Salut, j'essaie de flasher ma CR-10 avec Marlin et j'ai un problème. J'ai bien inclus la biblio U8glib, chargé la carte sanguino ... mais quand j'essaie de compiler marlin sur Arduino IDE j'obtiens ces message d'erreur : Pouvez vous m'aider
Arduino : 1.8.6 (Windows 10), Carte : "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
In file included from sketch\HAL.h:33:0,
                 from sketch\MarlinConfig.h:39,
                 from sketch\Sd2Card.cpp:29:
Sd2Card.h:100:39: error: pasting "/* SPI Master In Slave Out pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_MISO_PIN MISO_PIN       // SPI Master In Slave Out pin
sketch\fastio.h:86:42: note: in definition of macro '_SET_INPUT'
 #define _SET_INPUT(IO)        CBI(DIO ## IO ## _DDR, DIO ## IO ## _PIN)
sketch\Sd2Card.cpp:316:3: note: in expansion of macro 'SET_INPUT'
   SET_INPUT(SPI_MISO_PIN);
sketch\Sd2Card.cpp:316:13: note: in expansion of macro 'SPI_MISO_PIN'
Sd2Card.h:100:39: error: pasting "/* SPI Master In Slave Out pin*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:86:61: note: in definition of macro '_SET_INPUT'
Sd2Card.h:99:39: error: pasting "/* SPI Master Out Slave In pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_MOSI_PIN MOSI_PIN       // SPI Master Out Slave In pin
sketch\fastio.h:87:42: note: in definition of macro '_SET_OUTPUT'
 #define _SET_OUTPUT(IO)       SBI(DIO ## IO ## _DDR, DIO ## IO ## _PIN)
sketch\Sd2Card.cpp:317:3: note: in expansion of macro 'SET_OUTPUT'
   SET_OUTPUT(SPI_MOSI_PIN);
sketch\Sd2Card.cpp:317:14: note: in expansion of macro 'SPI_MOSI_PIN'
Sd2Card.h:99:39: error: pasting "/* SPI Master Out Slave In pin*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:87:61: note: in definition of macro '_SET_OUTPUT'
Sd2Card.h:101:39: error: pasting "/* SPI Clock pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_SCK_PIN SCK_PIN         // SPI Clock pin
sketch\Sd2Card.cpp:318:3: note: in expansion of macro 'SET_OUTPUT'
   SET_OUTPUT(SPI_SCK_PIN);
sketch\Sd2Card.cpp:318:14: note: in expansion of macro 'SPI_SCK_PIN'
Sd2Card.h:101:39: error: pasting "/* SPI Clock pin*/" and "_PIN" does not give a valid preprocessing token
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Voici des copains :
Modifié (le) par Yo'
