Je cherche a installer  Marlin 1.1.9 sur mon Anet A8 , je viens de remplacer la buse d'origine par une E3D V6.
J'ai suivi un tuto sur youtube (derbo)
Mon port est bien détecter avec le bon périphérique
J'ai bien mis les fichiers au bon endroit etc .
Seulement voila j'ai un message d'erreur dès la vérification:
Arduino : 1.8.6 (Windows 10), Carte : "Anet V1.0"
In file included from sketch\HAL.h:33:0,
                 from sketch\MarlinConfig.h:39,
                 from sketch\Sd2Card.cpp:29:
Sd2Card.h:100:39: error: pasting "/* SPI Master In Slave Out pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_MISO_PIN MISO_PIN       // SPI Master In Slave Out pin
sketch\fastio.h:86:42: note: in definition of macro '_SET_INPUT'
 #define _SET_INPUT(IO)        CBI(DIO ## IO ## _DDR, DIO ## IO ## _PIN)
sketch\Sd2Card.cpp:316:3: note: in expansion of macro 'SET_INPUT'
   SET_INPUT(SPI_MISO_PIN);
sketch\Sd2Card.cpp:316:13: note: in expansion of macro 'SPI_MISO_PIN'
Sd2Card.h:100:39: error: pasting "/* SPI Master In Slave Out pin*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:86:61: note: in definition of macro '_SET_INPUT'
Sd2Card.h:99:39: error: pasting "/* SPI Master Out Slave In pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_MOSI_PIN MOSI_PIN       // SPI Master Out Slave In pin
sketch\fastio.h:87:42: note: in definition of macro '_SET_OUTPUT'
 #define _SET_OUTPUT(IO)       SBI(DIO ## IO ## _DDR, DIO ## IO ## _PIN)
sketch\Sd2Card.cpp:317:3: note: in expansion of macro 'SET_OUTPUT'
   SET_OUTPUT(SPI_MOSI_PIN);
sketch\Sd2Card.cpp:317:14: note: in expansion of macro 'SPI_MOSI_PIN'
Sd2Card.h:99:39: error: pasting "/* SPI Master Out Slave In pin*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:87:61: note: in definition of macro '_SET_OUTPUT'
Sd2Card.h:101:39: error: pasting "/* SPI Clock pin*/" and "_DDR" does not give a valid preprocessing token
   #define SPI_SCK_PIN SCK_PIN         // SPI Clock pin
sketch\Sd2Card.cpp:318:3: note: in expansion of macro 'SET_OUTPUT'
   SET_OUTPUT(SPI_SCK_PIN);
sketch\Sd2Card.cpp:318:14: note: in expansion of macro 'SPI_SCK_PIN'
Sd2Card.h:101:39: error: pasting "/* SPI Clock pin*/" and "_PIN" does not give a valid preprocessing token
exit status 1
Je vous remercie pour votre aide.
