Bonjour à tous & à toutes,
ça fait un moment que je n'arrive pas à flasher (pour activer le mess bed leveling) une Ender 3 Pro (carte mère Creality 1.1.5) ... mais, quoi que je fasse, j'ai toujours la même erreur avrdude: stk500_recv(): programmer is not responding
bref, je ne sais plus quoi faire, donc si vous avez une solution, n'hésitez pas 😉 merci d'avance ...
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/sanguino_atmega1284p.html
PLATFORM: Atmel AVR (3.1.0) > Sanguino ATmega1284p (16MHz)
HARDWARE: ATMEGA1284P 16MHz, 16KB RAM, 124KB Flash
DEBUG: Current (simavr) On-board (simavr)
PACKAGES:
 - framework-arduino-avr 5.1.0
 - tool-avrdude 1.60300.200527 (6.3.0)
 - toolchain-atmelavr 1.50400.190710 (5.4.0)
Converting Marlin.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <U8glib-HAL> 0.4.3
|   |-- <Wire> 1.0
|   |-- <SPI> 1.0
|-- <Wire> 1.0
|-- <SPI> 1.0
|-- <EEPROM> 2.0
|-- <SoftwareSerial> 1.0
Building in release mode
Checking size .pio/build/melzi_optimized/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [===       ]  28.5% (used 4670 bytes from 16384 bytes)
Flash: [==========]  99.0% (used 125752 bytes from 126976 bytes)
Configuring upload protocol...
AVAILABLE: arduino
CURRENT: upload_protocol = arduino
Looking for upload port...
Auto-detected: /dev/cu.usbserial-1410
Uploading .pio/build/melzi_optimized/firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x67
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x67
avrdude done.  Thank you.
*** [upload] Error 1
================================== [FAILED] Took 17.28 seconds ==================================
Environment      Status    Duration
melzi_optimized  FAILED    00:00:17.280
  • 2 months later...
finalement, comme je ne trouvais pas de réponse, j'ai compilé le marlin bugfix 2.0.x avec visual code studio et flashé l'imprimante via octoprint ... mais
a) erreur n° 1
eeprom version error initialize eeprom ignore or reset
b) erreur n° 2
Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!
la solution
a) https://reprap.org/forum/read.php?415,869818
b) j'ai remis la version de base, à savoir marlin 1.1.8 et ça a réglé le problème ... vais essayer avec la "Latest release", pour voir ce que ça donne
voila, c'est tout pour l'instant
allez, ciao & bon confinement 😉
La version Marlin bugfix est rarement une bonne idée à moins de vouloir délibérément participer au développement  de Marlin.
Dans ce message tu trouveras les fichiers de config (Marlin V2.0.7.2) pour une Ender 3 carte V1.1.4 avec BLTouch. D'après @SyFizz_, le firmware est opérationnel avec octoprint. Tu pourrais modifier les fichiers pour les adapter à ta config (v1.1.5, Bltouch?,...). J'ajoute le fichier cardreader.cpp à remplacer dans Marlin\src\sd pour corriger le bug de reprise après arrêt d'alimentation.
cardreader.cpp
Modifié (le) par remibora
@remibora merci beaucoup ... non, pour l'instant juste la carte 1.1.5, j'ai pas mis de bl touch, vu que je n'arrivais pas à flasher l'imprimante
