Compile and upload with LCD_LANGUAGE set to 'test'
 *  - Click the controller to view the LCD menu
 *  - The LCD will display Japanese, Western, or Cyrillic text
 * See http://marlinfw.org/docs/development/lcd_language.html
 * :['JAPANESE', 'WESTERN', 'CYRILLIC']
#define DISPLAY_CHARSET_HD44780 JAPANESE
 * SD CARD
 * SD Card support is disabled by default. If your controller has an SD slot,
 * you must uncomment the following option or it won't work.
#define SDSUPPORT
 * SD CARD: SPI SPEED
 * Enable one of the following items for a slower SPI transfer speed.
 * This may be required to resolve "volume init" errors.
//#define SPI_SPEED SPI_HALF_SPEED
//#define SPI_SPEED SPI_QUARTER_SPEED
//#define SPI_SPEED SPI_EIGHTH_SPEED
 * SD CARD: ENABLE CRC
 * Use CRC checks and retries on the SD communication.
#define SD_CHECK_AND_RETRY
 * LCD Menu Items
 * Disable all menus and only display the Status Screen, or
 * just remove some extraneous menu items to recover space.
#define NO_LCD_MENUS
//#define SLIM_LCD_MENUS
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
//#define ENCODER_PULSES_PER_STEP 4
// Use this option to override the number of step signals required to
// move between next/prev menu items.
//#define ENCODER_STEPS_PER_MENU_ITEM 1
 * Encoder Direction Options
 * Test your encoder's behavior first with both options disabled.
 *  Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
 *  Reversed Menu Navigation only?    Enable REVERSE_MENU_DIRECTION.
 *  Reversed Value Editing only?      Enable BOTH options.
// This option reverses the encoder direction everywhere.
//  Set this option if CLOCKWISE causes values to DECREASE
//#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
//  If CLOCKWISE normally moves DOWN this makes it go UP.
//  If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
//#define INDIVIDUAL_AXIS_HOMING_MENU
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
//#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
//  M300 S<frequency Hz> P<duration ms>
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 2
//#define LCD_FEEDBACK_FREQUENCY_HZ 5000
//======================== LCD / Controller Selection =========================
//========================   (Character-based LCDs)   =========================
// RepRapDiscount Smart Controller.
// http://reprap.org/wiki/RepRapDiscount_Smart_Controller
// Note: Usually sold with a white PCB.
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// http://reprap.org/wiki/PanelOne
//#define PANEL_ONE
// GADGETS3D G3D LCD/SD Controller
// http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RigidBot Panel V1.0
// http://www.inventapart.com/
//#define RIGIDBOT_PANEL
// Makeboard 3D Printer Parts 3D Printer Mini Display 1602 Mini Controller
// https://www.aliexpress.com/item/Micromake-Makeboard-3D-Printer-Parts-3D-Printer-Mini-Display-1602-Mini-Controller-Compatible-with-Ramps-1/32765887917.html
//#define MAKEBOARD_MINI_2_LINE_DISPLAY_1602
// ANET and Tronxy 20x4 Controller
//#define ZONESTAR_LCD            // Requires ADC_KEYPAD_PIN to be assigned to an analog pin.
                                  // This LCD is known to be susceptible to electrical interference
                                  // which scrambles the display.  Pressing any button clears it up.
                                  // This is a LCD2004 display with 5 analog buttons.
// Generic 16x2, 16x4, 20x2, or 20x4 character-based LCD.
//#define ULTRA_LCD
//=====================   (I2C and Shift-Register LCDs)   =====================
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: https://github.com/kiyoshigawa/LiquidCrystal_I2C
// Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
//#define RA_CONTROL_PANEL
// Sainsmart (YwRobot) LCD Displays
// These require F.Malpartida's LiquidCrystal_I2C library
// https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
//#define LCD_SAINSMART_I2C_1602
//#define LCD_SAINSMART_I2C_2004
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: https://github.com/lincomatic/LiquidTWI2
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from https://goo.gl/aJJ4sH
// LCD configuration: http://reprap.org/wiki/SAV_3D_LCD
//#define SAV_3DLCD
//=======================   LCD / Controller Selection  =======================
//=========================      (Graphical LCDs)      ========================
// CONTROLLER TYPE: Graphical 128x64 (DOGM)
// IMPORTANT: The U8glib library is required for Graphical Display!
//            https://github.com/olikraus/U8glib_Arduino
// RepRapDiscount FULL GRAPHIC Smart Controller
// http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// ReprapWorld Graphical LCD
// https://reprapworld.com/?products_details&products_id/1218
//#define REPRAPWORLD_GRAPHICAL_LCD
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// http://panucatt.com
//#define VIKI2
//#define miniVIKI
// MakerLab Mini Panel with graphic
// controller and SD support - http://reprap.org/wiki/Mini_panel
//#define MINIPANEL
// MaKr3d Makr-Panel with graphic controller and SD support.
// http://reprap.org/wiki/MaKr3d_MaKrPanel
//#define MAKRPANEL
// Adafruit ST7565 Full Graphic Controller.
// https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/
//#define ELB_FULL_GRAPHIC_CONTROLLER
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// Cartesio UI
// http://mauk.cc/webshop/cartesio-shop/electronics/user-interface
//#define CARTESIO_UI
// LCD for Melzi Card with Graphical LCD
//#define LCD_FOR_MELZI
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
//#define SAV_3DGLCD
#if ENABLED(SAV_3DGLCD)
  #define U8GLIB_SH1106
#endif
// Original Ulticontroller from Ultimaker 2 printer with SSD1309 I2C display and encoder
// https://github.com/Ultimaker/Ultimaker2/tree/master/1249_Ulticontroller_Board_(x1)
//#define ULTI_CONTROLLER
// TinyBoy2 128x64 OLED / Encoder Panel
//#define OLED_PANEL_TINYBOY2
// MKS MINI12864 with graphic controller and SD support
// http://reprap.org/wiki/MKS_MINI_12864
//#define MKS_MINI_12864
// Factory display for Creality CR-10
// https://www.aliexpress.com/item/Universal-LCD-12864-3D-Printer-Display-Screen-With-Encoder-For-CR-10-CR-7-Model/32833148327.html
// This is RAMPS-compatible using a single 10-pin connector.
// (For CR-10 owners who want to replace the Melzi Creality board but retain the display)
//#define CR10_STOCKDISPLAY
// ANET and Tronxy Graphical Controller
//#define ANET_FULL_GRAPHICS_LCD  // Anet 128x64 full graphics lcd with rotary encoder as used on Anet A6
                                  // A clone of the RepRapDiscount full graphics display but with
                                  // different pins/wiring (see pins_ANET_10.h).
// MKS OLED 1.3" 128 × 64 FULL GRAPHICS CONTROLLER
// http://reprap.org/wiki/MKS_12864OLED
// Tiny, but very sharp OLED display
//#define MKS_12864OLED          // Uses the SH1106 controller (default)
//#define MKS_12864OLED_SSD1306  // Uses the SSD1306 controller
// Silvergate GLCD controller
// http://github.com/android444/Silvergate
//#define SILVER_GATE_GLCD_CONTROLLER
//============================  Other Controllers  ============================
// CONTROLLER TYPE: Standalone / Serial
// LCD for Malyan M200 printers.
// This requires SDSUPPORT to be enabled
//#define MALYAN_LCD
// CONTROLLER TYPE: Keypad / Add-on
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0
//=============================== Extra Features ==============================
// @section extras
// Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// If SOFT_PWM_SCALE is set to a value higher than 0, dithering can
// be used to mitigate the associated resolution loss. If enabled,
// some of the PWM cycles are stretched so on average the desired
// duty cycle is attained.
//#define SOFT_PWM_DITHER
// Temperature status LEDs that display the hotend and bed temperature.
// If all hotends, bed temperature, and target temperature are under 54C
// then the BLUE led is on. Otherwise the RED led is on. (1C hysteresis)
//#define TEMP_STAT_LEDS
// M240  Triggers a camera by emulating a Canon RC-1 Remote
// Data from: http://www.doc-diy.net/photo/rc-1_hacked/
//#define PHOTOGRAPH_PIN     23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder
//#define BARICUDA
// Support for BlinkM/CyzRgb
//#define BLINKM
// Support for PCA9632 PWM LED driver
//#define PCA9632
 * RGB LED / LED Strip Control
 * Enable support for an RGB LED connected to 5V digital pins, or
 * an RGB Strip connected to MOSFETs controlled by digital pins.
 * Adds the M150 command to set the LED (or LED strip) color.
 * If pins are PWM capable (e.g., 4, 5, 6, 11) then a range of
 * luminance values can be set from 0 to 255.
 * For Neopixel LED an overall brightness parameter is also available.
 * *** CAUTION ***
 *  LED Strips require a MOSFET Chip between PWM lines and LEDs,
 *  as the Arduino cannot handle the current the LEDs will require.
 *  Failure to follow this precaution can destroy your Arduino!
 *  NOTE: A separate 5V power supply is required! The Neopixel LED needs
 *  more current than the Arduino 5V linear regulator can produce.
 * *** CAUTION ***
 * LED Type. Enable only one of the following two options.
//#define RGB_LED
//#define RGBW_LED
#if ENABLED(RGB_LED) || ENABLED(RGBW_LED)
  #define RGB_LED_R_PIN 34
  #define RGB_LED_G_PIN 43
  #define RGB_LED_B_PIN 35
  #define RGB_LED_W_PIN -1
#endif
// Support for Adafruit Neopixel LED driver
//#define NEOPIXEL_LED
#if ENABLED(NEOPIXEL_LED)
  #define NEOPIXEL_TYPE   NEO_GRBW // NEO_GRBW / NEO_GRB - four/three channel driver type (defined in Adafruit_NeoPixel.h)
  #define NEOPIXEL_PIN    4        // LED driving pin on motherboard 4 => D4 (EXP2-5 on Printrboard) / 30 => PC7 (EXP3-13 on Rumba)
  #define NEOPIXEL_PIXELS 30       // Number of LEDs in the strip
  #define NEOPIXEL_IS_SEQUENTIAL   // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once.
  #define NEOPIXEL_BRIGHTNESS 127  // Initial brightness (0-255)
  //#define NEOPIXEL_STARTUP_TEST  // Cycle through colors at startup
#endif
 * Printer Event LEDs
 * During printing, the LEDs will reflect the printer status:
 *  - Gradually change from blue to violet as the heated bed gets to target temp
 *  - Gradually change from violet to red as the hotend gets to temperature
 *  - Change to white to illuminate work surface
 *  - Change to green once print has finished
 *  - Turn off after the print has finished and the user has pushed a button
#if ENABLED(BLINKM) || ENABLED(RGB_LED) || ENABLED(RGBW_LED) || ENABLED(PCA9632) || ENABLED(NEOPIXEL_LED)
  #define PRINTER_EVENT_LEDS
#endif
 * R/C SERVO support
 * Sponsored by TrinityLabs, Reworked by codexmas
 * Number of servos
 * For some servo-related options NUM_SERVOS will be set automatically.
 * Set this manually if there are extra servos needing manual control.
 * Leave undefined or set to 0 to entirely disable the servo subsystem.
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Delay (in milliseconds) before the next move will start, to give the servo time to reach its target angle.
// 300ms is a good value but you can try less delay.
// If the servo can't reach the requested position, increase it.
#define SERVO_DELAY { 300 }
// Only power servos during movement, otherwise leave off to prevent jitter
//#define DEACTIVATE_SERVOS_AFTER_MOVE
#endif // CONFIGURATION_H
configuration adv:
 * Marlin 3D Printer Firmware
 * Copyright (C) 2016 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
 * Based on Sprinter and grbl.
 * Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
 * Configuration_adv.h
 * Advanced settings.
 * Only change these if you know exactly what you're doing.
 * Some of these settings can damage your printer if improperly set!
 * Basic settings can be found in Configuration.h
#ifndef CONFIGURATION_ADV_H
#define CONFIGURATION_ADV_H
#define CONFIGURATION_ADV_H_VERSION 010109
//=============================Thermal Settings  ============================
// Hephestos 2 24V heated bed upgrade kit.
// https://store.bq.com/en/heated-bed-kit-hephestos2
//#define HEPHESTOS2_HEATED_BED_KIT
#if ENABLED(HEPHESTOS2_HEATED_BED_KIT)
  #undef TEMP_SENSOR_BED
  #define TEMP_SENSOR_BED 70
  #define HEATER_BED_INVERTING true
#endif
#if DISABLED(PIDTEMPBED)
  #define BED_CHECK_INTERVAL 5000 // ms between checks in bang-bang control
  #if ENABLED(BED_LIMIT_SWITCHING)
    #define BED_HYSTERESIS 2 // Only disable heating if T>target+BED_HYSTERESIS and enable heating if T>target-BED_HYSTERESIS
  #endif
#endif
 * the heater on.
 * The solution: Once the temperature reaches the target, start observing.
 * If the temperature stays too far below the target (hysteresis) for too
 * long (period), the firmware will halt the machine as a safety precaution.
 * If you get false positives for "Thermal Runaway", increase
 * THERMAL_PROTECTION_HYSTERESIS and/or THERMAL_PROTECTION_PERIOD
#if ENABLED(THERMAL_PROTECTION_HOTENDS)
  #define THERMAL_PROTECTION_PERIOD 40        // Seconds
  #define THERMAL_PROTECTION_HYSTERESIS 4     // Degrees Celsius
   * Whenever an M104, M109, or M303 increases the target temperature, the
   * firmware will wait for the WATCH_TEMP_PERIOD to expire. If the temperature
   * hasn't increased by WATCH_TEMP_INCREASE degrees, the machine is halted and
   * requires a hard reset. This test restarts with any M104/M109/M303, but only
   * if the current temperature is far enough below the target for a reliable
   * test.
   * If you get false positives for "Heating failed", increase WATCH_TEMP_PERIOD
   * and/or decrease WATCH_TEMP_INCREASE. WATCH_TEMP_INCREASE should not be set
   * below 2.
  #define WATCH_TEMP_PERIOD 20                // Seconds
  #define WATCH_TEMP_INCREASE 2               // Degrees Celsius
#endif
 * Thermal Protection parameters for the bed are just as above for hotends.
#if ENABLED(THERMAL_PROTECTION_BED)
  #define THERMAL_PROTECTION_BED_PERIOD 20    // Seconds
  #define THERMAL_PROTECTION_BED_HYSTERESIS 2 // Degrees Celsius
   * As described above, except for the bed (M140/M190/M303).
  #define WATCH_BED_TEMP_PERIOD 60                // Seconds
  #define WATCH_BED_TEMP_INCREASE 2               // Degrees Celsius
#endif
  // this adds an experimental additional term to the heating power, proportional to the extrusion speed.
  // if Kc is chosen well, the additional required power due to increased melting should be compensated.
  //#define PID_EXTRUSION_SCALING
  #if ENABLED(PID_EXTRUSION_SCALING)
    #define DEFAULT_Kc (100) //heating power=Kc*(e_speed)
    #define LPQ_MAX_LEN 50
  #endif
#endif
 * Automatic Temperature:
 * The hotend target temperature is calculated by all the buffered lines of gcode.
 * The maximum buffered steps/sec of the extruder motor is called "se".
 * Start autotemp mode with M109 S<mintemp> B<maxtemp> F<factor>
 * The target temperature is set to mintemp+factor*se[steps/sec] and is limited by
 * mintemp and maxtemp. Turn this off by executing M109 without F*
 * Also, if the temperature is set to a value below mintemp, it will not be changed by autotemp.
 * On an Ultimaker, some initial testing worked with M109 S215 B260 F1 in the start.gcode
#define AUTOTEMP
#if ENABLED(AUTOTEMP)
  #define AUTOTEMP_OLDWEIGHT 0.98
#endif
// Show extra position information in M114
//#define M114_DETAIL
// Show Temperature ADC value
// Enable for M105 to include ADC values read from temperature sensors.
//#define SHOW_TEMP_ADC_VALUES
 * High Temperature Thermistor Support
 * Thermistors able to support high temperature tend to have a hard time getting
 * good readings at room and lower temperatures. This means HEATER_X_RAW_LO_TEMP
 * will probably be caught when the heating element first turns on during the
 * preheating process, which will trigger a min_temp_error as a safety measure
 * and force stop everything.
 * To circumvent this limitation, we allow for a preheat time (during which,
 * min_temp_error won't be triggered) and add a min_temp buffer to handle
 * aberrant readings.
 * If you want to enable this feature for your hotend thermistor(s)
 * uncomment and set values > 0 in the constants below
// The number of consecutive low temperature errors that can occur
// before a min_temp_error is triggered. (Shouldn't be more than 10.)
//#define MAX_CONSECUTIVE_LOW_TEMPERATURE_ERROR_ALLOWED 0
// The number of milliseconds a hotend will preheat before starting to check
// the temperature. This value should NOT be set to the time it takes the
// hot end to reach the target temperature, but the time it takes to reach
// the minimum temperature your thermistor can read. The lower the better/safer.
// This shouldn't need to be more than 30 seconds (30000)
//#define MILLISECONDS_PREHEAT_TIME 0
// @section extruder
// Extruder runout prevention.
// If the machine is idle and the temperature over MINTEMP
// then extrude some filament every couple of SECONDS.
//#define EXTRUDER_RUNOUT_PREVENT
#if ENABLED(EXTRUDER_RUNOUT_PREVENT)
  #define EXTRUDER_RUNOUT_MINTEMP 190
  #define EXTRUDER_RUNOUT_SECONDS 30
  #define EXTRUDER_RUNOUT_SPEED 1500  // mm/m
  #define EXTRUDER_RUNOUT_EXTRUDE 5   // mm
#endif
// @section temperature
// Calibration for AD595 / AD8495 sensor to adjust temperature measurements.
// The final temperature is calculated as (measuredTemp * GAIN) + OFFSET.
#define TEMP_SENSOR_AD595_OFFSET  0.0
#define TEMP_SENSOR_AD595_GAIN    1.0
#define TEMP_SENSOR_AD8495_OFFSET 0.0
#define TEMP_SENSOR_AD8495_GAIN   1.0
 * Controller Fan
 * To cool down the stepper drivers and MOSFETs.
 * The fan will turn on automatically whenever any stepper is enabled
 * and turn off after a set period after all steppers are turned off.
//#define USE_CONTROLLER_FAN
#if ENABLED(USE_CONTROLLER_FAN)
  //#define CONTROLLER_FAN_PIN -1        // Set a custom pin for the controller fan
  #define CONTROLLERFAN_SECS 60          // Duration in seconds for the fan to run after all motors are disabled
  #define CONTROLLERFAN_SPEED 255        // 255 == full speed
#endif
// When first starting the main fan, run it at full speed for the
// given number of milliseconds.  This gets the fan spinning reliably
// before setting a PWM value. (Does not work with software PWM for fan on Sanguinololu)
//#define FAN_KICKSTART_TIME 100
 * PWM Fan Scaling
 * Define the min/max speeds for PWM fans (as set with M106).
 * With these options the M106 0-255 value range is scaled to a subset
 * to ensure that the fan has enough power to spin, or to run lower
 * current fans with higher current. (e.g., 5V/12V fans with 12V/24V)
 * Value 0 always turns off the fan.
 * Define one or both of these to override the default 0-255 range.
//#define FAN_MIN_PWM 50
//#define FAN_MAX_PWM 128
 * Extruder cooling fans
 * Extruder auto fans automatically turn on when their extruders'
 * temperatures go above EXTRUDER_AUTO_FAN_TEMPERATURE.
 * Your board's pins file specifies the recommended pins. Override those here
 * or set to -1 to disable completely.
 * Multiple extruders can be assigned to the same pin in which case
 * the fan will turn on when any selected extruder is above the threshold.
#define E0_AUTO_FAN_PIN -1
#define E1_AUTO_FAN_PIN -1
#define E2_AUTO_FAN_PIN -1
#define E3_AUTO_FAN_PIN -1
#define E4_AUTO_FAN_PIN -1
#define CHAMBER_AUTO_FAN_PIN -1
#define EXTRUDER_AUTO_FAN_TEMPERATURE 50
#define EXTRUDER_AUTO_FAN_SPEED   255  // == full speed
 * Part-Cooling Fan Multiplexer
 * This feature allows you to digitally multiplex the fan output.
 * The multiplexer is automatically switched at tool-change.
 * Set FANMUX[012]_PINs below for up to 2, 4, or 8 multiplexed fans.
#define FANMUX0_PIN -1
#define FANMUX1_PIN -1
#define FANMUX2_PIN -1
 * M355 Case Light on-off / brightness
//#define CASE_LIGHT_ENABLE
#if ENABLED(CASE_LIGHT_ENABLE)
  //#define CASE_LIGHT_PIN 4                  // Override the default pin if needed
  #define INVERT_CASE_LIGHT false             // Set true if Case Light is ON when pin is LOW
  #define CASE_LIGHT_DEFAULT_ON true          // Set default power-up state on
  #define CASE_LIGHT_DEFAULT_BRIGHTNESS 105   // Set default power-up brightness (0-255, requires PWM pin)
  //#define MENU_ITEM_CASE_LIGHT              // Add a Case Light option to the LCD main menu
  //#define CASE_LIGHT_USE_NEOPIXEL           // Use Neopixel LED as case light, requires NEOPIXEL_LED.
  #if ENABLED(CASE_LIGHT_USE_NEOPIXEL)
    #define CASE_LIGHT_NEOPIXEL_COLOR { 255, 255, 255, 255 } // { Red, Green, Blue, White }
  #endif
#endif
//============================ Mechanical Settings ==========================
// @section homing
// If you want endstops to stay on (by default) even when not homing
// enable this option. Override at any time with M120, M121.
//#define ENDSTOPS_ALWAYS_ON_DEFAULT
// @section extras
//#define Z_LATE_ENABLE // Enable Z the last moment. Needed if your Z driver overheats.
 * Dual Steppers / Dual Endstops
 * This section will allow you to use extra E drivers to drive a second motor for X, Y, or Z axes.
 * For example, set X_DUAL_STEPPER_DRIVERS setting to use a second motor. If the motors need to
 * spin in opposite directions set INVERT_X2_VS_X_DIR. If the second motor needs its own endstop
 * set X_DUAL_ENDSTOPS. This can adjust for "racking." Use X2_USE_ENDSTOP to set the endstop plug
 * that should be used for the second endstop. Extra endstops will appear in the output of 'M119'.
 * Use X_DUAL_ENDSTOP_ADJUSTMENT to adjust for mechanical imperfection. After homing both motors
 * this offset is applied to the X2 motor. To find the offset home the X axis, and measure the error
 * in X2. Dual endstop offsets can be set at runtime with 'M666 X<offset> Y<offset> Z<offset>'.
//#define X_DUAL_STEPPER_DRIVERS
#if ENABLED(X_DUAL_STEPPER_DRIVERS)
  #define INVERT_X2_VS_X_DIR true   // Set 'true' if X motors should rotate in opposite directions
  //#define X_DUAL_ENDSTOPS
  #if ENABLED(X_DUAL_ENDSTOPS)
    #define X2_USE_ENDSTOP _XMAX_
    #define X_DUAL_ENDSTOPS_ADJUSTMENT  0
  #endif
#endif
//#define Y_DUAL_STEPPER_DRIVERS
#if ENABLED(Y_DUAL_STEPPER_DRIVERS)
  #define INVERT_Y2_VS_Y_DIR true   // Set 'true' if Y motors should rotate in opposite directions
  //#define Y_DUAL_ENDSTOPS
  #if ENABLED(Y_DUAL_ENDSTOPS)
    #define Y2_USE_ENDSTOP _YMAX_
    #define Y_DUAL_ENDSTOPS_ADJUSTMENT  0
  #endif
#endif
#define Z_DUAL_STEPPER_DRIVERS
#if ENABLED(Z_DUAL_STEPPER_DRIVERS)
  //#define Z_DUAL_ENDSTOPS
  #if ENABLED(Z_DUAL_ENDSTOPS)
    #define Z2_USE_ENDSTOP _XMAX_
    #define Z_DUAL_ENDSTOPS_ADJUSTMENT  0
  #endif
#endif
 * Dual X Carriage
 * This setup has two X carriages that can move independently, each with its own hotend.
 * The carriages can be used to print an object with two colors or materials, or in
 * "duplication mode" it can print two identical or X-mirrored objects simultaneously.
 * The inactive carriage is parked automatically to prevent oozing.
 * X1 is the left carriage, X2 the right. They park and home at opposite ends of the X axis.
 * By default the X2 stepper is assigned to the first unused E plug on the board.
//#define DUAL_X_CARRIAGE
#if ENABLED(DUAL_X_CARRIAGE)
  #define X1_MIN_POS X_MIN_POS  // set minimum to ensure first x-carriage doesn't hit the parked second X-carriage
  #define X1_MAX_POS X_BED_SIZE // set maximum to ensure first x-carriage doesn't hit the parked second X-carriage
  #define X2_MIN_POS 80     // set minimum to ensure second x-carriage doesn't hit the parked first X-carriage
  #define X2_MAX_POS 353    // set maximum to the distance between toolheads when both heads are homed
  #define X2_HOME_DIR 1     // the second X-carriage always homes to the maximum endstop position
  #define X2_HOME_POS X2_MAX_POS // default home position is the maximum carriage position
      // However: In this mode the HOTEND_OFFSET_X value for the second extruder provides a software
      // override for X2_HOME_POS. This also allow recalibration of the distance between the two endstops
      // without modifying the firmware (through the "M218 T1 X???" command).
      // Remember: you should set the second extruder x-offset to 0 in your slicer.
  // There are a few selectable movement modes for dual x-carriages using M605 S<mode>
  //    Mode 0 (DXC_FULL_CONTROL_MODE): Full control. The slicer has full control over both x-carriages and can achieve optimal travel results
  //                                    as long as it supports dual x-carriages. (M605 S0)
  //    Mode 1 (DXC_AUTO_PARK_MODE)   : Auto-park mode. The firmware will automatically park and unpark the x-carriages on tool changes so
  //                                    that additional slicer support is not required. (M605 S1)
  //    Mode 2 (DXC_DUPLICATION_MODE) : Duplication mode. The firmware will transparently make the second x-carriage and extruder copy all
  //                                    actions of the first x-carriage. This allows the printer to print 2 arbitrary items at
  //                                    once. (2nd extruder x offset and temp offset are set using: M605 S2 [Xnnn] [Rmmm])
  // This is the default power-up mode which can be later using M605.
  #define DEFAULT_DUAL_X_CARRIAGE_MODE DXC_FULL_CONTROL_MODE
  // Default settings in "Auto-park Mode"
  #define TOOLCHANGE_PARK_ZLIFT   0.2      // the distance to raise Z axis when parking an extruder
  #define TOOLCHANGE_UNPARK_ZLIFT 1        // the distance to raise Z axis when unparking an extruder
  // Default x offset in duplication mode (typically set to half print bed width)
  #define DEFAULT_DUPLICATION_X_OFFSET 100
#endif // DUAL_X_CARRIAGE
// Activate a solenoid on the active extruder with M380. Disable all with M381.
// Define SOL0_PIN, SOL1_PIN, etc., for each extruder that has a solenoid.
//#define EXT_SOLENOID
// @section homing
// Homing hits each endstop, retracts by these distances, then does a slower bump.
#define X_HOME_BUMP_MM 5
#define Y_HOME_BUMP_MM 5
#define Z_HOME_BUMP_MM 2
#define HOMING_BUMP_DIVISOR { 2, 2, 4 }  // Re-Bump Speed Divisor (Divides the Homing Feedrate)
//#define QUICK_HOME                     // If homing includes X and Y, do a diagonal move initially
// When G28 is called, this option will make Y home before X
//#define HOME_Y_BEFORE_X
// Enable this if X or Y can't home without homing the other axis first.
//#define CODEPENDENT_XY_HOMING
// @section machine
#define AXIS_RELATIVE_MODES {false, false, false, false}
// Allow duplication mode with a basic dual-nozzle extruder
//#define DUAL_NOZZLE_DUPLICATION_MODE
// By default pololu step drivers require an active high signal. However, some high power drivers require an active low signal as step.
#define INVERT_X_STEP_PIN false
#define INVERT_Y_STEP_PIN false
#define INVERT_Z_STEP_PIN false
#define INVERT_E_STEP_PIN false
// Default stepper release if idle. Set to 0 to deactivate.
// Steppers will shut down DEFAULT_STEPPER_DEACTIVE_TIME seconds after the last move when DISABLE_INACTIVE_? is true.
// Time can be set by M18 and M84.
#define DEFAULT_STEPPER_DEACTIVE_TIME 120
#define DISABLE_INACTIVE_X true
#define DISABLE_INACTIVE_Y true
#define DISABLE_INACTIVE_Z true  // set to false if the nozzle will fall down on your printed part when print has finished.
#define DISABLE_INACTIVE_E true
#define DEFAULT_MINIMUMFEEDRATE       0.0     // minimum feedrate
#define DEFAULT_MINTRAVELFEEDRATE     0.0
//#define HOME_AFTER_DEACTIVATE  // Require rehoming after steppers are deactivated
// @section lcd
#if ENABLED(ULTIPANEL)
  #define MANUAL_FEEDRATE {50*60, 50*60, 4*60, 60} // Feedrates for manual moves along X, Y, Z, E from panel
  #define ULTIPANEL_FEEDMULTIPLY  // Comment to disable setting feedrate multiplier via encoder
#endif
// @section extras
// minimum time in microseconds that a movement needs to take if the buffer is emptied.
#define DEFAULT_MINSEGMENTTIME        20000
// If defined the movements slow down when the look ahead buffer is only half full
#define SLOWDOWN
// Frequency limit
// See nophead's blog for more info
// Not working O
//#define XY_FREQUENCY_LIMIT  15
// Minimum planner junction speed. Sets the default minimum speed the planner plans for at the end
// of the buffer and all stops. This should not be much greater than zero and should only be changed
// if unwanted behavior is observed on a user's machine when running at very slow speeds.
#define MINIMUM_PLANNER_SPEED 0.05 // (mm/sec)
// Use Junction Deviation instead of traditional Jerk Limiting
//#define JUNCTION_DEVIATION
#if ENABLED(JUNCTION_DEVIATION)
  #define JUNCTION_DEVIATION_MM 0.02  // (mm) Distance from real junction edge
#endif
 * Adaptive Step Smoothing increases the resolution of multi-axis moves, particularly at step frequencies
 * below 1kHz (for AVR) or 10kHz (for ARM), where aliasing between axes in multi-axis moves causes audible
 * vibration and surface artifacts. The algorithm adapts to provide the best possible step smoothing at the
 * lowest stepping frequencies.
//#define ADAPTIVE_STEP_SMOOTHING
// Microstep setting (Only functional when stepper driver microstep pins are connected to MCU.
#define MICROSTEP_MODES { 16, 16, 16, 16, 16 } // [1,2,4,8,16]
 *  @section  stepper motor current
 *  Some boards have a means of setting the stepper motor current via firmware.
 *  The power on motor currents are set by:
 *    PWM_MOTOR_CURRENT - used by MINIRAMBO & ULTIMAIN_2
 *                         known compatible chips: A4982
 *    DIGIPOT_MOTOR_CURRENT - used by BQ_ZUM_MEGA_3D, RAMBO & SCOOVO_X9H
 *                         known compatible chips: AD5206
 *    DAC_MOTOR_CURRENT_DEFAULT - used by PRINTRBOARD_REVF & RIGIDBOARD_V2
 *                         known compatible chips: MCP4728
 *    DIGIPOT_I2C_MOTOR_CURRENTS - used by 5DPRINT, AZTEEG_X3_PRO, MIGHTYBOARD_REVE
 *                         known compatible chips: MCP4451, MCP4018
 *  Motor currents can also be set by M907 - M910 and by the LCD.
 *    M907 - applies to all.
 *    M908 - BQ_ZUM_MEGA_3D, RAMBO, PRINTRBOARD_REVF, RIGIDBOARD_V2 & SCOOVO_X9H
 *    M909, M910 & LCD - only PRINTRBOARD_REVF & RIGIDBOARD_V2
//#define PWM_MOTOR_CURRENT { 1300, 1300, 1250 }          // Values in milliamps
//#define DIGIPOT_MOTOR_CURRENT { 135,135,135,135,135 }   // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
//#define DAC_MOTOR_CURRENT_DEFAULT { 70, 80, 90, 80 }    // Default drive percent - X, Y, Z, E axis
// Use an I2C based DIGIPOT (e.g., Azteeg X3 Pro)
//#define DIGIPOT_I2C
#if ENABLED(DIGIPOT_I2C) && !defined(DIGIPOT_I2C_ADDRESS_A)
   * Common slave addresses:
   *                    A   (A shifted)   B   (B shifted)  IC
   * Smoothie          0x2C (0x58)       0x2D (0x5A)       MCP4451
   * AZTEEG_X3_PRO     0x2C (0x58)       0x2E (0x5C)       MCP4451
   * MIGHTYBOARD_REVE  0x2F (0x5E)                         MCP4018
  #define DIGIPOT_I2C_ADDRESS_A 0x2C  // unshifted slave address for first DIGIPOT
  #define DIGIPOT_I2C_ADDRESS_B 0x2D  // unshifted slave address for second DIGIPOT
#endif
//#define DIGIPOT_MCP4018          // Requires library from https://github.com/stawel/SlowSoftI2CMaster
#define DIGIPOT_I2C_NUM_CHANNELS 8 // 5DPRINT: 4     AZTEEG_X3_PRO: 8
// Actual motor currents in Amps. The number of entries must match DIGIPOT_I2C_NUM_CHANNELS.
// These correspond to the physical drivers, so be mindful if the order is changed.
#define DIGIPOT_I2C_MOTOR_CURRENTS { 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0 }  //  AZTEEG_X3_PRO
//=============================Additional Features===========================
#define ENCODER_RATE_MULTIPLIER         // If defined, certain menu edit operations automatically multiply the steps when the encoder is moved quickly
#define ENCODER_10X_STEPS_PER_SEC 75    // If the encoder steps per sec exceeds this value, multiply steps moved x10 to quickly advance the value
#define ENCODER_100X_STEPS_PER_SEC 160  // If the encoder steps per sec exceeds this value, multiply steps moved x100 to really quickly advance the value
//#define CHDK 4        //Pin for triggering CHDK to take a picture see how to use it here http://captain-slow.dk/2014/03/09/3d-printing-timelapses/
#define CHDK_DELAY 50 //How long in ms the pin should stay HIGH before going LOW again
// @section lcd
// Include a page of printer information in the LCD Main Menu
#define LCD_INFO_MENU
// Scroll a longer status message into view
//#define STATUS_MESSAGE_SCROLLING
// On the Info Screen, display XY with one decimal place when possible
//#define LCD_DECIMAL_SMALL_XY
// The timeout (in ms) to return to the status screen from sub-menus
//#define LCD_TIMEOUT_TO_STATUS 15000
// Add an 'M73' G-code to set the current percentage
//#define LCD_SET_PROGRESS_MANUALLY
#if ENABLED(SDSUPPORT) || ENABLED(LCD_SET_PROGRESS_MANUALLY)
  //#define LCD_PROGRESS_BAR              // Show a progress bar on HD44780 LCDs for SD printing
  #if ENABLED(LCD_PROGRESS_BAR)
    #define PROGRESS_BAR_BAR_TIME 2000    // (ms) Amount of time to show the bar
    #define PROGRESS_BAR_MSG_TIME 3000    // (ms) Amount of time to show the status message
    #define PROGRESS_MSG_EXPIRE   0       // (ms) Amount of time to retain the status message (0=forever)
    //#define PROGRESS_MSG_ONCE           // Show the message for MSG_TIME then clear it
    //#define LCD_PROGRESS_BAR_TEST       // Add a menu item to test the progress bar
  #endif
#endif // SDSUPPORT || LCD_SET_PROGRESS_MANUALLY
 * LED Control Menu
 * Enable this feature to add LED Control to the LCD menu
//#define LED_CONTROL_MENU
#if ENABLED(LED_CONTROL_MENU)
  #define LED_COLOR_PRESETS                 // Enable the Preset Color menu option
  #if ENABLED(LED_COLOR_PRESETS)
    #define LED_USER_PRESET_RED        255  // User defined RED value
    #define LED_USER_PRESET_GREEN      128  // User defined GREEN value
    #define LED_USER_PRESET_BLUE         0  // User defined BLUE value
    #define LED_USER_PRESET_WHITE      255  // User defined WHITE value
    #define LED_USER_PRESET_BRIGHTNESS 255  // User defined intensity
    //#define LED_USER_PRESET_STARTUP       // Have the printer display the user preset color on startup
  #endif
#endif // LED_CONTROL_MENU
  // Some RAMPS and other boards don't detect when an SD card is inserted. You can work
  // around this by connecting a push button or single throw switch to the pin defined
  // as SD_DETECT_PIN in your board's pins definitions.
  // This setting should be disabled unless you are using a push button, pulling the pin to ground.
  // Note: This is always disabled for ULTIPANEL (except ELB_FULL_GRAPHIC_CONTROLLER).
  #define SD_DETECT_INVERTED
  #define SD_FINISHED_STEPPERRELEASE true          // Disable steppers when SD Print is finished
  #define SD_FINISHED_RELEASECOMMAND "M84 X Y Z E" // You might want to keep the z enabled so your bed stays in place.
  // Reverse SD sort to show "more recent" files first, according to the card's FAT.
  // Since the FAT gets out of order with usage, SDCARD_SORT_ALPHA is recommended.
  #define SDCARD_RATHERRECENTFIRST
  // Add an option in the menu to run all auto#.g files
  //#define MENU_ADDAUTOSTART
   * Continue after Power-Loss (Creality3D)
   * Store the current state to the SD Card at the start of each layer
   * during SD printing. If the recovery file is found at boot time, present
   * an option on the LCD screen to continue the print from the last-known
   * point in the file.
  //#define POWER_LOSS_RECOVERY
  #if ENABLED(POWER_LOSS_RECOVERY)
    //#define POWER_LOSS_PIN   44     // Pin to detect power loss
    //#define POWER_LOSS_STATE HIGH   // State of pin indicating power loss
  #endif
   * Sort SD file listings in alphabetical order.
   * With this option enabled, items on SD cards will be sorted
   * by name for easier navigation.
   * By default...
   *  - Use the slowest -but safest- method for sorting.
   *  - Folders are sorted to the top.
   *  - The sort key is statically allocated.
   *  - No added G-code (M34) support.
   *  - 40 item sorting limit. (Items after the first 40 are unsorted.)
   * SD sorting uses static allocation (as set by SDSORT_LIMIT), allowing the
   * compiler to calculate the worst-case usage and throw an error if the SRAM
   * limit is exceeded.
   *  - SDSORT_USES_RAM provides faster sorting via a static directory buffer.
   *  - SDSORT_USES_STACK does the same, but uses a local stack-based buffer.
   *  - SDSORT_CACHE_NAMES will retain the sorted file listing in RAM. (Expensive!)
   *  - SDSORT_DYNAMIC_RAM only uses RAM when the SD menu is visible. (Use with caution!)
  //#define SDCARD_SORT_ALPHA
  // SD Card Sorting options
  #if ENABLED(SDCARD_SORT_ALPHA)
    #define SDSORT_LIMIT       40     // Maximum number of sorted items (10-256). Costs 27 bytes each.
    #define FOLDER_SORTING     -1     // -1=above  0=none  1=below
    #define SDSORT_GCODE       false  // Allow turning sorting on/off with LCD and M34 g-code.
    #define SDSORT_USES_RAM    false  // Pre-allocate a static array for faster pre-sorting.
    #define SDSORT_USES_STACK  false  // Prefer the stack for pre-sorting to give back some SRAM. (Negated by next 2 options.)
    #define SDSORT_CACHE_NAMES false  // Keep sorted items in RAM longer for speedy performance. Most expensive option.
    #define SDSORT_DYNAMIC_RAM false  // Use dynamic allocation (within SD menus). Least expensive option. Set SDSORT_LIMIT before use!
    #define SDSORT_CACHE_VFATS 2      // Maximum number of 13-byte VFAT entries to use for sorting.
                                      // Note: Only affects SCROLL_LONG_FILENAMES with SDSORT_CACHE_NAMES but not SDSORT_DYNAMIC_RAM.
  #endif
  // This allows hosts to request long names for files and folders with M33
  //#define LONG_FILENAME_HOST_SUPPORT
  // Enable this option to scroll long filenames in the SD card menu
  //#define SCROLL_LONG_FILENAMES
   * This option allows you to abort SD printing when any endstop is triggered.
   * This feature must be enabled with "M540 S1" or from the LCD menu.
   * To have any effect, endstops must be enabled during SD printing.
  #define ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED
   * This option makes it easier to print the same SD Card file again.
   * On print completion the LCD Menu will open with the file selected.
   * You can just click to start the print, or navigate elsewhere.
  //#define SD_REPRINT_LAST_SELECTED_FILE
   * Auto-report SdCard status with M27 S<seconds>
  //#define AUTO_REPORT_SD_STATUS
#endif // SDSUPPORT
 * Additional options for Graphical Displays
 * Use the optimizations here to improve printing performance,
 * which can be adversely affected by graphical display drawing,
 * especially when doing several short moves, and when printing
 * on DELTA and SCARA machines.
 * Some of these options may result in the display lagging behind
 * controller events, as there is a trade-off between reliable
 * printing performance versus fast display updates.
#if ENABLED(DOGLCD)
  // Show SD percentage next to the progress bar
  //#define DOGM_SD_PERCENT
  // Enable to save many cycles by drawing a hollow frame on the Info Screen
  #define XYZ_HOLLOW_FRAME
  // Enable to save many cycles by drawing a hollow frame on Menu Screens
  #define MENU_HOLLOW_FRAME
  // A bigger font is available for edit items. Costs 3120 bytes of PROGMEM.
  // Western only. Not available for Cyrillic, Kana, Turkish, Greek, or Chinese.
  //#define USE_BIG_EDIT_FONT
  // A smaller font may be used on the Info Screen. Costs 2300 bytes of PROGMEM.
  //#define USE_SMALL_INFOFONT
  // Enable this option and reduce the value to optimize screen updates.
  // The normal delay is 10µs. Use the lowest value that still gives a reliable display.
  //#define DOGM_SPI_DELAY_US 5
  // Swap the CW/CCW indicators in the graphics overlay
  //#define OVERLAY_GFX_REVERSE
  #if ENABLED(U8GLIB_ST7920)
     * ST7920-based LCDs can emulate a 16 x 4 character display using
     * the ST7920 character-generator for very fast screen updates.
     * Enable LIGHTWEIGHT_UI to use this special display mode.
     * Since LIGHTWEIGHT_UI has limited space, the position and status
     * message occupy the same line. Set STATUS_EXPIRE_SECONDS to the
     * length of time to display the status message before clearing.
     * Set STATUS_EXPIRE_SECONDS to zero to never clear the status.
     * This will prevent position updates from being displayed.
    //#define LIGHTWEIGHT_UI
    #if ENABLED(LIGHTWEIGHT_UI)
      #define STATUS_EXPIRE_SECONDS 20
    #endif
  #endif
#endif // DOGLCD
// @section safety
// The hardware watchdog should reset the microcontroller disabling all outputs,
// in case the firmware gets stuck and doesn't do temperature regulation.
#define USE_WATCHDOG
#if ENABLED(USE_WATCHDOG)
  // If you have a watchdog reboot in an ArduinoMega2560 then the device will hang forever, as a watchdog reset will leave the watchdog on.
  // The "WATCHDOG_RESET_MANUAL" goes around this by not using the hardware reset.
  //  However, THIS FEATURE IS UNSAFE!, as it will only work if interrupts are disabled. And the code could hang in an interrupt routine with interrupts disabled.
  //#define WATCHDOG_RESET_MANUAL
#endif
// @section lcd
 * Babystepping enables movement of the axes by tiny increments without changing
 * the current position values. This feature is used primarily to adjust the Z
 * axis in the first layer of a print in real-time.
 * Warning: Does not respect endstops!
//#define BABYSTEPPING
#if ENABLED(BABYSTEPPING)
  //#define BABYSTEP_XY              // Also enable X/Y Babystepping. Not supported on DELTA!
  #define BABYSTEP_INVERT_Z false    // Change if Z babysteps should go the other way
  #define BABYSTEP_MULTIPLICATOR 1   // Babysteps are very small. Increase for faster motion.
  //#define BABYSTEP_ZPROBE_OFFSET   // Enable to combine M851 and Babystepping
  //#define DOUBLECLICK_FOR_Z_BABYSTEPPING // Double-click on the Status Screen for Z Babystepping.
  #define DOUBLECLICK_MAX_INTERVAL 1250 // Maximum interval between clicks, in milliseconds.
                                        // Note: Extra time may be added to mitigate controller latency.
  //#define BABYSTEP_ZPROBE_GFX_OVERLAY // Enable graphical overlay on Z-offset editor
#endif
 * Linear Pressure Control v1.5
 * Assumption: advance [steps] = k * (delta velocity [steps/s])
 * K=0 means advance disabled.
 * NOTE: K values for LIN_ADVANCE 1.5 differ from earlier versions!
 * Set K around 0.22 for 3mm PLA Direct Drive with ~6.5cm between the drive gear and heatbreak.
 * Larger K values will be needed for flexible filament and greater distances.
 * If this algorithm produces a higher speed offset than the extruder can handle (compared to E jerk)
 * print acceleration will be reduced during the affected moves to keep within the limit.
 * See http://marlinfw.org/docs/features/lin_advance.html for full instructions.
 * Mention @Sebastianv650 on GitHub to alert the author of any issues.
//#define LIN_ADVANCE
#if ENABLED(LIN_ADVANCE)
  #define LIN_ADVANCE_K 0.22  // Unit: mm compression per 1mm/s extruder speed
  //#define LA_DEBUG          // If enabled, this will generate debug information output over USB.
#endif
// @section leveling
#if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_UBL)
  // Override the mesh area if the automatic (max) area is too large
  //#define MESH_MIN_X MESH_INSET
  //#define MESH_MIN_Y MESH_INSET
  //#define MESH_MAX_X X_BED_SIZE - (MESH_INSET)
  //#define MESH_MAX_Y Y_BED_SIZE - (MESH_INSET)
#endif
// @section extras
// G2/G3 Arc Support
#define ARC_SUPPORT               // Disable this feature to save ~3226 bytes
#if ENABLED(ARC_SUPPORT)
  #define MM_PER_ARC_SEGMENT  1   // Length of each arc segment
  #define N_ARC_CORRECTION   25   // Number of intertpolated segments between corrections
  //#define ARC_P_CIRCLES         // Enable the 'P' parameter to specify complete circles
  //#define CNC_WORKSPACE_PLANES  // Allow G2/G3 to operate in XY, ZX, or YZ planes
#endif
// Support for G5 with XYZE destination and IJPQ offsets. Requires ~2666 bytes.
//#define BEZIER_CURVE_SUPPORT
// G38.2 and G38.3 Probe Target
// Set MULTIPLE_PROBING if you want G38 to double touch
//#define G38_PROBE_TARGET
#if ENABLED(G38_PROBE_TARGET)
  #define G38_MINIMUM_MOVE 0.0275 // minimum distance in mm that will produce a move (determined using the print statement in check_move)
#endif
// Moves (or segments) with fewer steps than this will be joined with the next move
#define MIN_STEPS_PER_SEGMENT 6
 * Minimum delay after setting the stepper DIR (in ns)
 *     0 : No delay (Expect at least 10µS since one Stepper ISR must transpire)
 *    20 : Minimum for TMC2xxx drivers
 *   200 : Minimum for A4988 drivers
 *   500 : Minimum for LV8729 drivers (guess, no info in datasheet)
 *   650 : Minimum for DRV8825 drivers
 *  1500 : Minimum for TB6600 drivers (guess, no info in datasheet)
 * 15000 : Minimum for TB6560 drivers (guess, no info in datasheet)
 * Override the default value based on the driver type set in Configuration.h.
//#define MINIMUM_STEPPER_DIR_DELAY 650
 * Minimum stepper driver pulse width (in µs)
 *   0 : Smallest possible width the MCU can produce, compatible with TMC2xxx drivers
 *   1 : Minimum for A4988 stepper drivers
 *   1 : Minimum for LV8729 stepper drivers
 *   2 : Minimum for DRV8825 stepper drivers
 *   3 : Minimum for TB6600 stepper drivers
 *  30 : Minimum for TB6560 stepper drivers
//#define MINIMUM_STEPPER_PULSE 2
 * Maximum stepping rate (in Hz) the stepper driver allows
 *  If undefined, defaults to 1MHz / (2 * MINIMUM_STEPPER_PULSE)
 *  500000 : Maximum for A4988 stepper driver
 *  400000 : Maximum for TMC2xxx stepper drivers
 *  250000 : Maximum for DRV8825 stepper driver
 *  150000 : Maximum for TB6600 stepper driver
 *  130000 : Maximum for LV8729 stepper driver
 *   15000 : Maximum for TB6560 stepper driver
//#define MAXIMUM_STEPPER_RATE 250000
// Control heater 0 and heater 1 in parallel.
//#define HEATERS_PARALLEL
//================================= Buffers =================================
// @section hidden
// The number of linear motions that can be in the plan at any give time.
// THE BLOCK_BUFFER_SIZE NEEDS TO BE A POWER OF 2 (e.g. 8, 16, 32) because shifts and ors are used to do the ring-buffering.
  #define BLOCK_BUFFER_SIZE 16 // SD,LCD,Buttons take more memory, block buffer needs to be smaller
#else
  #define BLOCK_BUFFER_SIZE 16 // maximize block buffer
#endif
// @section serial
// The ASCII buffer for serial input
#define MAX_CMD_SIZE 96
#define BUFSIZE 4
// Transmission to Host Buffer Size
// To save 386 bytes of PROGMEM (and TX_BUFFER_SIZE+3 bytes of RAM) set to 0.
// To buffer a simple "ok" you need 4 bytes.
// For ADVANCED_OK (M105) you need 32 bytes.
// For debug-echo: 128 bytes for the optimal speed.
// Other output doesn't need to be that speedy.
// :[0, 2, 4, 8, 16, 32, 64, 128, 256]
#define TX_BUFFER_SIZE 0
// Host Receive Buffer Size
// Without XON/XOFF flow control (see SERIAL_XON_XOFF below) 32 bytes should be enough.
// To use flow control, set this buffer size to at least 1024 bytes.
// :[0, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2048]
//#define RX_BUFFER_SIZE 1024
#if RX_BUFFER_SIZE >= 1024
  // Enable to have the controller send XON/XOFF control characters to
  // the host to signal the RX buffer is becoming full.
  //#define SERIAL_XON_XOFF
#endif
  // Enable this option to collect and display the maximum
  // RX queue usage after transferring a file to SD.
  //#define SERIAL_STATS_MAX_RX_QUEUED
  // Enable this option to collect and display the number
  // of dropped bytes after a file transfer to SD.
  //#define SERIAL_STATS_DROPPED_RX
#endif
// Enable an emergency-command parser to intercept certain commands as they
// enter the serial receive buffer, so they cannot be blocked.
// Currently handles M108, M112, M410
// Does not work on boards using AT90USB (USBCON) processors!
//#define EMERGENCY_PARSER
// Bad Serial-connections can miss a received command by sending an 'ok'
// Therefore some clients abort after 30 seconds in a timeout.
// Some other clients start sending commands while receiving a 'wait'.
// This "wait" is only sent when the buffer is empty. 1 second is a good value here.
//#define NO_TIMEOUTS 1000 // Milliseconds
// Some clients will have this feature soon. This could make the NO_TIMEOUTS unnecessary.
//#define ADVANCED_OK
// @section extras
 * Firmware-based and LCD-controlled retract
 * Add G10 / G11 commands for automatic firmware-based retract / recover.
 * Use M207 and M208 to define parameters for retract / recover.
 * Use M209 to enable or disable auto-retract.
 * With auto-retract enabled, all G1 E moves within the set range
 * will be converted to firmware-based retract/recover moves.
 * Be sure to turn off auto-retract during filament change.
 * Note that M207 / M208 / M209 settings are saved to EEPROM.
//#define FWRETRACT  // ONLY PARTIALLY TESTED
#if ENABLED(FWRETRACT)
  #define MIN_AUTORETRACT 0.1             // When auto-retract is on, convert E moves of this length and over
  #define MAX_AUTORETRACT 10.0            // Upper limit for auto-retract conversion
  #define RETRACT_LENGTH 3                // Default retract length (positive mm)
  #define RETRACT_LENGTH_SWAP 13          // Default swap retract length (positive mm), for extruder change
  #define RETRACT_FEEDRATE 45             // Default feedrate for retracting (mm/s)
  #define RETRACT_ZLIFT 0                 // Default retract Z-lift
  #define RETRACT_RECOVER_LENGTH 0        // Default additional recover length (mm, added to retract length when recovering)
  #define RETRACT_RECOVER_LENGTH_SWAP 0   // Default additional swap recover length (mm, added to retract length when recovering from extruder change)
  #define RETRACT_RECOVER_FEEDRATE 8      // Default feedrate for recovering from retraction (mm/s)
  #define RETRACT_RECOVER_FEEDRATE_SWAP 8 // Default feedrate for recovering from swap retraction (mm/s)
#endif
 * Extra Fan Speed
 * Adds a secondary fan speed for each print-cooling fan.
 *   'M106 P<fan> T3-255' : Set a secondary speed for <fan>
 *   'M106 P<fan> T2'     : Use the set secondary speed
 *   'M106 P<fan> T1'     : Restore the previous fan speed
//#define EXTRA_FAN_SPEED
 * Advanced Pause
 * Experimental feature for filament change support and for parking the nozzle when paused.
 * Adds the GCode M600 for initiating filament change.
 * If PARK_HEAD_ON_PAUSE enabled, adds the GCode M125 to pause printing and park the nozzle.
 * Requires an LCD display.
 * Requires NOZZLE_PARK_FEATURE.
 * This feature is required for the default FILAMENT_RUNOUT_SCRIPT.
//#define ADVANCED_PAUSE_FEATURE
#if ENABLED(ADVANCED_PAUSE_FEATURE)
  #define PAUSE_PARK_RETRACT_FEEDRATE         60  // (mm/s) Initial retract feedrate.
  #define PAUSE_PARK_RETRACT_LENGTH            2  // (mm) Initial retract.
                                                  // This short retract is done immediately, before parking the nozzle.
  #define FILAMENT_CHANGE_UNLOAD_FEEDRATE     10  // (mm/s) Unload filament feedrate. This can be pretty fast.
  #define FILAMENT_CHANGE_UNLOAD_ACCEL        25  // (mm/s^2) Lower acceleration may allow a faster feedrate.
  #define FILAMENT_CHANGE_UNLOAD_LENGTH      100  // (mm) The length of filament for a complete unload.
                                                  //   For Bowden, the full length of the tube and nozzle.
                                                  //   For direct drive, the full length of the nozzle.
                                                  //   Set to 0 for manual unloading.
  #define FILAMENT_CHANGE_SLOW_LOAD_FEEDRATE   6  // (mm/s) Slow move when starting load.
  #define FILAMENT_CHANGE_SLOW_LOAD_LENGTH     0  // (mm) Slow length, to allow time to insert material.
                                                  // 0 to disable start loading and skip to fast load only
  #define FILAMENT_CHANGE_FAST_LOAD_FEEDRATE   6  // (mm/s) Load filament feedrate. This can be pretty fast.
  #define FILAMENT_CHANGE_FAST_LOAD_ACCEL     25  // (mm/s^2) Lower acceleration may allow a faster feedrate.
  #define FILAMENT_CHANGE_FAST_LOAD_LENGTH     0  // (mm) Load length of filament, from extruder gear to nozzle.
  //#define ADVANCED_PAUSE_CONTINUOUS_PURGE       // Purge continuously up to the purge length until interrupted.
  #define ADVANCED_PAUSE_PURGE_FEEDRATE        3  // (mm/s) Extrude feedrate (after loading). Should be slower than load feedrate.
  #define ADVANCED_PAUSE_PURGE_LENGTH         50  // (mm) Length to extrude after loading.
                                                  //   Set to 0 for manual extrusion.
                                                  //   Filament can be extruded repeatedly from the Filament Change menu
                                                  //   until extrusion is consistent, and to purge old filament.
                                                  // Filament Unload does a Retract, Delay, and Purge first:
  #define FILAMENT_UNLOAD_RETRACT_LENGTH      13  // (mm) Unload initial retract length.
  #define FILAMENT_UNLOAD_DELAY             5000  // (ms) Delay for the filament to cool after retract.
  #define FILAMENT_UNLOAD_PURGE_LENGTH         8  // (mm) An unretract is done, then this length is purged.
  #define PAUSE_PARK_NOZZLE_TIMEOUT           45  // (seconds) Time limit before the nozzle is turned off for safety.
  #define FILAMENT_CHANGE_ALERT_BEEPS         10  // Number of alert beeps to play when a response is needed.
  #define PAUSE_PARK_NO_STEPPER_TIMEOUT           // Enable for XYZ steppers to stay powered on during filament change.
  //#define PARK_HEAD_ON_PAUSE                    // Park the nozzle during pause and filament change.
  //#define HOME_BEFORE_FILAMENT_CHANGE           // Ensure homing has been completed prior to parking for filament change
  //#define FILAMENT_LOAD_UNLOAD_GCODES           // Add M701/M702 Load/Unload G-codes, plus Load/Unload in the LCD Prepare menu.
  //#define FILAMENT_UNLOAD_ALL_EXTRUDERS         // Allow M702 to unload all extruders above a minimum target temp (as set by M302)
#endif
// @section tmc
 * TMC26X Stepper Driver options
 * The TMC26XStepper library is required for this stepper driver.
 * https://github.com/trinamic/TMC26XStepper
#if HAS_DRIVER(TMC26X)
  #define X_MAX_CURRENT     1000 // in mA
  #define X_SENSE_RESISTOR    91 // in mOhms
  #define X_MICROSTEPS        16 // number of microsteps
  #define X2_MAX_CURRENT    1000
  #define X2_SENSE_RESISTOR   91
  #define X2_MICROSTEPS       16
  #define Y_MAX_CURRENT     1000
  #define Y_SENSE_RESISTOR    91
  #define Y_MICROSTEPS        16
  #define Y2_MAX_CURRENT    1000
  #define Y2_SENSE_RESISTOR   91
  #define Y2_MICROSTEPS       16
  #define Z_MAX_CURRENT     1000
  #define Z_SENSE_RESISTOR    91
  #define Z_MICROSTEPS        16
  #define Z2_MAX_CURRENT    1000
  #define Z2_SENSE_RESISTOR   91
  #define Z2_MICROSTEPS       16
  #define E0_MAX_CURRENT    1000
  #define E0_SENSE_RESISTOR   91
  #define E0_MICROSTEPS       16
  #define E1_MAX_CURRENT    1000
  #define E1_SENSE_RESISTOR   91
  #define E1_MICROSTEPS       16
  #define E2_MAX_CURRENT    1000
  #define E2_SENSE_RESISTOR   91
  #define E2_MICROSTEPS       16
  #define E3_MAX_CURRENT    1000
  #define E3_SENSE_RESISTOR   91
  #define E3_MICROSTEPS       16
  #define E4_MAX_CURRENT    1000
  #define E4_SENSE_RESISTOR   91
  #define E4_MICROSTEPS       16
#endif // TMC26X
// @section tmc_smart
 * To use TMC2130 stepper drivers in SPI mode connect your SPI pins to
 * the hardware SPI interface on your board and define the required CS pins
 * in your `pins_MYBOARD.h` file. (e.g., RAMPS 1.4 uses AUX3 pins `X_CS_PIN 53`, `Y_CS_PIN 49`, etc.).
 * You may also use software SPI if you wish to use general purpose IO pins.
 * You'll also need the TMC2130Stepper Arduino library
 * (https://github.com/teemuatlut/TMC2130Stepper).
 * To use TMC2208 stepper UART-configurable stepper drivers
 * connect #_SERIAL_TX_PIN to the driver side PDN_UART pin with a 1K resistor.
 * To use the reading capabilities, also connect #_SERIAL_RX_PIN
 * to PDN_UART without a resistor.
 * The drivers can also be used with hardware serial.
 * You'll also need the TMC2208Stepper Arduino library
 * (https://github.com/teemuatlut/TMC2208Stepper).
#if HAS_TRINAMIC
  #define R_SENSE           0.11  // R_sense resistor for SilentStepStick2130
  #define HOLD_MULTIPLIER    0.5  // Scales down the holding current from run current
  #define INTERPOLATE       true  // Interpolate X/Y/Z_MICROSTEPS to 256
  #define X_CURRENT          800  // rms current in mA. Multiply by 1.41 for peak current.
  #define X_MICROSTEPS        16  // 0..256
  #define Y_CURRENT          800
  #define Z_CURRENT          800
  #define X2_CURRENT         800
  #define Y2_CURRENT         800
  #define Z2_CURRENT         800
  #define E0_CURRENT         800
  #define E1_CURRENT         800
  #define E2_CURRENT         800
  #define E3_CURRENT         800
  #define E4_CURRENT         800
   * Use software SPI for TMC2130.
   * The default SW SPI pins are defined the respective pins files,
   * but you can override or define them here.
  //#define TMC_USE_SW_SPI
  //#define TMC_SW_MOSI       -1
  //#define TMC_SW_MISO       -1
  //#define TMC_SW_SCK        -1
   * Use Trinamic's ultra quiet stepping mode.
   * When disabled, Marlin will use spreadCycle stepping mode.
  #define STEALTHCHOP
   * Monitor Trinamic TMC2130 and TMC2208 drivers for error conditions,
   * like overtemperature and short to ground. TMC2208 requires hardware serial.
   * In the case of overtemperature Marlin can decrease the driver current until error condition clears.
   * Other detected conditions can be used to stop the current print.
   * Relevant g-codes:
   * M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given.
   * M911 - Report stepper driver overtemperature pre-warn condition.
   * M912 - Clear stepper driver overtemperature pre-warn condition flag.
   * M122 S0/1 - Report driver parameters (Requires TMC_DEBUG)
  //#define MONITOR_DRIVER_STATUS
  #if ENABLED(MONITOR_DRIVER_STATUS)
    #define CURRENT_STEP_DOWN     50  // [mA]
    #define REPORT_CURRENT_CHANGE
    #define STOP_ON_ERROR
  #endif
   * The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD.
   * This mode allows for faster movements at the expense of higher noise levels.
   * STEALTHCHOP needs to be enabled.
   * M913 X/Y/Z/E to live tune the setting
  //#define HYBRID_THRESHOLD
  #define X_HYBRID_THRESHOLD     100  // [mm/s]
  #define X2_HYBRID_THRESHOLD    100
  #define Y_HYBRID_THRESHOLD     100
  #define Y2_HYBRID_THRESHOLD    100
  #define Z_HYBRID_THRESHOLD       3
  #define Z2_HYBRID_THRESHOLD      3
  #define E0_HYBRID_THRESHOLD     30
  #define E1_HYBRID_THRESHOLD     30
  #define E2_HYBRID_THRESHOLD     30
  #define E3_HYBRID_THRESHOLD     30
  #define E4_HYBRID_THRESHOLD     30
   * Use stallGuard2 to sense an obstacle and trigger an endstop.
   * You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin.
   * X, Y, and Z homing will always be done in spreadCycle mode.
   * X/Y/Z_HOMING_SENSITIVITY is used for tuning the trigger sensitivity.
   * Higher values make the system LESS sensitive.
   * Lower value make the system MORE sensitive.
   * Too low values can lead to false positives, while too high values will collide the axis without triggering.
   * It is advised to set X/Y/Z_HOME_BUMP_MM to 0.
   * M914 X/Y/Z to live tune the setting
  //#define SENSORLESS_HOMING // TMC2130 only
  #if ENABLED(SENSORLESS_HOMING)
    #define X_HOMING_SENSITIVITY  8
    #define Y_HOMING_SENSITIVITY  8
    #define Z_HOMING_SENSITIVITY  8
  #endif
   * Enable M122 debugging command for TMC stepper drivers.
   * M122 S0/1 will enable continous reporting.
  //#define TMC_DEBUG
   * M915 Z Axis Calibration
   * - Adjust Z stepper current,
   * - Drive the Z axis to its physical maximum, and
   * - Home Z to account for the lost steps.
   * Use M915 Snn to specify the current.
   * Use M925 Znn to add extra Z height to Z_MAX_POS.
  //#define TMC_Z_CALIBRATION
  #if ENABLED(TMC_Z_CALIBRATION)
    #define CALIBRATION_CURRENT 250
    #define CALIBRATION_EXTRA_HEIGHT 10
  #endif
   * You can set your own advanced settings by filling in predefined functions.
   * A list of available functions can be found on the library github page
   * https://github.com/teemuatlut/TMC2130Stepper
   * https://github.com/teemuatlut/TMC2208Stepper
   * Example:
   * #define TMC_ADV() { \
   *   stepperX.diag0_temp_prewarn(1); \
   *   stepperY.interpolate(0); \
  #define TMC_ADV() {  }
#endif // TMC2130 || TMC2208
// @section L6470
 * L6470 Stepper Driver options
 * The Arduino-L6470 library is required for this stepper driver.
 * https://github.com/ameyer/Arduino-L6470
#if HAS_DRIVER(L6470)
  #define X_OVERCURRENT   2000 // maxc current in mA. If the current goes over this value, the driver will switch off
  #define X_STALLCURRENT  1500 // current in mA where the driver will detect a stall
  #define X2_OVERCURRENT  2000
  #define X2_STALLCURRENT 1500
  #define Y_OVERCURRENT   2000
  #define Y_STALLCURRENT  1500
  #define Y2_OVERCURRENT  2000
  #define Y2_STALLCURRENT 1500
  #define Z_OVERCURRENT   2000
  #define Z_STALLCURRENT  1500
  #define Z2_OVERCURRENT  2000
  #define Z2_STALLCURRENT 1500
  #define E0_OVERCURRENT  2000
  #define E0_STALLCURRENT 1500
  #define E1_OVERCURRENT  2000
  #define E1_STALLCURRENT 1500
  #define E2_OVERCURRENT  2000
  #define E2_STALLCURRENT 1500
  #define E3_OVERCURRENT  2000
  #define E3_STALLCURRENT 1500
  #define E4_OVERCURRENT  2000
  #define E4_STALLCURRENT 1500
#endif // L6470
 * TWI/I2C BUS
 * This feature is an EXPERIMENTAL feature so it shall not be used on production
 * machines. Enabling this will allow you to send and receive I2C data from slave
 * devices on the bus.
 * ; Example #1
 * ; This macro send the string "Marlin" to the slave device with address 0x63 (99)
 * ; It uses multiple M260 commands with one B<base 10> arg
 * M260 A99  ; Target slave address
 * M260 B77  ; M
 * M260 B97  ; a
 * M260 B114 ; r
 * M260 B108 ; l
 * M260 B105 ; i
 * M260 B110 ; n
 * M260 S1   ; Send the current buffer
 * ; Example #2
 * ; Request 6 bytes from slave device with address 0x63 (99)
 * M261 A99 B5
 * ; Example #3
 * ; Example serial output of a M261 request
 * echo:i2c-reply: from:99 bytes:5 data:hello
// @section i2cbus
//#define EXPERIMENTAL_I2CBUS
#define I2C_SLAVE_ADDRESS  0 // Set a value from 8 to 127 to act as a slave
// @section extras
 * Spindle & Laser control
 * Add the M3, M4, and M5 commands to turn the spindle/laser on and off, and
 * to set spindle speed, spindle direction, and laser power.
 * SuperPid is a router/spindle speed controller used in the CNC milling community.
 * Marlin can be used to turn the spindle on and off. It can also be used to set
 * the spindle speed from 5,000 to 30,000 RPM.
 * You'll need to select a pin for the ON/OFF function and optionally choose a 0-5V
 * hardware PWM pin for the speed control and a pin for the rotation direction.
 * See http://marlinfw.org/docs/configuration/laser_spindle.html for more config details.
//#define SPINDLE_LASER_ENABLE
#if ENABLED(SPINDLE_LASER_ENABLE)
  #define SPINDLE_LASER_ENABLE_INVERT   false  // set to "true" if the on/off function is reversed
  #define SPINDLE_LASER_PWM             true   // set to true if your controller supports setting the speed/power
  #define SPINDLE_LASER_PWM_INVERT      true   // set to "true" if the speed/power goes up when you want it to go slower
  #define SPINDLE_LASER_POWERUP_DELAY   5000   // delay in milliseconds to allow the spindle/laser to come up to speed/power
  #define SPINDLE_LASER_POWERDOWN_DELAY 5000   // delay in milliseconds to allow the spindle to stop
  #define SPINDLE_DIR_CHANGE            true   // set to true if your spindle controller supports changing spindle direction
  #define SPINDLE_INVERT_DIR            false
  #define SPINDLE_STOP_ON_DIR_CHANGE    true   // set to true if Marlin should stop the spindle before changing rotation direction
   *  The M3 & M4 commands use the following equation to convert PWM duty cycle to speed/power
   *  SPEED/POWER = PWM duty cycle * SPEED_POWER_SLOPE + SPEED_POWER_INTERCEPT
   *    where PWM duty cycle varies from 0 to 255
   *  set the following for your controller (ALL MUST BE SET)
  #define SPEED_POWER_SLOPE    118.4
  #define SPEED_POWER_INTERCEPT  0
  #define SPEED_POWER_MIN     5000
  #define SPEED_POWER_MAX    30000    // SuperPID router controller 0 - 30,000 RPM
  //#define SPEED_POWER_SLOPE      0.3922
  //#define SPEED_POWER_INTERCEPT  0
  //#define SPEED_POWER_MIN       10
  //#define SPEED_POWER_MAX      100      // 0-100%
#endif
 * Filament Width Sensor
 * Measures the filament width in real-time and adjusts
 * flow rate to compensate for any irregularities.
 * Also allows the measured filament diameter to set the
 * extrusion rate, so the slicer only has to specify the
 * volume.
 * Only a single extruder is supported at this time.
 *  34 RAMPS_14    : Analog input 5 on the AUX2 connector
 *  81 PRINTRBOARD : Analog input 2 on the Exp1 connector (version B,C,D,E)
 * 301 RAMBO       : Analog input 3
 * Note: May require analog pins to be defined for other boards.
//#define FILAMENT_WIDTH_SENSOR
#if ENABLED(FILAMENT_WIDTH_SENSOR)
  #define FILAMENT_SENSOR_EXTRUDER_NUM 0    // Index of the extruder that has the filament sensor. :[0,1,2,3,4]
  #define MEASUREMENT_DELAY_CM        14    // (cm) The distance from the filament sensor to the melting chamber
  #define FILWIDTH_ERROR_MARGIN        1.0  // (mm) If a measurement differs too much from nominal width ignore it
  #define MAX_MEASUREMENT_DELAY       20    // (bytes) Buffer size for stored measurements (1 byte per cm). Must be larger than MEASUREMENT_DELAY_CM.
  #define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA // Set measured to nominal initially
  // Display filament width on the LCD status line. Status messages will expire after 5 seconds.
  //#define FILAMENT_LCD_DISPLAY
#endif
 * CNC Coordinate Systems
 * Enables G53 and G54-G59.3 commands to select coordinate systems
 * and G92.1 to reset the workspace to native machine space.
//#define CNC_COORDINATE_SYSTEMS
 * M43 - display pin status, watch pins for changes, watch endstops & toggle LED, Z servo probe test, toggle pins
//#define PINS_DEBUGGING
 * Auto-report temperatures with M155 S<seconds>
#define AUTO_REPORT_TEMPERATURES
 * Include capabilities in M115 output
#define EXTENDED_CAPABILITIES_REPORT
 * Disable all Volumetric extrusion options
//#define NO_VOLUMETRICS
#if DISABLED(NO_VOLUMETRICS)
   * Volumetric extrusion default state
   * Activate to make volumetric extrusion the default method,
   * with DEFAULT_NOMINAL_FILAMENT_DIA as the default diameter.
   * M200 D0 to disable, M200 Dn to set a new diameter.
  //#define VOLUMETRIC_DEFAULT_ON
#endif
 * Enable this option for a leaner build of Marlin that removes all
 * workspace offsets, simplifying coordinate transformations, leveling, etc.
 *  - M206 and M428 are disabled.
 *  - G92 will revert to its behavior from Marlin 1.0.
//#define NO_WORKSPACE_OFFSETS
 * Set the number of proportional font spaces required to fill up a typical character space.
 * This can help to better align the output of commands like `G29 O` Mesh Output.
 * For clients that use a fixed-width font (like OctoPrint), leave this set to 1.0.
 * Otherwise, adjust according to your client and font.
#define PROPORTIONAL_FONT_RATIO 1.0
 * Spend 28 bytes of SRAM to optimize the GCode parser
#define FASTER_GCODE_PARSER
 * User-defined menu items that execute custom GCode
#define CUSTOM_USER_MENUS
#if ENABLED(CUSTOM_USER_MENUS)
  #define USER_SCRIPT_DONE "M117 User Script Done"
  #define USER_SCRIPT_AUDIBLE_FEEDBACK
  //#define USER_SCRIPT_RETURN  // Return to status screen after a script
  #define USER_DESC_1 "Home & UBL Info"
  #define USER_GCODE_1 "G28\nG29 W"
  #define USER_DESC_2 "Preheat for PLA"
  #define USER_GCODE_2 "M140 S" STRINGIFY(PREHEAT_1_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_1_TEMP_HOTEND)
  #define USER_DESC_3 "Preheat for ABS"
  #define USER_GCODE_3 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_2_TEMP_HOTEND)
  #define USER_DESC_4 "Heat Bed/Home/Level"
  #define USER_GCODE_4 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nG28\nG29"
  #define USER_DESC_5 "Home & Info"
  #define USER_GCODE_5 "G28\nM503"
#endif
 * Specify an action command to send to the host when the printer is killed.
 * Will be sent in the form '//action:ACTION_ON_KILL', e.g. '//action:poweroff'.
 * The host must be configured to handle the action command.
//#define ACTION_ON_KILL "poweroff"
 * Specify an action command to send to the host on pause and resume.
 * Will be sent in the form '//action:ACTION_ON_PAUSE', e.g. '//action:pause'.
//#define ACTION_ON_PAUSE "pause"
//#define ACTION_ON_RESUME "resume"
//====================== I2C Position Encoder Settings ======================
 *  I2C position encoders for closed loop control.
 *  Developed by Chris Barr at Aus3D.
 *  Wiki: http://wiki.aus3d.com.au/Magnetic_Encoder
 *  Github: https://github.com/Aus3D/MagneticEncoder
 *  Supplier: http://aus3d.com.au/magnetic-encoder-module
 *  Alternative Supplier: http://reliabuild3d.com/
 *  Reilabuild encoders have been modified to improve reliability.
//#define I2C_POSITION_ENCODERS
#if ENABLED(I2C_POSITION_ENCODERS)
  #define I2CPE_ENCODER_CNT         1                       // The number of encoders installed; max of 5
                                                            // encoders supported currently.
  #define I2CPE_ENC_1_ADDR          I2CPE_PRESET_ADDR_X     // I2C address of the encoder. 30-200.
  #define I2CPE_ENC_1_AXIS          X_AXIS                  // Axis the encoder module is installed on.  <X|Y|Z|E>_AXIS.
  #define I2CPE_ENC_1_TYPE          I2CPE_ENC_TYPE_LINEAR   // Type of encoder:  I2CPE_ENC_TYPE_LINEAR -or-
                                                            // I2CPE_ENC_TYPE_ROTARY.
  #define I2CPE_ENC_1_TICKS_UNIT    2048                    // 1024 for magnetic strips with 2mm poles; 2048 for
                                                            // 1mm poles. For linear encoders this is ticks / mm,
                                                            // for rotary encoders this is ticks / revolution.
  //#define I2CPE_ENC_1_TICKS_REV     (16 * 200)            // Only needed for rotary encoders; number of stepper
                                                            // steps per full revolution (motor steps/rev * microstepping)
  //#define I2CPE_ENC_1_INVERT                              // Invert the direction of axis travel.
  #define I2CPE_ENC_1_EC_METHOD     I2CPE_ECM_MICROSTEP     // Type of error error correction.
  #define I2CPE_ENC_1_EC_THRESH     0.10                    // Threshold size for error (in mm) above which the
                                                            // printer will attempt to correct the error; errors
                                                            // smaller than this are ignored to minimize effects of
                                                            // measurement noise / latency (filter).
  #define I2CPE_ENC_2_ADDR          I2CPE_PRESET_ADDR_Y     // Same as above, but for encoder 2.
  #define I2CPE_ENC_2_AXIS          Y_AXIS
  #define I2CPE_ENC_2_TYPE          I2CPE_ENC_TYPE_LINEAR
  #define I2CPE_ENC_2_TICKS_UNIT    2048
  //#define I2CPE_ENC_2_TICKS_REV   (16 * 200)
  //#define I2CPE_ENC_2_INVERT
  #define I2CPE_ENC_2_EC_METHOD     I2CPE_ECM_MICROSTEP
  #define I2CPE_ENC_2_EC_THRESH     0.10
  #define I2CPE_ENC_3_ADDR          I2CPE_PRESET_ADDR_Z     // Encoder 3.  Add additional configuration options
  #define I2CPE_ENC_3_AXIS          Z_AXIS                  // as above, or use defaults below.
  #define I2CPE_ENC_4_ADDR          I2CPE_PRESET_ADDR_E     // Encoder 4.
  #define I2CPE_ENC_4_AXIS          E_AXIS
  #define I2CPE_ENC_5_ADDR          34                      // Encoder 5.
  #define I2CPE_ENC_5_AXIS          E_AXIS
  // Default settings for encoders which are enabled, but without settings configured above.
  #define I2CPE_DEF_TYPE            I2CPE_ENC_TYPE_LINEAR
  #define I2CPE_DEF_ENC_TICKS_UNIT  2048
  #define I2CPE_DEF_TICKS_REV       (16 * 200)
  #define I2CPE_DEF_EC_METHOD       I2CPE_ECM_NONE
  #define I2CPE_DEF_EC_THRESH       0.1
  //#define I2CPE_ERR_THRESH_ABORT  100.0                   // Threshold size for error (in mm) error on any given
                                                            // axis after which the printer will abort. Comment out to
                                                            // disable abort behaviour.
  #define I2CPE_TIME_TRUSTED        10000                   // After an encoder fault, there must be no further fault
                                                            // for this amount of time (in ms) before the encoder
                                                            // is trusted again.
   * Position is checked every time a new command is executed from the buffer but during long moves,
   * this setting determines the minimum update time between checks. A value of 100 works well with
   * error rolling average when attempting to correct only for skips and not for vibration.
  #define I2CPE_MIN_UPD_TIME_MS     4                       // (ms) Minimum time between encoder checks.
  // Use a rolling average to identify persistant errors that indicate skips, as opposed to vibration and noise.
  #define I2CPE_ERR_ROLLING_AVERAGE
#endif // I2C_POSITION_ENCODERS
 * MAX7219 Debug Matrix
 * Add support for a low-cost 8x8 LED Matrix based on the Max7219 chip as a realtime status display.
 * Requires 3 signal wires. Some useful debug options are included to demonstrate its usage.
//#define MAX7219_DEBUG
#if ENABLED(MAX7219_DEBUG)
  #define MAX7219_CLK_PIN   64
  #define MAX7219_DIN_PIN   57
  #define MAX7219_LOAD_PIN  44
  //#define MAX7219_GCODE          // Add the M7219 G-code to control the LED matrix
  #define MAX7219_INIT_TEST    2   // Do a test pattern at initialization (Set to 2 for spiral)
  #define MAX7219_NUMBER_UNITS 1   // Number of Max7219 units in chain.
  #define MAX7219_ROTATE       0   // Rotate the display clockwise (in multiples of +/- 90°)
                                   // connector at:  right=0   bottom=-90  top=90  left=180
   * Sample debug features
   * If you add more debug displays, be careful to avoid conflicts!
  #define MAX7219_DEBUG_PRINTER_ALIVE    // Blink corner LED of 8x8 matrix to show that the firmware is functioning
  #define MAX7219_DEBUG_PLANNER_HEAD  3  // Show the planner queue head position on this and the next LED matrix row
  #define MAX7219_DEBUG_PLANNER_TAIL  5  // Show the planner queue tail position on this and the next LED matrix row
  #define MAX7219_DEBUG_PLANNER_QUEUE 0  // Show the current planner queue depth on this and the next LED matrix row
                                         // If you experience stuttering, reboots, etc. this option can reveal how
                                         // tweaks made to the configuration are affecting the printer in real-time.
#endif
 * NanoDLP Sync support
 * Add support for Synchronized Z moves when using with NanoDLP. G0/G1 axis moves will output "Z_move_comp"
 * string to enable synchronization with DLP projector exposure. This change will allow to use
 * [[WaitForDoneMessage]] instead of populating your gcode with M400 commands
//#define NANODLP_Z_SYNC
#if ENABLED(NANODLP_Z_SYNC)
  //#define NANODLP_ALL_AXIS  // Enables "Z_move_comp" output on any axis move.
                              // Default behaviour is limited to Z axis only.
#endif
// Enable Marlin dev mode which adds some special commands
//#define MARLIN_DEV_MODE
#endif // CONFIGURATION_ADV_H
les probleme que je rencontre sont les suivant :
- pas d'affichage au LCD ( écran allumé mais rien d'afficher)
- le soft Mater control ,en mode prise de control les moteur ne tourne que dans 1 sens
je pense que d'autre erreur sont aussi presente mais je vois pas encore lequelle
merci de me dire ou sont mes louper sur la configuration
