Bonjour aujourd'hui j'ai voulue reflasher mon imprimante 3d Dagoma disco ultimate équipé D'une MKS gen L et j'ai eu la mauvaise surprise d'avoir des erreur que je n'arrive pas a comprendre .
Pourriez vous m'aider a régler se problème ?
Merci d'avance pour votre réponse
platformio run --silent -e mega2560
In file included from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39:0,
                 from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28,
                 from Marlin\src\HAL\AVR\HAL.cpp:24:
Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1692:0: warning: "FILAMENT_RUNOUT_SCRIPT" redefined
   #define FILAMENT_RUNOUT_SCRIPT "M600"
Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1645:0: note: this is the location of the previous definition
                 from Marlin\src\HAL\AVR\HAL_SPI.cpp:34:
                 from Marlin\src\HAL\AVR\MarlinSerial.cpp:39:
                 from Marlin\src\HAL\AVR\eeprom.cpp:24:
                 from Marlin\src\HAL\AVR\Servo.cpp:55:
                 from Marlin\src\HAL\AVR\fast_pwm.cpp:24:
In file included from Marlin\src\HAL\shared\../../inc/MarlinConfigPre.h:39:0,
                 from Marlin\src\HAL\shared\Delay.h:24,
                 from Marlin\src\HAL\shared\Delay.cpp:23:
Marlin\src\HAL\shared\../../inc/../../Configuration.h:1692:0: warning: "FILAMENT_RUNOUT_SCRIPT" redefined
Marlin\src\HAL\shared\../../inc/../../Configuration.h:1645:0: note: this is the location of the previous definition
In file included from Marlin\src\HAL\shared\../../core/../inc/MarlinConfigPre.h:39:0,
                 from Marlin\src\HAL\shared\../../core/../inc/MarlinConfig.h:28,
                 from Marlin\src\HAL\shared\../../core/serial.h:24,
                 from Marlin\src\HAL\shared\MinSerial.h:24,
                 from Marlin\src\HAL\shared\MinSerial.cpp:22:
Marlin\src\HAL\shared\../../core/../inc/../../Configuration.h:1692:0: warning: "FILAMENT_RUNOUT_SCRIPT" redefined
Marlin\src\HAL\shared\../../core/../inc/../../Configuration.h:1645:0: note: this is the location of the previous definition
                 from Marlin\src\HAL\shared\../../inc/MarlinConfig.h:28,
                 from Marlin\src\HAL\shared\HAL.cpp:27:
                 from Marlin\src\HAL\shared\esp_wifi.cpp:23:
                 from Marlin\src\HAL\shared\servo.cpp:53:
In file included from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:51:0,
Marlin\src\HAL\AVR\../../inc/Changes.h:611:4: error: #error "DISABLE_INACTIVE_[XYZIJKUVWE] is now DISABLE_IDLE_[XYZIJKUVWE]."
In file included from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:52:0,
Marlin\src\HAL\AVR\../../inc/SanityCheck.h:76:4: error: #error "Your Configuration.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration.h."
Marlin\src\HAL\AVR\../../inc/SanityCheck.h:81:4: error: #error "Your Configuration_adv.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration_adv.h."
Marlin\src\HAL\AVR\../../inc/SanityCheck.h:358:6: error: #error "Alternative LCD_INFO_SCREEN_STYLE requires 20x4 Character LCD."
Marlin\src\HAL\AVR\../../inc/SanityCheck.h:382:4: error: #error "SET_PROGRESS_MANUALLY requires at least one of SET_PROGRESS_PERCENT, SET_REMAINING_TIME, SET_INTERACTION_TIME to be enabled."
compilation terminated due to -fmax-errors=5.
*** [.pio\build\mega2560\src\src\HAL\AVR\HAL_SPI.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\AVR\HAL.cpp.o] Error 1
In file included from Marlin\src\inc/MarlinConfigPre.h:39:0,
                 from Marlin\src\inc/MarlinConfig.h:28,
                 from Marlin\src\MarlinCore.h:24,
                 from Marlin\src\MarlinCore.cpp:31:
Marlin\src\inc/../../Configuration.h:1692:0: warning: "FILAMENT_RUNOUT_SCRIPT" redefined
Marlin\src\inc/../../Configuration.h:1645:0: note: this is the location of the previous definition
*** [.pio\build\mega2560\src\src\HAL\AVR\MarlinSerial.cpp.o] Error 1
In file included from Marlin\src\HAL\shared\../../core/../inc/MarlinConfig.h:51:0,
Marlin\src\HAL\shared\../../core/../inc/Changes.h:611:4: error: #error "DISABLE_INACTIVE_[XYZIJKUVWE] is now DISABLE_IDLE_[XYZIJKUVWE]."
In file included from Marlin\src\HAL\shared\../../inc/MarlinConfig.h:51:0,
                 from Marlin\src\HAL\shared\Delay.cpp:25:
Marlin\src\HAL\shared\../../inc/Changes.h:611:4: error: #error "DISABLE_INACTIVE_[XYZIJKUVWE] is now DISABLE_IDLE_[XYZIJKUVWE]."
*** [.pio\build\mega2560\src\src\HAL\AVR\Servo.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\AVR\eeprom.cpp.o] Error 1
In file included from Marlin\src\HAL\shared\../../core/../inc/MarlinConfig.h:52:0,
Marlin\src\HAL\shared\../../core/../inc/SanityCheck.h:76:4: error: #error "Your Configuration.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration.h."
Marlin\src\HAL\shared\../../core/../inc/SanityCheck.h:81:4: error: #error "Your Configuration_adv.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration_adv.h."
Marlin\src\HAL\shared\../../core/../inc/SanityCheck.h:358:6: error: #error "Alternative LCD_INFO_SCREEN_STYLE requires 20x4 Character LCD."
Marlin\src\HAL\shared\../../core/../inc/SanityCheck.h:382:4: error: #error "SET_PROGRESS_MANUALLY requires at least one of SET_PROGRESS_PERCENT, SET_REMAINING_TIME, SET_INTERACTION_TIME to be enabled."
In file included from Marlin\src\HAL\shared\../../inc/MarlinConfig.h:52:0,
Marlin\src\HAL\shared\../../inc/SanityCheck.h:76:4: error: #error "Your Configuration.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration.h."
Marlin\src\HAL\shared\../../inc/SanityCheck.h:81:4: error: #error "Your Configuration_adv.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration_adv.h."
Marlin\src\HAL\shared\../../inc/SanityCheck.h:358:6: error: #error "Alternative LCD_INFO_SCREEN_STYLE requires 20x4 Character LCD."
Marlin\src\HAL\shared\../../inc/SanityCheck.h:382:4: error: #error "SET_PROGRESS_MANUALLY requires at least one of SET_PROGRESS_PERCENT, SET_REMAINING_TIME, SET_INTERACTION_TIME to be enabled."
*** [.pio\build\mega2560\src\src\HAL\shared\MinSerial.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\shared\Delay.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\AVR\fast_pwm.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\shared\HAL.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\shared\esp_wifi.cpp.o] Error 1
*** [.pio\build\mega2560\src\src\HAL\shared\servo.cpp.o] Error 1
In file included from Marlin\src\inc/MarlinConfig.h:51:0,
Marlin\src\inc/Changes.h:611:4: error: #error "DISABLE_INACTIVE_[XYZIJKUVWE] is now DISABLE_IDLE_[XYZIJKUVWE]."
In file included from Marlin\src\inc/MarlinConfig.h:52:0,
Marlin\src\inc/SanityCheck.h:76:4: error: #error "Your Configuration.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration.h."
Marlin\src\inc/SanityCheck.h:81:4: error: #error "Your Configuration_adv.h file is for an old version of Marlin. Downgrade Marlin or upgrade your Configuration_adv.h."
Marlin\src\inc/SanityCheck.h:358:6: error: #error "Alternative LCD_INFO_SCREEN_STYLE requires 20x4 Character LCD."
Marlin\src\inc/SanityCheck.h:382:4: error: #error "SET_PROGRESS_MANUALLY requires at least one of SET_PROGRESS_PERCENT, SET_REMAINING_TIME, SET_INTERACTION_TIME to be enabled."
*** [.pio\build\mega2560\src\src\MarlinCore.cpp.o] Error 1
======================================================================== [FAILED] Took 6.77 seconds ========================================================================
Environment    Status    Duration
mega2560       FAILED    00:00:06.772
=================================================================== 1 failed, 0 succeeded in 00:00:06.772 ===================================================================
Tu n'utilises pas les bons fichiers de configurations.h et adv.h pour la version Marlin utilisée.
Modifié (le) par medmed
