kiss82
Tout ce qui a été posté par kiss82
  1. @fran6p @thinkyhead I finalized a version that works on the CR-10 v2 stock setup: https://github.com/kiss81/cr10v2 in the "marlin" folder. The main issue I struggled with where the inverted END stops in the Z direction... That caused several issues of course I am trying to do some prints now to see how it goes.
  2. @fran6p Thank you! The last changes made it come alive. It almost works now except that I try to use it on a stock cr-10 v2 without bltouch and got some troubles with that. I tried to remove the bltouch code, but it is not recognizing my z-stop switch yet. My config for a stock cr-10 v2: https://github.com/kiss81/cr10v2 In the "marlin" folder. For a default extruder the e-steps where wrong as well, so I corrected that already.
  3. Thank you. I tried xloader, but no luck... so strange that I can't get it to work while it's working on your control box... I checked the hardware version of my board and it's the same. For now I am settled with TH3D Unified as that one seems to work for me, but I would prefer vanilla Marlin 2,x.
  4. I tried everything, but with the latest hex in the start post or compiling it myself it won't boot. I tried making some changes like the baudrate and motherboard, but no luck either. Something is wrong in the configuration I am afraid. TH3D I can compile and flash, so I am quite sure the bootloader is fine.
  5. Sorry for not talking French, but believe me, you will understand my English better then my French I own a CR-10 v2 (stock) and I successfully compiled the latest Marlin code with the provided configuration. I disabled the bltouch include. After that I flash with avrdude, but after flashing nothing happens. I then reset the control box but only the LCD lights up, but no message anything. I tried to flash the attached hex file from the first post, but I get the same behavior. Flashing back the stock firmware with avrdude works, but none of the new firmware does boot. Do I need to update the bootloader maybe?
  6. One more question what did you use to flash it successfully from stock to the new firmware?
  7. Thank you for your reply in English. I think I get it now what is wrong on my end: It seems to only flash the program and not the included bootloader... I need to change my avrdude command I guess. (or use other software)
  8. Sorry for not talking French, but believe me, you will understand my English better then my French I own a CR-10 v2 (stock) and I successfully compiled the latest Marlin code with the provided configuration. I disabled the bltouch include. After that I flash with avrdude, but after flashing nothing happens. I then reset the control box but only the LCD lights up, but no message anything. I tried to flash the attached hex file from the first post, but I get the same behavior. Flashing back the stock firmware with avrdude works, but none of the new firmware does boot. Do I need to update the bootloader maybe?
