killerjesse
Tout ce qui a été posté par killerjesse
  1. Apres 4 redémarrage et insérer à chaque fois le password wifi sur le pad je continue l'instal puis WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning. j'ai finalement kiauh et je lance pas la version 6. (sinon Error [ KIAUH ] ~~~~~~~~~~~~~~~~~~~~~ ║ ║ Klipper Installation And Update Helper ║ ║ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ║ ╚═══════════════════════════════════════════════════════╝ ╔═══════════════════════════════════════════════════════╗ ║ ~~~~~~~~~~~~~~~~~~~ [ Main Menu ] ~~~~~~~~~~~~~~~~~~~ ║ [ERROR] An unexpected error occured: list index out of range Traceback (most recent call last): File "/home/pi/kiauh/kiauh/core/menus/base_menu.py", line 225, in run self.__display_menu() File "/home/pi/kiauh/kiauh/core/menus/base_menu.py", line 219, in __display_menu self.print_menu() File "/home/pi/kiauh/kiauh/core/menus/main_menu.py", line 122, in print_menu self._fetch_status() File "/home/pi/kiauh/kiauh/core/menus/main_menu.py", line 85, in _fetch_status self.version = get_kiauh_version() File "/home/pi/kiauh/kiauh/utils/common.py", line 46, in get_kiauh_version lastest_tag: str = get_local_tags(Path(__file__).parent.parent)[-1] IndexError: list index out of range pi@speeder-pad:~$ deleted bluid , ok installer klipper ..... ###### Cloning Klipper from https://github.com/Klipper3d/klipper ... Cloning into '/home/pi/klipper'... remote: Enumerating objects: 69065, done. remote: Counting objects: 100% (31/31), done. remote: Compressing objects: 100% (17/17), done. error: RPC failed; curl 92 HTTP/2 stream 0 was not closed cleanly: CANCEL (err fatal: the remote end hung up unexpectedly fatal: early EOF fatal: index-pack failed #=======================================================# Cloning Klipper from https://github.com/Klipper3d/klipper failed! #=======================================================# Je relance la commande et la ca passe, j'ai insister plusieurs fois sur différente erreurs et enfin tout est relancer pour ma part.
  2. Idem , réinstallé depuis hier et même chose il perd la connexion et de nouveau problème pour installer Khiau (pas mal d'erreur dans les script à l'installation) aussi ma Nano V 3.0 sur la SR ayant rendu l'âme j'ai pris une MKS nano V 3.1 (aliexpress) pour remplacer et donc voulu refaire un full bluid complet Moonraker connection impossible etc... je vais tenter encore ce soir pour voir , si vous avez des idées ... speeder pad wifi , Flsun V400 , Flsun SR LGX lite Last login: Sat Nov 30 13:09:38 2024 from 10.0.50.167 pi@speeder-pad:~$ sudo apt-get install network-manager -y Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service → /lib/systemd/system/NetworkManager.service. Setting up network-manager-pptp (1.2.8-2) ... Processing triggers for libc-bin (2.31-0ubuntu9.16) ... Processing triggers for systemd (245.4-4ubuntu3.24) ... bloquer après cette étape, le pad fonctionne et le wifi aussi mais plus d'ip et mobaexterm donne : Network error: Connection timed out
  3. Salut étant sous la config Guilouz avec le speeder pads sur SR , V400 , ender3pro. je voulus teste la calibration des TMC 2209 mais impossible d'installer en SSH car je suis en multi instant et il veux installer dans printer_data (chez moi c'est printer_1_data ex) . quelqu'un as une idée pour modifier install.ssh bash ? voici une idée de la commande à faire en ssh wget -O - https://raw.githubusercontent.com/andrewmcgr/klipper_tmc_autotune/main/install.sh | bash j'ai le instal.ssh , quel serai la commande pour l'installer depuis un répertoire de klipper ? je mis connait peu en programmation ... (Cyrille si tu passe ...) merci
  4. https://github.com/Guilouz/Klipper-Flsun-Speeder-Pad/wiki/Measure-resonances-with-Fysetc-Portable-Input-Shaper Déjà eu plus d'info sur le nouveau passe PI ? même si depuis deux semaines les fichiers de Cyril était déjà configurer en 600/10000mm/s
  5. bon , vue le boulot hardcore que Cyril fournie , je me laisse tenter par l'image 1.2 du pads et refais un raz avec une ré Install total V400 ,SR.
  6. # Start and End G-Codes ################################################## [gcode_macro START_PRINT] description: Start G-Code gcode: LED_HOTEND_ON {% set BED_TEMP = params.BED_TEMP|default(60)|float %} {% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(210)|float %} G21 G90 M82 {% if printer.extruder.target != 0 %} M104 S{EXTRUDER_TEMP} {% else %} M104 S150 {% endif %} M140 S{BED_TEMP} {% if printer.toolhead.homed_axes != "xyz" %} G28 {% endif %} G1 Z370 F3000 G1 X-150 F3000 M190 S{BED_TEMP} M109 S{EXTRUDER_TEMP} G1 Z1 F3000 G1 X-150 Y0 Z0.4 G92 E0 G3 X0 Y-130 I150 J1 Z0.3 E30 F2000 G92 E0 G1 E-1 F2100
  7. j'ai pas compris l'intérêt du Macro (doit pas être douer) , je prend un STL sous cura et la je l'upload directement dans l'imprimante elle chauffe puis imprime . suis sous Cura 5.2.1 profil V400 fichier usb déjà essayé de copié ce code dans cura et tout déconne quand je le fais. mon Gcode actuel Gcode de démarrage G21 G90 M82 M107 T0 M140 S{material_bed_temperature} M104 S{material_print_temperature} T0 M190 S{material_bed_temperature} M109 S{material_print_temperature} T0 G28 BED_MESH_PROFILE LOAD="default" G1 F3000 Z1 G1 X-150 Y0 Z0.4 G92 E0 G3 X0 Y-130 I150 Z0.3 E30 F2000 G92 E0 Gcode de fin M107 T0 M104 S0 M104 S0 T1 M140 S0 G92 E0 G91 G1 E-1 F300 G1 Z+0.5 F6000 G28 G90 ;absolute positioning J'ai bien changer mes fichiers Printer et macro mis a jour hier 18/02/2023: Fixed V400 Hotend LED for some configuration files
  8. Salut , je suis sous le Klipper de Ciryl et j'ai remarque que le Led du hotend ne s'allume plus au démarrage de l'impression. j'ai regarder dans le fichier Pinter et macro mais à part lancer Neopixel et faire une erreur , je ne vois pas la ligne de commande (sauf dans le Macro Start Gcode )..... une idée ?
  9. Woooow je suis pas du tout avec ce profil moi Cura 5.1.0
  10. killerjesse
    FLSUN V400 CURA
    3.v400 config for CURA5.0.rar
  11. Ben j'ai tester et tout retenter mais rien n'y fais , KlipperScreen INVALIDE , MCU une fois sur deux (version klipper et Stm32 synchro) , impossible de connecter la SR , pas de menu avec avertissement pour le capteur Z (PEI défoncer lol) , etc... J'ai replacer la version 1.1 pad de Flsun et le firmware SR de flsun et la tout fonctionne (V400 port1 et SR port2 à configurer c'est pas en détection automatique sur les Usb) c'est fonctionnel , j'ai même trouver comment inverser le sens de rotation du LGX en suppriment " ! " devant le dir_pin: PD3 dans le fichier printer.cfg. mais les fonctions sont limiter PID , Mise à jour , etc.... en gros votre travail à tout les deux manque cruellement sur le firmware d'origine
  12. Super taff , je reprend le nouveau fichier 1.1 pad et je recommence . car la sa imprime mais toujours pas de Super racer et le Z offset est plutôt hardcore à calibrer etc....
  13. en attendent " Téléchargez cette image de restauration et décompressez-la : Lien supprimé à la demande de Flsun " ca fais pas trop ouverture je trouve. j'ai voulu recommencer toutes les étapes du root car je n'ai plus les messages pour les bed leveling quand il faut placer le capteur etc ...
  14. je l'ai fais , je vais tenter une réinstal complète
  15. Dans l'interface mainsail ? Oui Impossible de faire un bedleveling ou un mesh , j'ai refais la procédure par kiauh uninstal puis instal et la klipper et le reste est à jour mais l'erreur timelaps revient , après j'ai supprimer les lignes tilelaps un peu partout , mais impossible de faire un offset.
  16. Avertissement Moonraker L' option 'origin: https://github.com/Guilouz/KlipperScreen-Flsun-V400.git' de la section [update_manager] n'a pas été analysée. Cela peut provenir du fait que cette option n'est plus disponible ou que le chargement d'un module a créé une erreur. Dans le futur, ceci créera une erreur de démarrage. Pour info ma carte mère est déjà décalé du pneufit , donc un seconde évolution de la votre je pense. bon après avoir virer toutes les ligne Timelaps dans tout les fichier de config , je peux enfin imprimer par contre Klipper et Moonraker sont toujours en rouge Invalide
  17. pas de fichier "timelapse " dans le dossier config .... mais c'est pas le plus embêtant , je sais plus imprimer car MCU ne reconnais pas Klipper
  18. Le Root , c'est nickel fonctionne à 100% . nice joob par contre j'ai suivie la procedure de Cyril mais ..................................
  19. Super je télécharge et test voir si cela fonctionne , vous géré grave
  20. Salut , J'ai une V400 et impossible de rooter , tester 3 fichiers Update.sh . Une idée ? je cherche à connecter mes autres imprimante sur le pad et rien à faire sa fonctionne pas.
  21. Salut , présentation sommaire , Bricoleur de toujours, le monde des imprimantes 3d est bien utiles et la flexibilité de pouvoir a tout moment crée est fortement satisfaisant . Nom , qui ou pourquoi etc .... n'est pas intéressant je pense. j'ai acheter une Créality Ender3 pro il y as deux ans sur une opportunité et de suite j'ai aimer les possibilités , après moulte modifications j'ai eu envie d'une Flsun Super Racer pour aller un rien plus vite dans mes impressions . le 1 juillet j'était sur le site de Flsun pour prendre une V400 et que du bonheur pour l'instant. je suis ce site depuis un moment pour le contenue des articles et les informations du forum. voila , j'avais dit sommaire donc .....
