J'ai reçu mon écran MKS mini 12864 v3, j'ai configurer Marlin :
  • #define MKS_MINI_12864_V3
  • #define NEOPIXEL_LED
Mais j'ai systématiquement cette erreur :
Révélation
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_bl24cxx.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_flash.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_if_iic.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_sdcard.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_sram.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_wired.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\fast_pwm.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\fastio.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\msc_sd.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\sdio.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\tft\gt911.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\tft\tft_fsmc.cpp.o
In file included from Marlin\src\HAL\STM32\../../inc/../pins/stm32f4/pins_MKS_EAGLE.h:35,
                 from Marlin\src\HAL\STM32\../../inc/../pins/pins.h:707,
                 from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:34,
                 from Marlin\src\HAL\STM32\HAL_SPI.cpp:27:
Marlin\src\HAL\STM32\../../inc/../pins/stm32f4/pins_MKS_ROBIN_NANO_V3_common.h:52: warning: "SERVO0_PIN" redefined
   52 | #define SERVO0_PIN                          PA8   // Enable BLTOUCH
In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfigPre.h:39,
                 from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:28,
Marlin\src\HAL\STM32\../../inc/../../Configuration.h:1335: note: this is the location of the previous definition 1335 | #define SERVO0_PIN 11
                 from Marlin\src\HAL\STM32\HAL.cpp:27:
In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:49,
Marlin\src\HAL\STM32\../../inc/SanityCheck.h:2640:4: error: #error "LED_CONTROL_MENU requires BLINKM, RGB_LED, RGBW_LED, PCA9533, PCA9632, or NEOPIXEL_LED."
 2640 |   #error "LED_CONTROL_MENU requires BLINKM, RGB_LED, RGBW_LED, PCA9533, PCA9632, or NEOPIXEL_LED."
                 from Marlin\src\HAL\STM32\MarlinSerial.cpp:27:
                 from Marlin\src\HAL\STM32\Servo.cpp:27:
                 from Marlin\src\HAL\STM32\eeprom_bl24cxx.cpp:32:
                 from Marlin\src\HAL\STM32\eeprom_if_iic.cpp:32:
                 from Marlin\src\HAL\STM32\eeprom_flash.cpp:27:
                 from Marlin\src\HAL\STM32\eeprom_sdcard.cpp:31:
                 from Marlin\src\HAL\STM32\fast_pwm.cpp:27:
                 from Marlin\src\HAL\STM32\eeprom_sram.cpp:27:
                 from Marlin\src\HAL\STM32\fastio.cpp:27:
                 from Marlin\src\HAL\STM32\eeprom_wired.cpp:27:
                 from Marlin\src\HAL\STM32\sdio.cpp:27:
In file included from Marlin\src\HAL\STM32\tft\../../../inc/../pins/stm32f4/pins_MKS_EAGLE.h:35,
                 from Marlin\src\HAL\STM32\tft\../../../inc/../pins/pins.h:707,
                 from Marlin\src\HAL\STM32\tft\../../../inc/MarlinConfig.h:34,
                 from Marlin\src\HAL\STM32\tft\gt911.cpp:26:
Marlin\src\HAL\STM32\tft\../../../inc/../pins/stm32f4/pins_MKS_ROBIN_NANO_V3_common.h:52: warning: "SERVO0_PIN"
redefined
In file included from Marlin\src\HAL\STM32\tft\../../../inc/MarlinConfigPre.h:39,
                 from Marlin\src\HAL\STM32\tft\../../../inc/MarlinConfig.h:28,
Marlin\src\HAL\STM32\tft\../../../inc/../../Configuration.h:1335: note: this is the location of the previous definition
In file included from Marlin\src\HAL\STM32\tft\../../../inc/MarlinConfig.h:49,
Marlin\src\HAL\STM32\tft\../../../inc/SanityCheck.h:2640:4: error: #error "LED_CONTROL_MENU requires BLINKM, RGB_LED, RGBW_LED, PCA9533, PCA9632, or NEOPIXEL_LED."
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\HAL_SPI.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\HAL.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\MarlinSerial.cpp.o] Error 1
                 from Marlin\src\HAL\STM32\tft\tft_fsmc.cpp:27:
redefined
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_bl24cxx.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\Servo.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_if_iic.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_sdcard.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_flash.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\fast_pwm.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_sram.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\fastio.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\eeprom_wired.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\sdio.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\tft\gt911.cpp.o] Error 1
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\tft\tft_fsmc.cpp.o] Error 1
========================================= [FAILED] Took 13.84 seconds =========================================
Environment                Status    Duration
mks_eagle_usb_flash_drive  FAILED    00:00:13.837
==================================== 1 failed, 0 succeeded in 00:00:13.837 ====================================
 *  The terminal process "C:\Users\Benoit\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
 *  Executing task in folder Marlin-2.1.2: C:\Users\Benoit\.platformio\penv\Scripts\platformio.exe run
Processing mks_eagle_usb_flash_drive (board: marlin_STM32F407VGT6_CCM; platform: ststm32@~12.1; framework: arduino)
----------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/marlin_STM32F407VGT6_CCM.html
PLATFORM: ST STM32 (12.1.1) > STM32F407VG (128k RAM, 64k CCM RAM, 1024k Flash
HARDWARE: STM32F407VGT6 168MHz, 128KB RAM, 1MB Flash
DEBUG: Current (jlink) External (jlink, stlink)
PACKAGES:
 - framework-arduinoststm32 @ 0.0.0
 - framework-cmsis @ 2.50501.200527 (5.5.1)
 - toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 12 compatible libraries
Scanning dependencies...
Dependency Graph
|-- TMCStepper @ 0.7.3
|   |-- SoftwareSerial @ 1.0
|   |-- SPI @ 1.0
|-- U8glib-HAL @ 0.5.2
|   |-- Wire @ 1.0
|   |-- SPI @ 1.0
|-- IWatchdog @ 1.0.0
|-- SPI @ 1.0
|-- EEPROM @ 2.0.1
|-- Wire @ 1.0
|-- Servo @ 1.1.2
Building in release mode
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\HAL.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\HAL_SPI.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\MarlinSPI.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\MarlinSerial.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\MinSerial.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\HAL\STM32\Servo.cpp.o
redefined
redefined
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\inc\Warnings.cpp.o
In file included from Marlin\src\inc\../pins/stm32f4/pins_MKS_EAGLE.h:35,
                 from Marlin\src\inc\../pins/pins.h:707,
                 from Marlin\src\inc\MarlinConfig.h:34,
                 from Marlin\src\inc\Warnings.cpp:28:
Marlin\src\inc\../pins/stm32f4/pins_MKS_ROBIN_NANO_V3_common.h:52: warning: "SERVO0_PIN" redefined
In file included from Marlin\src\inc\MarlinConfigPre.h:39,
                 from Marlin\src\inc\MarlinConfig.h:28,
Marlin\src\inc\../../Configuration.h:1335: note: this is the location of the previous definition
Marlin\src\inc\Warnings.cpp:742:4: warning: #warning "Contrast cannot be changed when LCD_CONTRAST_MIN >= LCD_CONTRAST_MAX." [-Wcpp]
  742 |   #warning "Contrast cannot be changed when LCD_CONTRAST_MIN >= LCD_CONTRAST_MAX."
Marlin\src\inc\Warnings.cpp:753:4: warning: #warning "Your FYSETC/MKS/BTT Mini Panel works best with NEOPIXEL_LED, LED_CONTROL_MENU, LED_USER_PRESET_STARTUP, and LED_COLOR_PRESETS." [-Wcpp]
  753 |   #warning "Your FYSETC/MKS/BTT Mini Panel works best with NEOPIXEL_LED, LED_CONTROL_MENU, LED_USER_PRESET_STARTUP, and LED_COLOR_PRESETS."
Marlin\src\inc\Warnings.cpp:759:4: warning: #warning "Your FYSETC Mini Panel works best with LED_USER_PRESET_STARTUP." [-Wcpp]
  759 |   #warning "Your FYSETC Mini Panel works best with LED_USER_PRESET_STARTUP."
Checking size .pio\build\mks_eagle_usb_flash_drive\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [=         ]   9.3% (used 12196 bytes from 131072 bytes)
Flash: [==        ]  17.3% (used 180896 bytes from 1048576 bytes)
Building .pio\build\mks_eagle_usb_flash_drive\firmware.bin
rename_target([".pio\build\mks_eagle_usb_flash_drive\firmware.bin"], [".pio\build\mks_eagle_usb_flash_drive\firmware.elf"])
========================================= [SUCCESS] Took 18.24 seconds =========================================
mks_eagle_usb_flash_drive  SUCCESS   00:00:18.243
========================================= 1 succeeded in 00:00:18.243 =========================================
PACKAGES:
Found 13 compatible libraries
Dependency Graph
|   |-- SPI @ 1.0
|-- Adafruit NeoPixel @ 1.8.7
|   |-- Wire @ 1.0
|   |-- SPI @ 1.0
|-- SPI @ 1.0
|-- EEPROM @ 2.0.1
|-- Wire @ 1.0
|-- Servo @ 1.1.2
Marlin\src\HAL\STM32\../../inc/SanityCheck.h:2624:6: error: #error "Your FYSETC/MKS/BTT Mini Panel requires NEOPIXEL_TYPE to be NEO_RGB."
 2624 |     #error "Your FYSETC/MKS/BTT Mini Panel requires NEOPIXEL_TYPE to be NEO_RGB."
redefined
redefined
Marlin\src\HAL\STM32\tft\../../../inc/SanityCheck.h:2624:6: error: #error "Your FYSETC/MKS/BTT Mini Panel requires NEOPIXEL_TYPE to be NEO_RGB."
========================================= [FAILED] Took 14.30 seconds =========================================
mks_eagle_usb_flash_drive  FAILED    00:00:14.297
==================================== 1 failed, 0 succeeded in 00:00:14.297 ====================================
Quand je repasse : //#define NEOPIXEL_LED
La compilation se fait bien, mail du coup le retro-éclairage ne fonctionne pas.... je trouve pas sur GG....et suis à une vintaine de compil 😥
Si vous avez une piste ?
En fait j'ai trouvé...la solution était sous mes yeux, au cas ou si ça peux servir a quelqu’un d'autre 😁:
#define NEOPIXEL_LED //
#if ENABLED(NEOPIXEL_LED)//NEOPIXEL_LED
#define NEOPIXEL_TYPE NEO_RGB //NEO_GRBW // NEO_GRBW, NEO_RGBW, NEO_GRB, NEO_RBG, etc.
                                          // See https://github.com/adafruit/Adafruit_NeoPixel/blob/master/Adafruit_NeoPixel.h
  #define NEOPIXEL_PIN                4 // LED driving pin //ORIGINE
  //#define NEOPIXEL2_TYPE  NEOPIXEL_TYPE
  #define NEOPIXEL2_PIN               5 //ORIGINE
  #define NEOPIXEL_PIXELS              30 // Number of LEDs in the strip. (Longest strip when NEOPIXEL2_SEPARATE is disabled.)
  #define NEOPIXEL_IS_SEQUENTIAL          // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once.
  #define NEOPIXEL_BRIGHTNESS         127 // Initial brightness (0-255)
  #define NEOPIXEL_STARTUP_TEST         // Cycle through colors at startup
et activer dans adv.h :
#define LED_CONTROL_MENU
Bon dimanche
