je voudrais supprimer le menu de préchauffage ABS, car je n'utilise pas d'ABS.
J'ai donc pensé commenter les lignes suivantes dans configuration.h :
//#define PREHEAT_2_LABEL       "ABS"
//#define PREHEAT_2_TEMP_HOTEND 240
//#define PREHEAT_2_TEMP_BED    110
//#define PREHEAT_2_FAN_SPEED     0 // Value from 0 to 255
Mais la compilation n'a pas fonctionné :
" Marlin\src\module\configuration_store.cpp: In static member function 'static void MarlinSettings::reset()':
Marlin\src\module\configuration_store.cpp:2533:33: error: 'PREHEAT_2_TEMP_HOTEND' was not declared in this scope; did you mean 'PREHEAT_1_TEMP_HOTEND'?
 2533 |     ui.preheat_hotend_temp[1] = PREHEAT_2_TEMP_HOTEND;
      |                                 PREHEAT_1_TEMP_HOTEND
Marlin\src\module\configuration_store.cpp:2535:30: error: 'PREHEAT_2_TEMP_BED' was not declared in this scope; did you mean 'PREHEAT_1_TEMP_BED'?
 2535 |     ui.preheat_bed_temp[1] = PREHEAT_2_TEMP_BED;
      |                              PREHEAT_1_TEMP_BED
Marlin\src\module\configuration_store.cpp:2537:31: error: 'PREHEAT_2_FAN_SPEED' was not declared in this scope; did you mean 'PREHEAT_1_FAN_SPEED'?
 2537 |     ui.preheat_fan_speed[1] = PREHEAT_2_FAN_SPEED;
      |                               PREHEAT_1_FAN_SPEED
*** [.pio\build\LPC1769\src\src\module\configuration_store.cpp.o] Error 1
Est-il possible de supprimer le menu ABS ? et si oui, comment éviter le message d'erreur ci-dessus ?
Cordialement
Thierry
