Je prépare une compilation de Marlin 2 pour installer une MKS EAGLE sur ma CR10s
J'ai récupérer sur le GitHub de makerbase le marlin préconfigurer et je l'adapte a ma CR10s
mais j'ai une erreur de compilation et je ne comprends pas la raison, si vous avez une piste a me donner :
Warning! Ignore unknown configuration option `monitor_flags` in section [env]
Warning! `src_filter` configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:DUE] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_build_flags` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_flags` instead
Warning! `src_filter` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_build_flags` configuration option in section [env:simulator_windows] is deprecated and will be removed in the next release! Please use `build_src_flags` instead
Warning! `src_filter` configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:STM32F103CB_malyan] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Processing mks_eagle_usb_flash_drive (platform: ststm32@~12.1; board: marlin_STM32F407VGT6_CCM; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/marlin_STM32F407VGT6_CCM.html
PLATFORM: ST STM32 (12.1.1) > STM32F407VG (128k RAM, 64k CCM RAM, 1024k Flash
HARDWARE: STM32F407VGT6 168MHz, 128KB RAM, 1MB Flash
DEBUG: Current (jlink) External (jlink, stlink)
PACKAGES:
 - framework-arduinoststm32 @ 0.0.0
 - framework-cmsis @ 2.50501.200527 (5.5.1)
 - toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 13 compatible libraries
Scanning dependencies...
Dependency Graph
|-- lvgl @ 6.1.1
|-- qr_encode @ 0.0.0+20201117144502
|-- TMCStepper @ 0.7.3
|   |-- SoftwareSerial @ 1.0
|   |-- SPI @ 1.0
|-- SPI @ 1.0
|-- EEPROM @ 2.0.1
|-- IWatchdog @ 1.0.0
|-- Wire @ 1.0
|-- Servo @ 1.1.2
Building in release mode
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\MarlinCore.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\control\M999.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\control\T.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\eeprom\M500-M504.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\digipot\M907-M910.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\powerloss\M1000.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\powerloss\M413.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\trinamic\M122.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\trinamic\M569.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\trinamic\M906.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\feature\trinamic\M911-M914.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\gcode.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\gcode_d.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\geometry\G92.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\geometry\M206_M428.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\host\M110.cpp.o
Compiling .pio\build\mks_eagle_usb_flash_drive\src\src\gcode\host\M113.cpp.o
In file included from Marlin\src\inc/MarlinConfigPre.h:37,
                 from Marlin\src\inc/MarlinConfig.h:28,
                 from Marlin\src\MarlinCore.h:24,
                 from Marlin\src\MarlinCore.cpp:31:
Marlin\src\MarlinCore.cpp: In function 'void manage_inactivity(bool)':
Marlin\src\MarlinCore.cpp:662:1: error: invalid conversion from 'const char*' to 'uint8_t' {aka 'unsigned char'} [-fpermissive]
  662 |           REPEAT(E_STEPPERS, _CASE_EN);
      | const char*
Marlin\src\inc/../core/macros.h:592:24: note: in definition of macro 'EVAL1'
  592 | #define EVAL1(V...)    V
Marlin\src\inc/../core/macros.h:591:30: note: in expansion of macro 'EVAL1'
  591 | #define EVAL2(V...)    EVAL1(EVAL1(V))
Marlin\src\inc/../core/macros.h:590:24: note: in expansion of macro 'EVAL2'
  590 | #define EVAL4(V...)    EVAL2(EVAL2(V))
Marlin\src\inc/../core/macros.h:591:24: note: in expansion of macro 'EVAL1'
Marlin\src\inc/../core/macros.h:590:30: note: in expansion of macro 'EVAL2'
Marlin\src\inc/../core/macros.h:589:24: note: in expansion of macro 'EVAL4'
  589 | #define EVAL8(V...)    EVAL4(EVAL4(V))
Marlin\src\inc/../core/macros.h:589:30: note: in expansion of macro 'EVAL4'
Marlin\src\inc/../core/macros.h:588:24: note: in expansion of macro 'EVAL8'
  588 | #define EVAL16(V...)   EVAL8(EVAL8(V))
Marlin\src\inc/../core/macros.h:588:30: note: in expansion of macro 'EVAL8'
Marlin\src\inc/../core/macros.h:581:24: note: in expansion of macro 'EVAL16'
  581 | #define EVAL(V...)     EVAL16(V)
Marlin\src\inc/../core/macros.h:639:33: note: in expansion of macro 'EVAL'
  639 | #define REPEAT_S(S,N,OP)        EVAL(_REPEAT(S,SUB##S(N),OP))
Marlin\src\inc/../core/macros.h:205:29: note: in expansion of macro 'THIRD'
  205 | #define ___TERN(P,V...)     THIRD(P,V)              // If first argument has a comma, A. Else B.
Marlin\src\inc/../core/macros.h:205:37: note: in expansion of macro '_OPTARG'
Marlin\src\inc/../core/macros.h:204:29: note: in expansion of macro '___TERN'
  204 | #define __TERN(T,V...)      ___TERN(_CAT(_NO,T),V)  // Prepend '_NO' to get '_NOT_0' or '_NOT_1'
Marlin\src\inc/../core/macros.h:203:29: note: in expansion of macro '__TERN'
  203 | #define _TERN(E,V...)       __TERN(_CAT(T_,E),V)    // Prepend 'T_' to get 'T_0' or 'T_1'
Marlin\src\inc/../core/macros.h:202:29: note: in expansion of macro '_TERN'
  202 | #define TERN_(O,A)          _TERN(_ENA_1(O),,A)     // OPTION ? 'A' : '<nul>'
Marlin\src\inc/../core/macros.h:208:29: note: in expansion of macro 'TERN_'
  208 | #define OPTARG(O,A...)      TERN_(O,DEFER4(_OPTARG)(A))
Marlin\src\inc/Conditionals_LCD.h:610:21: note: in expansion of macro 'OPTARG'
  610 | #define E_OPTARG(N) OPTARG(HAS_MULTI_EXTRUDER, N)
Marlin\src\module/stepper.h:619:55: note: in expansion of macro 'E_OPTARG'
  619 |     #define AXIS_IS_ENABLED(N,V...) axis_is_enabled(N E_OPTARG(#V))
Marlin\src\MarlinCore.cpp:661:59: note: in expansion of macro 'AXIS_IS_ENABLED'
  661 |           #define _CASE_EN(N) case N: oldstatus = stepper.AXIS_IS_ENABLED(E_AXIS, N); stepper.ENABLE_EXTRUDER(N); break;
Marlin\src\inc/../core/macros.h:624:3: note: in expansion of macro '_CASE_EN'
  624 |   _RPT_OP(_RPT_I)                                             \
Marlin\src\inc/../core/macros.h:639:38: note: in expansion of macro '_REPEAT'
Marlin\src\inc/../core/macros.h:640:33: note: in expansion of macro 'REPEAT_S'
  640 | #define REPEAT(N,OP)            REPEAT_S(0,N,OP)
Marlin\src\MarlinCore.cpp:662:11: note: in expansion of macro 'REPEAT'
Marlin\src\module/stepper.h:589:83: note:   initializing argument 2 of 'static bool Stepper::axis_is_enabled(AxisEnum, uint8_t)'
  589 |     static inline bool axis_is_enabled(const AxisEnum axis E_OPTARG(const uint8_t eindex=0)) {
Marlin\src\inc/../core/macros.h:571:26: note: in definition of macro 'THIRD'
  571 | #define THIRD(a,b,c,...) c
Marlin\src\module/stepper.h:589:60: note: in expansion of macro 'E_OPTARG'
      | const char*
Marlin\src\inc/../core/macros.h:628:20: note: in expansion of macro '_REPEAT'
  628 | #define __REPEAT() _REPEAT
Marlin\src\inc/../core/macros.h:184:22: note: in expansion of macro '_IF_1'
  184 | #define _CAT(a,V...) a##V
*** [.pio\build\mks_eagle_usb_flash_drive\src\src\MarlinCore.cpp.o] Error 1
Si j'ai bien compris l'erreur me renvoi  ça dans marlincore.ccp :
	"resource": "/e:/Mks-Robin-Nano-Marlin2.0-Firmware-master/Marlin/src/MarlinCore.cpp",
	"owner": "cpp",
	"severity": 8,
	"message": "invalid conversion from 'const char*' to 'uint8_t' {aka 'unsigned char'} [-fpermissive]",
	"startLineNumber": 662,
	"startColumn": 1,
	"endLineNumber": 662,
	"endColumn": 1
   #else // !SWITCHING_EXTRUDER
        bool oldstatus;
        switch (active_extruder) {
          default:
      #endif
Modifié (le) par fran6p
Modération: «blocs» de texte déplacé dans la balise prévue pour
Je te conseille de partir sur une version stable de marlin et non la version bugfix proposée par MKS. Dans ce sujet, tu trouveras les fichiers de config pour une configuration similaire à la tienne (carte MKS eagle mais écran probablement différent,...) qui se basent sur Marlin V2.1.1.
Ok merci, je reprends tout à zéro, si ça marche pas je vais tenter klipper, mais j’ai l impression qu’il faut tout réapprendre 😅
En attendant je vous souhaite une bonne et heureuse nouvelle année 😁
Juste pour confirmer que le problème viens bien de la version de Marlin proposer par MKS, plus de soucis de compilation !
Mais du coup je teste en parallèle klipper 😬
Je me ferais plus avoir ! Merci 🙏
