[CR10S PRO V1] problème de réglage de hauteur de la buse sous Klipper Mainsail
Bonjour je vient de passer sous Klipper Mainsail ma cr10s pro V1 avec mon Raspberry 3b+(je débute complet sous celui çi)
je ne parvient pas a faire le réglage de la feuille de papier sous cette interface J'arrive a descendre le Z en effet mas pas suffisamment
# This file contains pin mappings for the Creality CR-10S Pro. To use
# this config, the firmware should be compiled for the AVR atmega2560.
[include mainsail.cfg]
[mcu]
serial: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AG0JSFC4-if00-port0
[virtual_sdcard]
path: /home/noebe/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
[stepper_x]
step_pin: PF0
dir_pin: PF1
enable_pin: !PD7
rotation_distance: 40
microsteps: 16
full_steps_per_rotation: 200
endstop_pin: ^PE5
position_endstop: 0
position_min: 0
position_max: 300
homing_speed: 50
homing_retract_dist: 5
[stepper_y]
step_pin: PF6
dir_pin: !PF7
enable_pin: !PF2
microsteps: 16
endstop_pin: ^PJ1
position_endstop: 0
position_min: 0
position_max: 310
homing_speed: 50
[stepper_z]
step_pin: PL3
dir_pin: !PL1
enable_pin: !PK0
rotation_distance: 8
microsteps: 16
endstop_pin: probe:z_virtual_endstop
position_min: -1
position_max: 351
[extruder]
step_pin: PA4
dir_pin: PA6
enable_pin: !PA2
rotation_distance: 22.900
microsteps: 16
nozzle_diameter: 0.400
filament_diameter: 1.750
max_extrude_only_distance: 500.0
max_extrude_only_velocity: 70.0
max_extrude_only_accel: 1000.0
heater_pin: PB4
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PK5
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_extrude_temp: 170
min_temp: 5
max_temp: 275
[heater_bed]
heater_pin: PH5
sensor_pin: PK6
control: pid
pid_Kp: 690.34
pid_Ki: 111.47
pid_Kd: 1068.83
min_temp: 5
max_temp: 140
[fan]
pin: PH6
[printer]
kinematics: cartesian
max_velocity: 200
max_accel: 1500
max_z_velocity: 10
max_z_accel: 100
[probe]
pin: PD3
x_offset: -27
y_offset: 0
#z_offset: 0
speed: 4.0
samples: 2
sample_retract_dist: 3.0
[safe_z_home]
home_xy_position: 177,155
speed: 80.0
z_hop: 10.0
z_hop_speed: 5.0
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 10, 10
mesh_max: 263, 300
probe_count: 5,5
fade_start: 1
fade_end: 10
[filament_switch_sensor e0_sensor]
switch_pin: PE4
pause_on_runout: False
runout_gcode:
  PAUSE_PARK
[pause_resume]
[respond]
default_type: echo
#[save_variables]
#filename: ~/variables.cfg
#[delayed_gcode macros_initialize]
#initial_duration: 1
#gcode:
#  INITIALIZE_VARIABLE VARIABLE=park_x VALUE=20
#  INITIALIZE_VARIABLE VARIABLE=park_y VALUE=290
#  INITIALIZE_VARIABLE VARIABLE=bowden_len VALUE=400
#[include macros/*.cfg]
#*# <---------------------- SAVE_CONFIG ---------------------->
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*#     0.068750, -0.048750, -0.082500, -0.078750, -0.025000
#*#     -0.050000, -0.113750, -0.103750, -0.072500, 0.010000
#*#     -0.141250, -0.133750, -0.102500, -0.068750, 0.011250
#*#     -0.148750, -0.133750, -0.087500, -0.048750, 0.035000
#*#     -0.002500, -0.062500, -0.067500, -0.045000, 0.068750
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 10.0
#*# max_x = 263.0
#*# min_y = 10.0
#*# max_y = 300.0
#*# [probe]
#*# z_offset = 1.550
Modifié (le) par Ber59
ajout printer.cfg
Il y a 3 heures, Ber59 a dit :
position_min: -1
Insuffisant avec un Bltouch ou similaire (augmenter cette valeur -4 , -5).
