AlexUnderKH
Tout ce qui a été posté par AlexUnderKH
  1. I`m waiting upgrade pack now. No printing. After changing spare parts I will try to do something. Added some thermophotos...
  2. You mean that patcher can work on S1 firmware (2.0...) after remove temp sensor fix? Its very important question for me. I want to use fluidd, if new table with new firmware not support community fix, I`ll try to downgrade stock firmware. I have 0.9, 0.3 its very very very good for this poor table Can you give me a link? I removed all supports on plastic frame LInk pls, if its possible. Or photo with dimensions. Its just for testing. Almost of my prints dont need very good tolerance, but I need to understand what tolerance printer can give to me. Me too) Oh, I understood. You mean videocam. Yeah, its a shit) I turn off it, because I can use it only throw Artillery Studio, which is working on notebook near the printer) I have termovision camera. I`ll try to look at the printer throw it later, and give pictures/video to this community, may be I`ll see something interesting on it
  3. With 2.0...firmware? Very interesting ratio) I changed only nozzle from 0.4 to 0.6, no leaks for now, another hotend parts is stock. You mean thermocamera? How about stepper_z? May be flow is so low because z steps is bad? In my situation I have 2 printers on the same table... Ok, thanks. I will try low temperature
  4. I guess 3mf will be easier. Cube.3mf I printed that models many times on Flashforge. Difference is the slicer, because I use Artillery studio for M1 Pro, and Orca for Flashforge. Problem with vertical walls was solved after cutting out the plastic stops in the table base and manually leveling it (now the difference is 0.9 mm, and the corners are more or less even) I`m waiting for Upgrade kit now. 1-2 weeks and I`ll receive it (I believe)) I tried to downgrade firmware with my handmade cable, but nothing happend. Drivers ok, first steps ok, but when it comes to flashing the firmware itself, an error appears. The firmware program from the official website didn't work at all (there was a config read error, which prevented it from even being detected by Maskrom). So I found a slightly more recent version, which at least detected Maskrom, and I was able to at least try. After a couple of attempts, I gave up. I'll wait for their cable.
  5. Thanks. My english is much better) I joined to group, and I will ping you later. Thanks I understood. I use different usual PETG on Flashforge. Some of them printing on 25-28 cubic millimeters. But I have problem on M1 Pro with the same plastics. Pressure Advance, poor seam quality, problem with retract etc. I set extruder temperature to 255-260. PA 0.03, retract 2.0 mm 40 mm/s. But detail is worse, than I can print on Flashforge. I add some photo) Problem with vertical printing solved.
  6. Bonjour. Veuillez m'excuser d'avance pour les fautes d'orthographe ; je suis ukrainien et mon français est très sommaire, à part quelques expressions. J'utilise donc Google Traduction. J'ai commandé cette imprimante avant de trouver cette discussion, il est donc trop tard pour changer quoi que ce soit. La renvoyer coûte tellement cher que cela n'a aucun intérêt, et je ne sais même pas si c'est possible, car l'imprimante devrait traverser la frontière de l'UE. Bref, j'essaie de la faire fonctionner. Auparavant, j'imprimais très bien (et je continue d'imprimer) avec une Flashforge AD5M. Comparée à cette daube, elle imprime parfaitement. J'ai acheté et installé une buse de 0,6 mm sur la M1, et j'attends le kit de mise à niveau. Pour l'instant, j'imprime uniquement avec du PETGE, mais les résultats sont loin d'être satisfaisants. Le PETGE de Sanlu se comporte très mal. Peut-être avez-vous déjà imprimé avec ce filament et pourriez-vous partager vos paramètres ? En résumé, je pense qu'il serait judicieux de partager quelques paramètres d'impression qui ont fonctionné, car nous avons tous eu des déconvenues avec nos achats. Cordialement, Alexander.
