je ne comprend pas , a chaque impression  avant il me fesait un palpage du plateau.
et depuis hier plus rien avec des messages, mes plus de nivelement pendant le print.
voir photo
[gcode_macro G32]
gcode:
    #{% set mesh_center = printer["gcode_macro _ADAPTIVE_MESH_VARIABLES]"].mesh_center %}
    G90
    #STATUS_HOMING
    G28
    #QUAD_GANTRY_LEVEL
    clean_nozzle            ;Clean nozzle
    #STATUS_HOMING
    G28 Z
    #clean_nozzle            ;Clean nozzle
    CALIBRATE_Z BED_POSITION={mesh_center}
    ADAPTIVE_BED_MESH
  [gcode_macro PRINT_END]
  #gcode:
  #[gcode_macro UNLOAD_FILAMENT]
   #gcode:
  #[gcode_macro LOAD_FILAMENT]
   #gcode:
 [gcode_macro CANCEL_PRINT]
 #gcode:
#[resonance_tester]
#accel_chip : adxl345
# accel_chip : adxl345
#probe_points :
# 100,100,20 # un exemple
[gcode_macro START_PRINT]
gcode:
    {% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(190)|float %}
    {% set BED_TEMP = params.BED_TEMP|default(60)|float %}
    {% set FL_SIZE = params.SIZE|default("0_0_0_0")|string %}
    G32              ;home all axes
    ADAPTIVE_BED_MESH SIZE={FL_SIZE}
    #BED_MESH_PROFILE =default
    BED_MESH_PROFILE LOAD=default
    G90
    #Reset the G-Code Z offset (adjust Z offset if needed)
    SET_GCODE_OFFSET Z=-0.080
    # Home the printer
    M140 S{BED_TEMP} ; set bed temp
    M104 S{EXTRUDER_TEMP} ; set extruder temp
    M105
    M190 S{BED_TEMP} ; wait bed temp
    # M104 S{EXTRUDER_TEMP} ; set extruder temp
    #M105 //dd
    M109 S{EXTRUDER_TEMP}
    G28  #;Home all Axes # G28
    # Move the nozzle near the bed
    #G1 Z5 F3000
    # Move the nozzle very close to the bed
    # Wait for bed to reach temperature
    # Set and wait for nozzle to reach temperature
    # Reset Extruder
    G92 E0
    # Move Z Axis up
    G1 Z2 F200
    G1 Z5.1 F700
    # Move to start position
    G1 X6 Y20 Z0.28 F1000.0
    # Draw the first line
    G1 X6 Y200.0 Z0.28 F1000.0 E15
    # Move to side a little
    G1 X6.4 Y200.0 Z0.28 F1000.0
    # Draw the second line
    G1 X6.4 Y20 Z0.50 F1000.0 E30 #//dd
    # Reset Extruder
    G1 Z3.0 F1000 #//dd
    # Print message on LCD
Il y a 4 heures, Andre Casagrandi a dit :
Je ne comprend pas , a chaque impression  avant il me fesait un palpage du plateau.
As tu fais des modifs dans tes fichiers de configuration ? Car on croirait qu'il manque des infos dans ces fichiers
bonjours je pense que c'est depuis que j'ai voulu installer Kamp , j'ai mis a jours le rpi3.
voile ce que j'ai rajouté
Installation:
La façon la plus propre et la plus simple de commencer à utiliser KAMP est d’utiliser l’utilitaire Update Manager de Moonraker. Cela vous permettra d’installer facilement et de fournir de futures mises à jour lorsque d’autres fonctionnalités seront déployées !
  1. ssh dans votre appareil Klipper et exécutez les commandes suivantes :
     cd
     git clone https://github.com/kyleisah/Klipper-Adaptive-Meshing-Purging.git
     ln -s ~/Klipper-Adaptive-Meshing-Purging/Configuration printer_data/config/KAMP
     cp ~/Klipper-Adaptive-Meshing-Purging/Configuration/KAMP_Settings.cfg ~/printer_data/config/KAMP_Settings.cfg
Le fichier de configuration (KAMP_Settings.cfg) est bien inclus dans le printer.cfg (étape 4 de l'installation) ?
4. After you [include] the features you want, be sure to restart your firmware so those inclusions take effect. Don't forget to add [include KAMP_Settings.cfg] to your printer.cfg!
Sinon, juste pour info, pour tout problème lié à Klipper, le plus simple est de joindre les journaux (klipper.log, moonraker.log), ils contiennent généralement les informations permettant de dépanner les problèmes rencontrés.
