bianchifan
Tout ce qui a été posté par bianchifan
  1. I registered for the upgrade kit on Saturday, today i recived an answer.. Thank you for your continued support since the launch of the M1 Pro. We have received your submitted information, and our service team has confirmed its authenticity. SN: (706871FAC74F) has been successfully registered. Your M1Pro S1 upgrade accessory package is expected to ship from our European warehouse between January 15th and 20th, 2026. When I mailed my problems with the M1 some weeks ago it took more than 3 weeks for an answer! What happened?
  2. After more than 2 weeks I rceived an Answer from Artillery. Regarding the broken filament they are offering me a new extruder, the scratches should be my fault due to a wrong z-offset To get a new extruder I'm intended to complete a "Customer information filling form(3)".... The answer I mentioned above shows me, that they did not got the problem. Both faults are firmware faults. That does not help me, I'm on Linux Mint and Artillery Studio does not work properly with newest WINE. Last week I got a used iMac and upgraded it to "Sequioa" with the help of Opencore. Unfortunately the MAC Soft didn't run at all, its only for ARM processors..
  3. Please roll back some pages, MrMagouet described it carefully which soft? I've installed Mobileraker on my Sony xperia G8441 and it run. But not perfect. When trying some moves the build plate crashed against the hotend so I use the dashboard only Mobileraker on Sony xperia fluidd in browser - no problems!
  4. hall effect card ??? I updated yesterday afternoon.. the result after doing a manual ABL and from a second try out of the printer's memory with ABL activated Spagetti in in upper left corner..3rd try with reduced speed almost the same..spagetti in the upper left corner
  5. I'll build some when needed I'll give it a try when my actual job queue is finished. I'm busy with printing a couple of chameleon for a school class Yesterday I decided to finish a ~8h print job first before running the OTA FW update because my csreen told me Version "V" The printer starts fine after a cold boot. Today evening it did run normal, the FW displayed as 1.0.11 or similar. I do have some linux skills but I'm quite new to Klipper. ACtually I can log into the linux system and surf a little. I had to dig into system for searching, at this very moment I don't know where to find the configs.
  6. Correct! I beg your pardon, I'm German.
  7. I udpdated last night I got some display mismatch and a Klipper warning: MCU running at 167MHz instead of 168MHz.
  8. The M1 pro profile is included in the ORCA nitely since early September but now I#m also running the Beta since two weeks The webfam is supported !! and all other controls are supported! Very important: Emergency STOP due to missing Stop on the M1 front panel. Sadly a direct WLAN Transfer of the sliced GCode does not work :(, you have to export the Code first and use the import&Print button next to start the print. Greetings from Germany! I'm very happy the M1 pro is discussed here so I was able to reopen the UI port :) Another point.. I've also trouble with the extruder 3rd time I changed the filament, i stucks and did not work any more. I must it totally disassemble. The filament causing the failure was a tri-color PLA, it seems too week/soft compared to my very old (~ 10y) one color PLA sorts.
