Ils ont ajouté dans la version v1.0.8 via un script shell lancé en tant que service, des optimisations niveau système pour répartir la charge des MCUs sur les deux cœurs du Rockchip RK3308; modifié aussi le niceness de «l'IA»…
Le fichier tuning.sh (~/QD_Q2/bin/tuning.sh) :
#!/bin/bash
### BEGIN INIT INFO
# Provides:       tuning
# Required-Start:    $local_fs $remote_fs $network $syslog $named
# Required-Stop:     $local_fs $remote_fs $network $syslog $named
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: tunes CPU performance and process affinity
# Description:       tunes CPU performance and process affinity
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
TASKSET=/usr/bin/taskset
RENICE=/usr/bin/renice
CPUFREQSET=/usr/bin/cpufreq-set
CPUFREQINFO=/usr/bin/cpufreq-info
test -x $TASKSET || exit 0
test -x $RENICE || exit 0
set_irq_affinity() {
        TTYS4=`grep ttyS4 < /proc/interrupts | awk -F: '{print $1}' | tr -d '[:blank:]'`
        # TTYS2=`grep ttyS2 < /proc/interrupts | awk -F: '{print $1}' | tr -d '[:blank:]'`
        USB2=`grep "hcd:usb2" < /proc/interrupts | awk -F: '{print $1}' | tr -d '[:blank:]'`
        USB3=`grep "hcd:usb3" < /proc/interrupts | awk -F: '{print $1}' | tr -d '[:blank:]'`
        # USB4=`grep "hcd:usb4" < /proc/interrupts | awk -F: '{print $1}' | tr -d '[:blank:]'`
        # Split MCU IRQs evenly between CPUs 1 and 2
        echo 4 > /proc/irq/${TTYS4}/smp_affinity
        # echo 2 > /proc/irq/${TTYS2}/smp_affinity
        echo 8 > /proc/irq/${USB2}/smp_affinity
        echo 8 > /proc/irq/${USB3}/smp_affinity
        # echo 8 > /proc/irq/${USB4}/smp_affinity
set_affinity() {
        AFFINITY_CPUS=$1
        COMMAND_NAME=$2
        echo "Setting CPU affinity for all $COMMAND_NAME threads to CPU $AFFINITY_CPUS"
        for p in `ps -eLf | grep -i $COMMAND_NAME | grep -v grep | awk '{print $4}'`
        do
                $TASKSET -cp $AFFINITY_CPUS $p
        done
make_nice() {
        NICE_LEVEL=$1
        COMMAND_NAME=$2
        echo "Setting all $COMMAND_NAME threads to niceness level $NICE_LEVEL"
        for p in `ps -eLf | grep $COMMAND_NAME | grep -v grep | awk '{print $4}'`
        do
                $RENICE $NICE_LEVEL $p
        done
tune_up() {
        # Put CPU into Performance Mode
        # echo "Placing Printer CPU into Performance mode with fixed frequency"
        # $CPUFREQSET -g performance
        # $CPUFREQSET -d 1.10Ghz
        # $CPUFREQINFO
        # Isolate Klipper from xindi and mjpg-streamer
        echo "\nIsolating klipper from qd-q2-client, mjpg_streamer, moonraker, and nginx\n"
        set_affinity 0 /home/mks/QD_Q2/bin/client
        set_affinity 0 ustreamer
        set_affinity 0 nginx
        set_affinity 0 moonraker
        set_affinity 1-2 klippy
        set_irq_affinity
        # Set Niceness of qd-q2-client and mjpg_streamer
        echo "\nSetting niceness of qd-q2-client, mjpg_streamer, nginx\n"
        make_nice 1 /home/mks/QD_Q2/bin/client
        make_nice 1 nginx
        make_nice 2 ustreamer
tune_down() {
        # Put CPU into ondemand Mode
        # echo "Placing Printer CPU into default ondemand and frequency scaling mode"
        # $CPUFREQSET -g ondemand
        # $CPUFREQSET -d 408Mhz
        # $CPUFREQINFO
        # Unisolate Klipper, xindi, nginx, moonraker, and ustreamer
        echo "Resetting klipper/ustreamer/client/nginx/moonraker tuning to system default"
        set_affinity 0-3 /home/mks/QD_Q2/bin/client
        set_affinity 0-3 klippy
        set_affinity 0-3 ustreamer
        set_affinity 0-3 nginx
        set_affinity 0-3 moonraker
        echo "Resetting niceness of qd-q2-client, ustreamer, nginx to system default"
        make_nice 0 /home/mks/QD_Q2/bin/client
        make_nice 0 ustreamer
        make_nice 0 nginx
case "$1" in
        start)
                sleep 30        # Wait for all the main printer processes to start up
                tune_up
        reload)
                tune_up
        stop)
                tune_down
                exit 0
esac
exit 0
et le service systemd (/etc/systemd/system/makerbase-tuning.service) :
[Unit]
Description=Makerbase-Tuning
After=moonraker.service
StartLimitIntervalSec=0
[Service]
Type=simple
Restart=always
RestartSec=3
ExecStart=bash /home/mks/QD_Q2/bin/tuning.sh start
[Install]
WantedBy=multi-user.target
En plus, mais je n'en suis pas certain, je pense que les firmwares ont été reflashé (klipper.bin et klipper_THR.bin tous deux datés du 10/10/2025).
Le service algo_app est aussi modifié :
[Unit]
Description=Start algo_app
After=network.target moonraker.service
[Install]
[Service]
ExecStart=/usr/local/bin/algo_app/main
WorkingDirectory=/usr/local/bin/algo_app
Restart=always
RestartSec=15
MemoryHigh=200M
MemoryMax=250M
User=root
Group=root
Environment=PYTHONPATH=/usr/local/bin/algo_app
Environment=LD_LIBRARY_PATH=/usr/local/bin/algo_app/_internal/lib
Nice=19
CPUSchedulingPolicy=other
#CPUQuota=90%
CPUAffinity=3
# 确保工作目录存在并有正确的权限
ExecStartPre=/bin/mkdir -p /usr/local/bin/algo_app/video_output
ExecStartPre=/bin/mkdir -p /var/log/algo_app
ExecStartPre=/bin/chown -R root:root /usr/local/bin/algo_app
ExecStartPre=/bin/chmod -R 775 /usr/local/bin/algo_app
Le 16/10/2025 at 11:22, tranbert a dit :
je pensais forcer un fliesytem check au reboot,
As-tu essayé en ajoutant à la racine du système, un fichier nommé forcefsck :
sudo touch /forcefsck
ou
sudo > /forcefsck
Extrait du /etc/init.d/checkroot.sh :
_want_force_fsck () {
        case "$(findmnt -n -o FSTYPE /)" in
        # Only ext* file systems support `-f' option to fsck. See #686895
        (ext*)
                [ -f /forcefsck ] || grep -q -s -w -i "forcefsck" /proc/cmdline
                return 1
        esac
Au redémarrage suivant, une vérification forcée du système devrait avoir lieu.
il y a 9 minutes, fran6p a dit :
Ha oui bonne idée merci. Dès que j'ai fini d'imprimer les trucs pour mon fils, je teste.
Au pire, qu'est-ce qui peut se passer ? Un filesystem illisible ? Même pas peur. ☠️
(j'aurais bien aimé une console serie quand même)
Modifié (le) par tranbert
il y a 6 minutes, tranbert a dit :
Au pire : rien, au mieux : réparation du système 😉.
Lis le fichier init (checkroot.sh) pour voir ce qu'il fait 😉, j'espère simplement qu'il se lance bien, car le système d'init utilise plutôt systemd 🙄.
il y a 57 minutes, fran6p a dit :
Aurait pu...  Le fichier a disparu au reboot, mais ce n'est pas mieux... Et le log dans /var/log/fsck ne bouge pas
Warning!  /dev/mmcblk0p6 is mounted.
Warning: skipping journal recovery because doing a read-only filesystem check.
/dev/mmcblk0p6 contains a file system with errors, check forced.
Je vais creuser côté systemd
