nzangel
À propos de nzangel
  • Date de naissance 11/10/1980
    Villers-Les-Nancy
    Anycubic I3 Mega
Récompenses de nzangel
Favoris
  1. Gcode start & end
    Gcode START et END
    étant donné que cette question reviens régulièrement,  voici les Gcodes de démarrage et de fin , il y a mieux, il y a pire , mais ils font  très bien leur boulot sur l'anycubic :P
    voici un gcode de démarrage
    ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M109 S{print_temperature} ;Uncomment to add your own temperature line
    G21        ;metric values
    G90        ;absolute positioning
    M82        ;set extruder to absolute mode
    M107       ;start with the fan off
    G28 X0 Y0  ;move X/Y to min endstops
    G28 Z0     ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G92 E0                  ;zero the extruded length
    G1 F200 E10             ;extrude 10mm of feed stock
    G92 E0                  ;zero the extruded length again
    G1 F{travel_speed};Put printing message on LCD screen
    M117 Printing...
    G5 ;
    Gcode de fin
    ;End GCode
    M104 S0                     ;extruder heater off
    M140 S0                     ;heated bed heater off (if you have it)
    G91                                    ;relative positioning
    G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle to release some of the pressure
    G1 Z+1.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0                             ;move X/Y to min endstops so the head is out of the way
    G0 Y180 F3500       ; Ramene le plateau en avant afin de decoller la piece tranquillouuuuuuuu
    M84                         ;steppers off
    M107 ;
    ;{profile_string}
    si un modo peu passé par la est épinglé ce poste ça serais cool
