bonjour a tous je suis novice dans l'affaire 3D
un ami m'a prete son imprimante le temps de son demenagement mais il ne l'a jamais regle avec les option du coup je dois me demerder lol.
voici les reglages sur le spad dans printer.cfg
# !Ender-3 V2 ABL
# printer_size: 220x220x250
# version: 3.6
# This file contains pin mappings for the stock 2020 Creality Ender-3 V2+CRtouch
# To use this config, during "make menuconfig" select the
# STM32F103 with a "28KiB bootloader" and serial (on USART1 PA10/PA9)
# communication.
# If you prefer a direct serial connection, in "make menuconfig"
# select "Enable extra low-level configuration options" and select
# serial (on USART3 PB11/PB10), which is broken out on the 10 pin IDC
# cable used for the LCD module as follows:
# 3: Tx, 4: Rx, 9: GND, 10: VCC
# Flash this firmware by copying "out/klipper.bin" to a SD card and
# turning on the printer with the card inserted. The firmware
# filename must end in ".bin" and must not match the last filename
# that was flashed.
# See docs/Config_Reference.md for a description of parameters.
###fluidd set
[include cx_printer.cfg]
[display_status]
[pause_resume]
[gcode_macro PAUSE]
description: Pause the actual running print
rename_existing: PAUSE_BASE
# change this if you need more or less extrusion
variable_extrude: 1.0
gcode:
  ##### read E from pause macro #####
  {% set E = printer["gcode_macro PAUSE"].extrude|float %}
  ##### set park positon for x and y #####
  # default is your max posion from your printer.cfg
  {% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
  {% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
  ##### calculate save lift position #####
  {% set max_z = printer.toolhead.axis_maximum.z|float %}
  {% set act_z = printer.toolhead.position.z|float %}
  {% if act_z < (max_z - 2.0) %}
      {% set z_safe = 2.0 %}
  {% else %}
      {% set z_safe = max_z - act_z %}
  {% endif %}
  ##### end of definitions #####
  PAUSE_BASE
  G91
  {% if printer.extruder.can_extrude|lower == 'true' %}
    G1 E-{E} F2100
  {% else %}
    {action_respond_info("Extruder not hot enough")}
  {% endif %}
  {% if "xyz" in printer.toolhead.homed_axes %}
    G1 Z{z_safe} F900
    G90
    G1 X{x_park} Y{y_park} F6000
  {% else %}
    {action_respond_info("Printer not homed")}
  {% endif %}
[gcode_macro RESUME]
description: Resume the actual running print
rename_existing: RESUME_BASE
gcode:
  #### get VELOCITY parameter if specified ####
  {% if 'VELOCITY' in params|upper %}
    {% set get_params = ('VELOCITY=' + params.VELOCITY)  %}
  {%else %}
    {% set get_params = "" %}
  {% endif %}
    G91
    G1 E{E} F2100
  {% else %}
  {% endif %}
  RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
gcode:
  TURN_OFF_HEATERS
    G91
    G1 Z4.5 F300
    G90
  {% else %}
  {% endif %}
    G28 X Y
    G1 Y{y_park} F2000
    M84
  CANCEL_PRINT_BASE
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
microsteps: 16
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 240
homing_speed: 80
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
microsteps: 16
endstop_pin: ^PA6
position_endstop: 0
position_max: 236
homing_speed: 80
[stepper_z]
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
microsteps: 16
rotation_distance: 8
endstop_pin: probe:z_virtual_endstop  #enable to use bltouch
# endstop_pin: ^PA7   #disable to use bltouch
# position_endstop: 0.0  #disable to use bltouch
position_max: 250
position_min: -10
homing_speed: 4
second_homing_speed: 1
homing_retract_dist: 2.0
[extruder]
max_extrude_only_distance: 1000.0
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
microsteps: 16
rotation_distance: 76.190
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PC5
control: pid
# tuned for stock hardware with 200 degree Celsius target
pid_Kp: 22.865
pid_Ki: 1.292
pid_Kd: 101.178
min_temp: 0
max_temp: 300
[idle_timeout]
timeout: 172800
[verify_heater extruder]
check_gain_time: 200
hysteresis: 5
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
# tuned for stock hardware with 50 degree Celsius target
pid_Kp: 73.008
pid_Ki: 2.421
pid_Kd: 550.294
min_temp: 0
max_temp: 130
[fan]
pin: PA0
[fan_generic extruder_partfan]
# pin: PB15
pin: PC6
#max_power:
#shutdown_speed:
#cycle_time:
#hardware_pwm:
#kick_start_time:
#off_below:
#tachometer_pin:
#tachometer_ppr:
#tachometer_poll_interval:
#   See the "fan" section for a description of the above parameters.
#heater: extruder
#   Name of the config section defining the heater that this fan is
#   associated with. If a comma separated list of heater names is
#   provided here, then the fan will be enabled when any of the given
#   heaters are enabled. The default is "extruder".
#heater_temp: 50.0
#   A temperature (in Celsius) that the heater must drop below before
#   the fan is disabled. The default is 50 Celsius.
#fan_speed: 1.0
#   The fan speed (expressed as a value from 0.0 to 1.0) that the fan
#   will be set to when its associated heater is enabled. The default
#   is 1.0
[heater_fan heater_partfan]
pin: PB14
#max_power:
#shutdown_speed:
#cycle_time:
#hardware_pwm:
#kick_start_time:
#off_below:
#tachometer_pin:
#tachometer_ppr:
#heater: extruder
#heater_temp: 50.0
#fan_speed: 1.0
#   is 1.0
[mcu]
serial: /dev/serial/by-id/usb_serial_1
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
# max_accel_to_decel: 7000
max_z_velocity: 5
square_corner_velocity: 5.0
max_z_accel: 100
# [mcu rpi]
# serial: /tmp/klipper_host_mcu
# [adxl345]
# cs_pin: rpi:None
# spi_speed: 2000000
# spi_bus: spidev2.0
# [resonance_tester]
# accel_chip: adxl345
# accel_per_hz: 70
# probe_points:
#     117.5,117.5,10
[input_shaper]
shaper_type_x = mzv
shaper_freq_x = 89.8
shaper_type_y = mzv
shaper_freq_y = 35.2
[bltouch]
sensor_pin: ^PB1
control_pin: PB0
x_offset: -25.0
y_offset: -35.0
#z_offset: 0
speed: 20
samples: 1
sample_retract_dist: 8.0
stow_on_each_sample = false #high speed for bltoch
[safe_z_home]
home_xy_position: 110,110 # Change coordinates to the center of your print bed
speed: 200
z_hop: 10               # Move up 10mm
z_hop_speed: 10
[bed_mesh]
probe_count = 5,5
algorithm = bicubic
speed: 120
mesh_min: 10,20         #need to handle head distance with bl_touch
mesh_max: 200.2,191.5       #max probe range
# probe_count: 5,5
fade_start: 1
fade_end: 10
fade_target: 0
# algorithm: bicubic
[bed_screws]
screw1:35,55
screw1_name:1
screw2:200,55
screw2_name:2
screw3:200,200
screw3_name:3
screw4:35,200
screw4_name:4
[exclude_object]
# [delayed_gcode AUTOSTART]
# initial_duration: 1
# gcode:
#   TURN_ON_MOTORS
[gcode_arcs]
#resolution: 1.0
[gcode_macro BED_LEVEL]
gcode:
    G28
    BED_MESH_CALIBRATE
[gcode_macro Z_AXI_CALIBRATE]
gcode:
    G28
    PROBE_CALIBRATE
[gcode_macro SHAPER]
gcode:
    G28
    SHAPER_CALIBRATE
[gcode_macro PID]
gcode:
    G28
    PID_CALIBRATE HEATER=extruder TARGET=200
    PID_CALIBRATE HEATER=heater_bed TARGET=60
[gcode_macro Press_Advance_short]
gcode:
    SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY=1 ACCEL=500
    TUNING_TOWER COMMAND=SET_PRESSURE_ADVANCE PARAMETER=ADVANCE START=0 FACTOR=.005
[gcode_macro Press_Advance_long]
gcode:
    TUNING_TOWER COMMAND=SET_PRESSURE_ADVANCE PARAMETER=ADVANCE START=0 FACTOR=.020
# [output_pin my_led]
# pin: PB12
#   The pin to configure as an output. This parameter must be
#   provided.
#pwm: False
#   Set if the output pin should be capable of pulse-width-modulation.
#   If this is true, the value fields should be between 0 and 1; if it
#   is false the value fields should be either 0 or 1. The default is
#   False.
#static_value:
#   If this is set, then the pin is assigned to this value at startup
#   and the pin can not be changed during runtime. A static pin uses
#   slightly less ram in the micro-controller. The default is to use
#   runtime configuration of pins.
#value:
#   The value to initially set the pin to during MCU configuration.
#   The default is 0 (for low voltage).
#shutdown_value:
#   The value to set the pin to on an MCU shutdown event. The default
#   is 0 (for low voltage).
#maximum_mcu_duration:
#   The maximum duration a non-shutdown value may be driven by the MCU
#   without an acknowledge from the host.
#   If host can not keep up with an update, the MCU will shutdown
#   and set all pins to their respective shutdown values.
#   Default: 0 (disabled)
#   Usual values are around 5 seconds.
#cycle_time: 0.100
#   The amount of time (in seconds) per PWM cycle. It is recommended
#   this be 10 milliseconds or greater when using software based PWM.
#   The default is 0.100 seconds for pwm pins.
#hardware_pwm: False
#   Enable this to use hardware PWM instead of software PWM. When
#   using hardware PWM the actual cycle time is constrained by the
#   implementation and may be significantly different than the
#   requested cycle_time. The default is False.
#scale:
#   This parameter can be used to alter how the 'value' and
#   'shutdown_value' parameters are interpreted for pwm pins. If
#   provided, then the 'value' parameter should be between 0.0 and
#   'scale'. This may be useful when configuring a PWM pin that
#   controls a stepper voltage reference. The 'scale' can be set to
#   the equivalent stepper amperage if the PWM were fully enabled, and
#   then the 'value' parameter can be specified using the desired
#   amperage for the stepper. The default is to not scale the 'value'
#   parameter.
[include timelapse.cfg]
[include cx_gmcro.cfg]
#*# <---------------------- SAVE_CONFIG ---------------------->
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*#     0.092500, 0.012500, 0.060000, 0.035000, -0.052500
#*#     -0.052500, -0.060000, -0.032500, -0.042500, -0.172500
#*#     -0.067500, -0.115000, -0.115000, -0.157500, -0.217500
#*#     -0.037500, -0.075000, -0.067500, -0.127500, -0.217500
#*#     0.010000, -0.060000, -0.055000, -0.077500, -0.185000
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 10.0
#*# max_x = 200.0
#*# min_y = 20.0
#*# max_y = 191.0
#*# [bltouch]
#*# z_offset = 2.150
voici les parametrages cura
CE3E3V2__3DBenchy.gcode
help me please 😞
Modifié (le) par fran6p
  • Solution
J'ai édité ton message pour placer le contenu du ficher printer.cfg dans une section «citation» () => c'est plus lisible 😉
