J'ai démarré Mainsail tout à l'heure, et j'ai eu un message d'erreur en marron disant "Klipper corrupt", difficile à réparer. C'est pas du mot pour mot, mais ça voulait dire ça.
J'ai tenté la récupération deux fois, résultat:
14:57:37 	Git Repo klipper: Attempting Repo Recovery...
14:57:37 	Git Repo klipper: Starting Clone Recovery...
14:57:37 	Cloning into '/home/pi/.klipper_repo_backup'...
14:59:08 	error: RPC failed; curl 92 HTTP/2 stream 3 was not closed cleanly: CANCEL (err 8)
14:59:08 	error: 3994 bytes of body are still expected
14:59:08 	fetch-pack: unexpected disconnect while reading sideband packet
14:59:08 	fatal: early EOF
14:59:08 	fatal: fetch-pack: invalid index-pack output
14:59:10 	fatal: could not fetch 996dfcaa303c363bc8a10741d77b1b18553113b7 from promisor remote
14:59:10 	warning: Clone succeeded, but checkout failed.
14:59:10 	You can inspect what was checked out with 'git status'
14:59:10 	and retry with 'git restore --source=HEAD :/'
14:59:11 	Git Repo klipper: Git Clone Failed
14:59:11 	Error Recovering klipper
14:59:11 	Git Clone Error
Du coup, j'ai supprimé Klipper avec Kiauh, et lancé une installation par la suite. Pas moyen:
|     ~~~~~~~~~~~~~~~~~ [ KIAUH ] ~~~~~~~~~~~~~~~~~     |
|        Klipper Installation And Update Helper         |
###### Initializing Klipper installation ...
| Please select your preferred Python version.          |
| The recommended version is Python 3.x.                |
|  1) [Python 3.x]  (recommended)                       |
|  2) [Python 2.7]  (legacy)                            |
|                       B) « Back                       |
###### Select Python version: 1
   [➔] Python 3.x
| Please select the number of Klipper instances to set  |
| up. The number of Klipper instances will determine    |
| the amount of printers you can run from this host.    |
| WARNING:                                              |
| Setting up too many instances may crash your system.  |
|                       B) « Back                       |
###### Number of Klipper instances to set up: 1
   [➔] Instance count: 1
###### Installing single Klipper instance ...
###### Checking for the following dependencies:
● git
[✓ OK] Dependencies already met!
###### Cloning Klipper from https://github.com/Klipper3d/klipper ...
Cloning into '/home/pi/klipper'...
remote: Enumerating objects: 61988, done.
remote: Counting objects: 100% (96/96), done.
remote: Compressing objects: 100% (68/68), done.
error: RPC failed; curl 56 GnuTLS recv error (-9): Error decoding the received TLS packet.
error: 5310 bytes of body are still expected
fatal: early EOF
 failed!
pi@raspberrypi:~ $
Je ne sais pas interpréter ce message 🤨
Eh bien à force d'essayer, ça a fini par passer. J'en déduis donc que le message concerne un souci de connexion.
J'ai maintenant un problème de connexion de Klipper.
Sur l'écran LCD: Moonraker: connecté, Klipper: déconnecté
Sur Mainsail:
Moonraker ne peut pas se connecter à Klipper!
Veuillez vérifier que le service Klipper fonctionne et que l'adresse klippy_uds_address est correctement configurée dans le fichier moonraker.conf..
Comment je peux connecter Klipper?
