Hanafi
Tout ce qui a été posté par Hanafi
  1. oui c'est un fichier recuperer ici sur le forum voici le fichier # This is a Klipper configuration for TronXY X5SA, with CXY-V6 # motherboard. # === FLASHING WITH STOCK BOOTLOADER === # You should make firmware for STM32F103 with bootloader offset # at 0x8008800 (Chitu v6 Bootloader) and serial (on USART1 PA10/PA9) # communication. # Use "./scripts/update_chitu.py ./out/klipper.bin ./out/update.cbd" # after make to generate update.cbd. Put `update.cbd` onto SD card, # and reboot the printer. It will be automatically installed, and you # will be able to update it this way. [mcu] serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 restart_method: command [printer] kinematics: corexy max_velocity: 300 max_accel: 3000 max_z_velocity: 25 max_z_accel: 30 [stepper_x] step_pin: PE5 dir_pin: !PE6 enable_pin: !PC13 microsteps: 16 rotation_distance: 20 endstop_pin: !PG10 position_endstop: -1 position_min: -1 position_max: 350 homing_speed: 50 homing_retract_dist: 10 second_homing_speed: 10.0 [stepper_y] step_pin: PE2 dir_pin: !PE3 enable_pin: !PE4 microsteps: 16 rotation_distance: 20 endstop_pin: !PA12 position_endstop: 0 position_max: 330 homing_retract_dist: 10 homing_speed: 50.0 second_homing_speed: 10.0 [stepper_z] step_pin: PB9 dir_pin: PE0 enable_pin: !PE1 microsteps: 16 rotation_distance: 4 endstop_pin: probe:z_virtual_endstop position_max: 400 position_min: -2 [extruder] step_pin: PB4 dir_pin: PB5 enable_pin: !PB8 microsteps: 16 rotation_distance: 35.520 nozzle_diameter: 0.400 filament_diameter: 1.750 heater_pin: PG12 sensor_type: ATC Semitec 104GT-2 sensor_pin: PA1 control: pid pid_Kp: 18.831 pid_Ki: 0.821 pid_Kd: 108.044 min_temp: 0 max_temp: 250 max_extrude_only_distance: 300 [heater_bed] heater_pin: PG11 sensor_type: EPCOS 100K B57560G104F sensor_pin: PA0 control: pid min_temp: 0 max_temp: 130 pid_Kp: 73.932 pid_Ki: 1.521 pid_Kd: 898.279 [heater_fan hotend_fan] pin: PG14 fan_speed: 0.5 [fan] pin: PG13 max_power: 0.5 [controller_fan drivers_fan] pin: PD6 [filament_switch_sensor sentinel] pause_on_runout: True runout_gcode: M25 switch_pin: PA15 [output_pin beeper] pin: PB0 [safe_z_home] home_xy_position: 165,165 speed: 50 z_hop: 10 z_hop_speed: 5 [bed_screws] screw1: 5,5 screw2: 165,5 screw3: 325,5 screw4: 5,325 screw5: 165,325 screw6: 325,325 [bed_mesh] speed: 120 probe_count: 5,5 horizontal_move_z: 5 algorithm: lagrange mesh_min : 20,20 mesh_max : 310,310 mesh_pps: 0 [probe] x_offset: -40 y_offset: 0 pin: !PG9 speed: 30 z_offset: 2
  2. mais coté octopi impossible de se connecter voici c que me donne sur terminal octopi: Changing monitoring state from "Offline" to "Opening serial connection" Connecting to port /tmp/printer, baudrate 115200 Changing monitoring state from "Opening serial connection" to "Connecting" Connected to: Serial<id=0x629be6d0, open=True>(port='/tmp/printer', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Repl: M110 N0 -> M110 Repl: M110 N0 -> M110 No answer from the printer within the connection timeout, trying another hello Repl: M110 N0 -> M110 There was a timeout while trying to connect to the printer Changing monitoring state from "Connecting" to "Offline" Connection closed, closing down monitor rebonjour, ca evolu apres avoir redemarer le raspberry ca ce conecte mais avec ce message d'erreur Le firmware de votre imprimante a signalé une erreur. Pour cette raison, le travail d'impression en cours sera annulé. Erreur signalée : Include file '/home/pi/mainsail_macros.cfg' does not exist
  3. comment peut en savoir si cela fonctionne avec klipper ? ya t-il un tuto pour la Tronxy X5SA pour klipper ?
  4. Merci palou34
    j'ai flashé la carte avec update.bcd recuperer sur klipper et ca a biper 2fois et plus rien apres.
    merci pour l'info
    1. palouf34
      palouf34
      je n'utilise pas cette méthode  mais cela devrait fonctionner.
      As tu relancé ton imprimante aprés le flashage pour que cela prenne bien en compte le nouveau firmware.
      autrement regarde sur le forum je t'ai répondus pour avoir plus de détail.
    2. palouf34
      palouf34
      Pour que je puisse t'aider plus facilement et pas trop pollué  le fils spécial klipper, peux tu ouvrir un fils directement dans la section imprimante sous section tronxy.
  5. Bonjour, En voulant faire l'update avec le fichier update.cbd ma tronxy n'affiche rien juste les Ventilo qui tourne.si quelqu'un possède le fichier .rar pour tronxy x5sa ça me dépannerait. Merci beaucoup
