Bonjour , je viens de me presenter sur le Forum .
Je suis donc débutant en impresson 3D , j'ai acheté est monté relativement facilement une ANYCUBIC KOSSEL Liear plus , mais a la mise en route j'ai un écran avec 2 lignes de carrés et le message lorsque je veux téléverser :::::     struct fpos_t {  .
J'aurais besoin d'aide s'il vous plait !
Cordialement Philippe
voilà même les message complet
Arduino : 1.8.2 (Windows 10), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Marlin.h:23:0,
                 from sketch\thermistortables.h:4,
                 from sketch\Configuration.h:731,
                 from C:\Users\goldo\Downloads\IMPRIMANTE 3D\soft carte SD\Eng-Kossel files 20161021\Firmware\For Plus\Anycubicplus\Anycubicplus.ino:41:
sketch\pins.h:453:0: warning: "Y_MAX_PIN" redefined
     #define Y_MAX_PIN          15
sketch\pins.h:452:0: note: this is the location of the previous definition
     #define Y_MAX_PIN          43
sketch\pins.h:502:0: warning: "CONTROLLERFAN_PIN" redefined
   #define CONTROLLERFAN_PIN    7
In file included from sketch\Configuration.h:730:0,
sketch\Configuration_adv.h:64:0: note: this is the location of the previous definition
 #define CONTROLLERFAN_PIN -1 //Pin used for the fan to cool controller (-1 to disable)
                 from sketch\Marlin_main.cpp:32:
                 from sketch\Marlin.h:22,
sketch\Marlin_main.cpp:2223:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
         LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF".");
In file included from sketch\SdFile.h:27:0,
                 from sketch\cardreader.h:8,
                 from sketch\Marlin_main.cpp:46:
SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
In file included from sketch\Marlin.h:10:0,
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
 __extension__ typedef long long fpos_t;
sketch\Marlin_main.cpp: In function 'void set_bed_level_equation_lsq(double*)':
sketch\Marlin_main.cpp:844:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     planeNormal.debug("planeNormal");
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Hello,
Je pencherai pour un probléme de compilation dû a une version trop récente de l'IDE Arduino que tu utilises.( Arduino : 1.8.2 )
Est ce celui préconisé ?
Sinon c'est assez rapide à tester .... désinstalles la version que tu utilises et essayes avec une version 1.0.x ( arduino-1.0.5-windows ou arduino-1.0.6-r2-windows par exemple)
Certains codes ont été écrit pour des versions antérieurs du compilateur arduino actuel (depuis la 1.6 de memoire) et sont maintenu dans l’état
et tiens nous informé ;)
Modifié (le) par La Bidouille
