Bonjour et bonnes fêtes de fin d'année à tous !
Je travaille sur une Creality CR10 S5 avec la carte silencieuse creality V2.1 .
Malheureusement je ne parviens pas à configurer Marlin pour faire fonctionner mon capteur de fin de filament.
Voici ce que j'ai comme configuration.h
* RAMPS-based boards use SERVO3_PIN for the first runout sensor.
 * For other boards you may need to define FIL_RUNOUT_PIN, FIL_RUNOUT2_PIN, etc.
#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
  #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500.
  #define NUM_RUNOUT_SENSORS   1          // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each.
  #define FIL_RUNOUT_PIN 2 // Creality CR-10 S5 stock sensor
  #define FIL_RUNOUT_STATE     LOW       // Pin state indicating that filament is NOT present.
  #define FIL_RUNOUT_PULLUP               // Use internal pullup for filament runout pins.
  //#define FIL_RUNOUT_PULLDOWN           // Use internal pulldown for filament runout pins.
  //#define WATCH_ALL_RUNOUT_SENSORS      // Execute runout script on any triggering sensor, not only for the active extruder.
                                          // This is automatically enabled for MIXING_EXTRUDERs.
  // Override individually if the runout sensors vary
  //#define FIL_RUNOUT1_STATE LOW
  //#define FIL_RUNOUT1_PULLUP
  //#define FIL_RUNOUT1_PULLDOWN
  //#define FIL_RUNOUT2_STATE LOW
  //#define FIL_RUNOUT2_PULLUP
  //#define FIL_RUNOUT2_PULLDOWN
  //#define FIL_RUNOUT3_STATE LOW
  //#define FIL_RUNOUT3_PULLUP
  //#define FIL_RUNOUT3_PULLDOWN
  //#define FIL_RUNOUT4_STATE LOW
  //#define FIL_RUNOUT4_PULLUP
  //#define FIL_RUNOUT4_PULLDOWN
  //#define FIL_RUNOUT5_STATE LOW
  //#define FIL_RUNOUT5_PULLUP
  //#define FIL_RUNOUT5_PULLDOWN
  //#define FIL_RUNOUT6_STATE LOW
  //#define FIL_RUNOUT6_PULLUP
  //#define FIL_RUNOUT6_PULLDOWN
  //#define FIL_RUNOUT7_STATE LOW
  //#define FIL_RUNOUT7_PULLUP
  //#define FIL_RUNOUT7_PULLDOWN
  //#define FIL_RUNOUT8_STATE LOW
  //#define FIL_RUNOUT8_PULLUP
  //#define FIL_RUNOUT8_PULLDOWN
  // Commands to execute on filament runout.
  // With multiple runout sensors use the %c placeholder for the current tool in commands (e.g., "M600 T%c")
  // NOTE: After 'M412 H1' the host handles filament runout and this script does not apply.
  #define FILAMENT_RUNOUT_SCRIPT "M600"
  // After a runout is detected, continue printing this length of filament
  // before executing the runout script. Useful for a sensor at the end of
  // a feed tube. Requires 4 bytes SRAM per sensor, plus 4 bytes overhead.
  //#define FILAMENT_RUNOUT_DISTANCE_MM 25
  #ifdef FILAMENT_RUNOUT_DISTANCE_MM
    // Enable this option to use an encoder disc that toggles the runout pin
    // as the filament moves. (Be sure to set FILAMENT_RUNOUT_DISTANCE_MM
    // large enough to avoid false positives.)
    //#define FILAMENT_MOTION_SENSOR
  #endif
#endif
Configuration_adv.h
// @section advanced pause
 * Advanced Pause for Filament Change
 *  - Adds the G-code M600 Filament Change to initiate a filament change.
 *  - This feature is required for the default FILAMENT_RUNOUT_SCRIPT.
 * Requirements:
 *  - For Filament Change parking enable and configure NOZZLE_PARK_FEATURE.
 *  - For user interaction enable an LCD display, HOST_PROMPT_SUPPORT, or EMERGENCY_PARSER.
 * Enable PARK_HEAD_ON_PAUSE to add the G-code M125 Pause and Park.
#define ADVANCED_PAUSE_FEATURE
#if ENABLED(ADVANCED_PAUSE_FEATURE)
  #define PAUSE_PARK_RETRACT_FEEDRATE         60  // (mm/s) Initial retract feedrate.
  #define PAUSE_PARK_RETRACT_LENGTH           10  // (mm) Initial retract.
                                                  // This short retract is done immediately, before parking the nozzle.
  #define FILAMENT_CHANGE_UNLOAD_FEEDRATE     41  // (mm/s) Unload filament feedrate. This can be pretty fast.
  #define FILAMENT_CHANGE_UNLOAD_ACCEL        25  // (mm/s^2) Lower acceleration may allow a faster feedrate.
  #define FILAMENT_CHANGE_UNLOAD_LENGTH      400  // (mm) The length of filament for a complete unload.
                                                  //   For Bowden, the full length of the tube and nozzle.
                                                  //   For direct drive, the full length of the nozzle.
                                                  //   Set to 0 for manual unloading.
  #define FILAMENT_CHANGE_SLOW_LOAD_FEEDRATE   6  // (mm/s) Slow move when starting load.
  #define FILAMENT_CHANGE_SLOW_LOAD_LENGTH     0  // (mm) Slow length, to allow time to insert material.
                                                  // 0 to disable start loading and skip to fast load only
  #define FILAMENT_CHANGE_FAST_LOAD_FEEDRATE  41  // (mm/s) Load filament feedrate. This can be pretty fast.
  #define FILAMENT_CHANGE_FAST_LOAD_ACCEL     25  // (mm/s^2) Lower acceleration may allow a faster feedrate.
  #define FILAMENT_CHANGE_FAST_LOAD_LENGTH     0  // (mm) Load length of filament, from extruder gear to nozzle.
  #define ADVANCED_PAUSE_CONTINUOUS_PURGE         // Purge continuously up to the purge length until interrupted.
  #define ADVANCED_PAUSE_PURGE_FEEDRATE        3  // (mm/s) Extrude feedrate (after loading). Should be slower than load feedrate.
  #define ADVANCED_PAUSE_PURGE_LENGTH        150  // (mm) Length to extrude after loading.
                                                  //   Set to 0 for manual extrusion.
                                                  //   Filament can be extruded repeatedly from the Filament Change menu
                                                  //   until extrusion is consistent, and to purge old filament.
  #define ADVANCED_PAUSE_RESUME_PRIME          0  // (mm) Extra distance to prime nozzle after returning from park.
  //#define ADVANCED_PAUSE_FANS_PAUSE             // Turn off print-cooling fans while the machine is paused.
                                                  // Filament Unload does a Retract, Delay, and Purge first:
  #define FILAMENT_UNLOAD_PURGE_RETRACT       10  // (mm) Unload initial retract length.
  #define FILAMENT_UNLOAD_PURGE_DELAY       5000  // (ms) Delay for the filament to cool after retract.
  #define FILAMENT_UNLOAD_PURGE_LENGTH         0  // (mm) An unretract is done, then this length is purged.
  #define FILAMENT_UNLOAD_PURGE_FEEDRATE      25  // (mm/s) feedrate to purge before unload
  #define PAUSE_PARK_NOZZLE_TIMEOUT           45  // (seconds) Time limit before the nozzle is turned off for safety.
  #define FILAMENT_CHANGE_ALERT_BEEPS          6  // Number of alert beeps to play when a response is needed.
  #define PAUSE_PARK_NO_STEPPER_TIMEOUT           // Enable for XYZ steppers to stay powered on during filament change.
  //#define FILAMENT_CHANGE_RESUME_ON_INSERT      // Automatically continue / load filament when runout sensor is triggered again.
  //#define PAUSE_REHEAT_FAST_RESUME              // Reduce number of waits by not prompting again post-timeout before continuing.
  #define PARK_HEAD_ON_PAUSE                      // Park the nozzle during pause and filament change.
  #define HOME_BEFORE_FILAMENT_CHANGE             // If needed, home before parking for filament change
  #define FILAMENT_LOAD_UNLOAD_GCODES           // Add M701/M702 Load/Unload G-codes, plus Load/Unload in the LCD Prepare menu.
  //#define FILAMENT_UNLOAD_ALL_EXTRUDERS         // Allow M702 to unload all extruders above a minimum target temp (as set by M302)
#endif
Salut et bienvenue sur le forum,
L'idéal serait d'envoyer le Gcode M119 dans Pronterface (plus d'infos ici) ou autre logiciel, depuis un ordinateur relié à l'imprimante en USB.
Sans filament, l'état devrait être OPEN et passer en triggered lorsque le filament est présent.
A quel endroit as-tu branché le câble du détecteur sur la carte-mère?
En passant, je note que dans le fichier exemple, la constante FIL_RUNOUT_STATE est à HIGH alors que tu as mis LOW 🤔
Petite remarque, la ligne suivante est inutile puisque la constante est déjà définie dans le fichier de définition de la carte:
Grand merci pour ce début de réponse. 😄
En effet, j'ai oublié de dire que lorsque je fais le test Gcode M119, que le filament soit dans le capteur ou non, j'ai toujours "filament: open".
Je vais essayer avec FIL_RUNOUT_STATE --> HIGH
et dé-commenter la ligne #define FIL_RUNOUT_PIN 2 // Creality CR-10 S5 stock sensor.
Le capteur est branché sur la carte mère creality silent board V2.1  ici (en rouge) :
Modifié (le) par MathF
Il y a 2 heures, MathF a dit :
il se pourrait que ton détecteur ne fonctionne pas. As-tu un multimètre pour le tester?
c'est utile si la logique est inversée. Dans ton cas, cela devrait pas résoudre ton problème 🥴
j'imagine qu'il faut lire "commenter". 🤨
Si le port X+ avait un problème, tu pourrais essayer de brancher ton détecteur sur le port Y+ et changer la définition de FIL_RUNOUT_PIN dans le fichier Marlin\src\pins\ramps\pins_RAMPS_CREALITY.h:
#define FIL_RUNOUT_PIN                         15
