thrlab@aol.com
    Alfawise u20
Récompenses de thrlab@aol.com
  1. oui,je viens de l'installer,mais il refuse toujours le "build" > Executing task: C:\Users\labussiere\.platformio\penv\Scripts\pio.exe run < Processing LPC1769 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1769; framework: arduino) -------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html PLATFORM: NXP Arduino LPC176x (0.1.3) > NXP LPC1769 HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink) PACKAGES: - framework-arduino-lpc176x 0.2.6 - toolchain-gccarmnoneeabi 1.90301.200702 (9.3.1) Converting Marlin.ino LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf LDF Modes: Finder ~ off, Compatibility ~ strict Found 1 compatible libraries Scanning dependencies... Dependency Graph |-- <Servo> 1.0.0 Building in release mode error:Command 'cmd /C dir E:\' returned non-zero exit status 1. error:Command 'cmd /C dir G:\' returned non-zero exit status 1. error:Command 'cmd /C dir H:\' returned non-zero exit status 1. Unable to find destination disk (Autodetect Error) Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1769/firmware.bin) manually to the appropriate disk Checking size .pio\build\LPC1769\firmware.elf Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [== ] 20.2% (used 6597 bytes from 32736 bytes) Flash: [== ] 18.8% (used 89192 bytes from 475136 bytes) ==================================== [SUCCESS] Took 10.43 seconds ==================================== Environment Status Duration ------------- -------- ------------ LPC1769 SUCCESS 00:00:10.427 ===================================== 1 succeeded in 00:00:10.427 =====================================
  2. Bonjour, Après installation d'une carte-mère SKR V1.4 TURBO et d'un écran TFT V2.0 sur ma U20,j'ai ce message d'erreur...Pas de communication entre l'écran et la carte-mère...Câblage et câbles contrôlés... Si quelqu'un a déjà eu ce problème ou connait une solution... Merci d'avance.
