baldaquin
Récompenses de baldaquin
  1. Salut à tous @philippe en dessous le résultat de ma compil @dcro95 en ce qui me concerne j'utilise bien arduino 1.8.5 Merci sketch\Marlin_main.cpp: In function 'void gcode_M166()': sketch\Marlin_main.cpp:11061:31: warning: suggest parentheses around assignment used as truth value [-Wparentheses] if(mixer.gradient_flag = true) ^ sketch\configuration_store.cpp: In static member function 'static bool MarlinSettings::poweroff_save()': sketch\configuration_store.cpp:782:2: warning: no return statement in function returning non-void [-Wreturn-type] } ^ sketch\configuration_store.cpp: In static member function 'static bool MarlinSettings::poweroff_load()': sketch\configuration_store.cpp:812:3: warning: no return statement in function returning non-void [-Wreturn-type] } ^ sketch\configuration_store.cpp: In static member function 'static bool MarlinSettings::Fixed_parameter_save()': sketch\configuration_store.cpp:835:2: warning: no return statement in function returning non-void [-Wreturn-type] } ^ In file included from C:\Users\claude\Downloads\arduino-1.8.5-windows\arduino-1.8.5\hardware\arduino\avr\cores\arduino/Arduino.h:28:0, from sketch\MarlinConfig.h:38, from sketch\configuration_store.h:26, from sketch\configuration_store.cpp:190: sketch\configuration_store.cpp: In static member function 'static bool MarlinSettings::Fixed_parameter_load()': sketch\configuration_store.cpp:859:19: warning: unknown escape sequence: '\F' SERIAL_ECHOPAIR(" \r\Fixed parameter nbytes; crc error ", (uint32_t)stored_crc); ^ sketch\serial.h:60:40: note: in expansion of macro 'SERIAL_PROTOCOLPAIR' #define SERIAL_ECHOPAIR(pre,value) SERIAL_PROTOCOLPAIR(pre, value) ^ sketch\configuration_store.cpp:859:3: note: in expansion of macro 'SERIAL_ECHOPAIR' SERIAL_ECHOPAIR(" \r\Fixed parameter nbytes; crc error ", (uint32_t)stored_crc); ^ sketch\configuration_store.cpp:861:3: warning: no return statement in function returning non-void [-Wreturn-type] } ^ sketch\ultralcd.cpp: In function 'void lcd_mixer_gradient_mix_menu()': sketch\ultralcd.cpp:989:28: warning: statement has no effect [-Wunused-value] MENU_ITEM_ADDON_END(); ^ sketch\ultralcd.cpp:995:28: warning: statement has no effect [-Wunused-value] MENU_ITEM_ADDON_END(); ^ sketch\ultralcd.cpp: In function 'void lcd_mixer_edit_gradient_menu()': sketch\ultralcd.cpp:1014:28: warning: statement has no effect [-Wunused-value] MENU_ITEM_ADDON_END(); ^ sketch\ultralcd.cpp:1021:31: warning: suggest parentheses around assignment used as truth value [-Wparentheses] if(mixer.gradient_flag = true) ^ sketch\ultralcd.cpp:1030:28: warning: statement has no effect [-Wunused-value] MENU_ITEM_ADDON_END(); ^ sketch\ultralcd.cpp: In function 'void lcd_mixer_menu()': sketch\ultralcd.cpp:1083:28: warning: statement has no effect [-Wunused-value] MENU_ITEM_ADDON_END(); ^ Archiving built core (caching) in: C:\Users\claude\AppData\Local\Temp\arduino_cache_853598\core\core_arduino_avr_mega_cpu_atmega2560_adb847a52a45f7c7d1ff294c21144161.a Le croquis utilise 166144 octets (65%) de l'espace de stockage de programmes. Le maximum est de 253952 octets. Les variables globales utilisent 6095 octets (74%) de mémoire dynamique, ce qui laisse 2097 octets pour les variables locales. Le maximum est de 8192 octets.
  2. Merci Philippe pour ta prompte réponse. J'ai vu et regardé cette vidéo (et bien d'autres) une dizaine de fois. J'ai suivi pas à pas ce que fait le mec. Lui n'a aucune erreur quand il fait le check, moi j'en ai des tonnes (enfin quelques unes plutôt). Et j'utilise bien les mêmes fichiers, programmes et librairies et ce dans les mêmes versions. J'avoue que je ne comprends pas. J'en ai 13 en tout, situées dans Marlin_main.cpp, Configuration_store.cpp, et ultralcd.cpp. Il me crée bien le fichier core, mais je n'ose pas le téléverser dans l'imprimante. Tu peux me dire ce que tu en penses. Dois je continuer ou non ? Merci pour ta réponse. Claude Archiving built core (caching) in: C:\Users\claude\AppData\Local\Temp\arduino_cache_853598\core\core_arduino_avr_mega_cpu_atmega2560_adb847a52a45f7c7d1ff294c21144161.a Le croquis utilise 166144 octets (65%) de l'espace de stockage de programmes. Le maximum est de 253952 octets. Les variables globales utilisent 6095 octets (74%) de mémoire dynamique, ce qui laisse 2097 octets pour les variables locales. Le maximum est de 8192 octets.
  3. Bonjour à tous. Possédant une A20M, je l'ai reçue il y a 2 semaines avec le 3dtouch inclus. (Je ne m'y attendais pas). Si l'installation physique ne pose pas de problème, il n'en va pas de même avec le firmware. J'ai tout essayé. J'ai des tonnes d'erreurs avec Arduino, J'ai lu les forums, regardé des vidéos, etc......ça marche avec eux et pas avec moi....lol. Comment avez-vous fait pour y arriver ? Je ne comprends vraiment pas. Je planche dessus depuis que j'ai l'imprimante. Merci Claude
