Marchelo3D
    Crealtity Ender 6
Récompenses de Marchelo3D
  • Reacting Well Rare
  1. en poursuivant mes recherche, merci le Internet Je suis tombé sur cette config: https://www.facebook.com/download/5514887198620325/printerworking.cfg?av=100009970600884&eav=AfYD_IaLuu-2Tl_xO6lVxq0mvcwip2gbIPa6jKCp70AU-4WJMxvVDercJr2jlrRepQc&paipv=0&hash=AcqqT5EGUf0QQAb8H7E&__cft__[0]=AZX7YF5RRzQU29ZtOAm2f4l6YHqznBfteGSo27DHhVsEug-6Ae4zoPiQr_W0VjdTefZmx0-wp0AExj6HAYdp8tkaENcbxe0gY7N3RV6B03j1j1j2U2YD45F8Xg7YGsASDfarzeh4TIkRQin5d7HiJ_QzVGe7CXqdOiJgxLIUORg7YQ&__tn__=H-R en revenat et corrigeant me config, j'en suis arrivè là et il y a du mieux je peux faire un home: [stepper_x] step_pin: PB13 dir_pin: PB12 enable_pin: !PB14 microsteps: 16 rotation_distance: 40 endstop_pin: ^PC0 position_endstop: 0 position_max: 260 homing_speed: 50 [tmc2209 stepper_x] uart_pin: PC11 tx_pin: PC10 uart_address: 0 run_current: 0.580 stealthchop_threshold: 999999 [stepper_y] step_pin: PB10 dir_pin: !PB2 enable_pin: !PB11 microsteps: 16 rotation_distance: 40 endstop_pin: ^PC1 position_endstop: 0 position_max: 260 homing_speed: 50 [tmc2209 stepper_y] uart_pin: PC11 tx_pin: PC10 uart_address: 2 run_current: 0.580 stealthchop_threshold: 999999 [stepper_z] step_pin: PB0 dir_pin: !PC5 enable_pin: !PB1 microsteps: 16 rotation_distance: 8 endstop_pin: ^PC2 position_endstop: 0.0 position_max: 400 [tmc2209 stepper_z] uart_pin: PC11 tx_pin: PC10 uart_address: 1 run_current: 0.580 stealthchop_threshold: 999999 [extruder] max_extrude_only_distance: 1000.0 step_pin: PB3 dir_pin: !PB4 enable_pin: !PD1 microsteps: 16 rotation_distance: 22.857 nozzle_diameter: 0.400 filament_diameter: 1.750 heater_pin: PC8 sensor_type: EPCOS 100K B57560G104F sensor_pin: PA0 control: pid pid_Kp: 21.527 pid_Ki: 1.063 pid_Kd: 108.982 min_temp: 0 max_temp: 250 [tmc2209 extruder] uart_pin: PC11 tx_pin: PC10 uart_address: 3 run_current: 0.650 stealthchop_threshold: 999999 [heater_bed] heater_pin: PC9 sensor_type: ATC Semitec 104GT-2 sensor_pin: PC4 control: pid pid_Kp: 54.027 pid_Ki: 0.770 pid_Kd: 948.182 min_temp: 0 max_temp: 100 [heater_fan controller_fan] pin: PB15 heater: heater_bed heater_temp: 45.0 [heater_fan nozzle_cooling_fan] pin: PC7 [fan] pin: PC6 [mcu] serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_4C0040000B504B5735313920-if00 # serial: /dev/ttyAMA0 restart_method: command [printer] kinematics: corexy max_velocity: 500 max_accel: 2000 max_z_velocity: 10 max_z_accel: 100 [board_pins] aliases: # EXP1 header EXP1_1=PB5, EXP1_3=PA9, EXP1_5=PA10, EXP1_7=PB8, EXP1_9=<GND>, EXP1_2=PA15, EXP1_4=<RST>, EXP1_6=PB9, EXP1_8=PD6, EXP1_10=<5V> #[virtual_sdcard] #path: /home/pi/printer_data/gcodes #[gcode_macro POWEROFF] #gcode: # RESPOND TYPE=command MSG=action:poweroff #[gcode_macro CANCEL_PRINT] #rename_existing: BASE_CANCEL_PRINT #gcode: # TURN_OFF_HEATERS # CLEAR_PAUSE # SDCARD_RESET_FILE # BASE_CANCEL_PRINT ###################################################################### # BigTreeTech TFT TouchScreen emulated 12864 mode ###################################################################### [display] lcd_type: emulated_st7920 spi_software_miso_pin: PD8 # status led, Virtual MISO spi_software_mosi_pin: PD6 spi_software_sclk_pin: PB9 en_pin: PB8 encoder_pins: ^PA10, ^PA9 click_pin: ^!PA15 [include fluidd.cfg]
  2. Bonjour Papagalak, Après une installation de Klipper au forceps pas sans difficulté, j'arrive enfin à communiquer avec l'imprimante au travers de l'interface de Fluidd. J'avais bien le fichier que tu m'indique. je l'ai adapté avec https://3dprintbeginner.com/how-to-install-klipper-on-creality-ender-6/?fbclid=IwAR3ECGPbYebrjNGj4ULfJAR2lZKbgUob8tJ5wiTHTA1PWm40JBiM6YsmqVM Mais pour l'instant je n'arrive même pas à faire un HOME, les moteurs saccades et l'opération n'aboutie pas. Obligé de faire une coupure sauvage de l'imprimante. Je lance à nouvel appel au secours à ceux qui auraient installer cette fameuse carte BIGTREETECH SKR Mini E3 V3 0 avec Klipper. Car pour le moment pas de carte mère d'origine et une imprimante sur les bras don je ne peux pas me servir. pour info mon fichier printer.cfg: # This file contains common pin mappings for the BIGTREETECH SKR mini # E3 v3.0. To use this config, the firmware should be compiled for the # STM32G0B1 with a "8KiB bootloader" and USB communication/USART. # The "make flash" command does not work on the SKR mini E3. Instead, # after running "make", copy the generated "out/klipper.bin" file to a # file named "firmware.bin" on an SD card and then restart the SKR # mini E3 with that SD card. # See docs/Config_Reference.md for a description of parameters. #[bltouch] # enable for BLTouch #sensor_pin: PC14 #control_pin: PA1 #x_offset: -40 #y_offset: -10 #z_offset: 3.0 #speed: #[safe_z_home] # enable for BLTouch #home_xy_position: 115,115 # Change coordinates to the center of your print bed #speed: 50 #z_hop: 10 # Move up 10mm #z_hop_speed: 5 #[bed_mesh] # enable for BLTouch #speed: 120 #horizontal_move_z: 5 #mesh_min: 10, 10 #mesh_max: 190, 220 #probe_count: 5,5 [stepper_x] step_pin: PB13 dir_pin: !PB12 enable_pin: !PB14 microsteps: 16 rotation_distance: 40 endstop_pin: ^PC0 position_endstop: 260 position_max: 260 homing_speed: 50 [tmc2209 stepper_x] uart_pin: PC11 tx_pin: PC10 uart_address: 0 run_current: 0.580 hold_current: 0.500 stealthchop_threshold: 999999 [stepper_y] step_pin: PB10 dir_pin: !PB2 enable_pin: !PB11 microsteps: 16 rotation_distance: 40 endstop_pin: ^PC1 position_endstop: 260 position_max: 260 homing_speed: 50 [tmc2209 stepper_y] uart_pin: PC11 tx_pin: PC10 uart_address: 2 run_current: 0.580 hold_current: 0.500 stealthchop_threshold: 999999 [stepper_z] step_pin: PB0 dir_pin: PC5 enable_pin: !PB1 microsteps: 16 rotation_distance: 8 endstop_pin: ^PC2 # disable to use BLTouch position_endstop: 0.0 # disable to use BLTouch #endstop_pin: probe:z_virtual_endstop # enable to use BLTouch position_max: 400 #position_min: -2 # enable to use BLTouch [tmc2209 stepper_z] uart_pin: PC11 tx_pin: PC10 uart_address: 1 run_current: 0.580 hold_current: 0.500 stealthchop_threshold: 999999 [extruder] max_extrude_only_distance: 1000.0 step_pin: PB3 dir_pin: !PB4 enable_pin: !PD1 microsteps: 16 rotation_distance: 22.857 nozzle_diameter: 0.400 filament_diameter: 1.750 heater_pin: PC8 sensor_type: EPCOS 100K B57560G104F sensor_pin: PA0 control: pid pid_Kp: 21.527 pid_Ki: 1.063 pid_Kd: 108.982 min_temp: 0 max_temp: 250 [tmc2209 extruder] uart_pin: PC11 tx_pin: PC10 uart_address: 3 run_current: 0.650 hold_current: 0.500 stealthchop_threshold: 999999 [heater_bed] heater_pin: PC9 sensor_type: ATC Semitec 104GT-2 sensor_pin: PC4 control: pid pid_Kp: 54.027 pid_Ki: 0.770 pid_Kd: 948.182 min_temp: 0 max_temp: 100 [heater_fan controller_fan] pin: PB15 heater: heater_bed heater_temp: 45.0 [heater_fan nozzle_cooling_fan] pin: PC7 [fan] pin: PC6 [mcu] serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_4C0040000B504B5735313920-if00 # serial: /dev/ttyAMA0 restart_method: command [printer] kinematics: corexy max_velocity: 500 max_accel: 2000 max_z_velocity: 10 max_z_accel: 100 [board_pins] aliases: # EXP1 header EXP1_1=PB5, EXP1_3=PA9, EXP1_5=PA10, EXP1_7=PB8, EXP1_9=<GND>, EXP1_2=PA15, EXP1_4=<RST>, EXP1_6=PB9, EXP1_8=PD6, EXP1_10=<5V> #[virtual_sdcard] #path: /home/pi/printer_data/gcodes #[gcode_macro POWEROFF] #gcode: # RESPOND TYPE=command MSG=action:poweroff #[gcode_macro CANCEL_PRINT] #rename_existing: BASE_CANCEL_PRINT #gcode: # TURN_OFF_HEATERS # CLEAR_PAUSE # SDCARD_RESET_FILE # BASE_CANCEL_PRINT ###################################################################### # BigTreeTech TFT TouchScreen emulated 12864 mode ###################################################################### [display] lcd_type: emulated_st7920 spi_software_miso_pin: PD8 # status led, Virtual MISO spi_software_mosi_pin: PD6 spi_software_sclk_pin: PB9 en_pin: PB8 encoder_pins: ^PA10, ^PA9 click_pin: ^!PA15 [include fluidd.cfg]
  3. Hello, enfin un retour carte mere HS je l'ai remplacer par BIGTREETECH SKR Mini E3 V3 0 Mais impossible de trouver le bon fichier printer.cfg Quelqu'un a t il fait cet upgrade qui fonction Et aurais l'amabilité de me le fournir? merci pour vos contributions
  4. Hello, enfin un retour carte mere HS je l'ai remplacer par BIGTREETECH SKR Mini E3 V3 0 Mais impossible de trouver le bon fichier printer.cfg Quelqu'un a t il fait cet upgrade qui fonction Et aurais l'amabilité de me le fournir? merci pour vos contributions
  5. Bonjour Papagalak, Je ne rappelle pas avoir regardé Et la je ne peux pas le faire pour le moment, car je ne suis pas chez moi. Mais si c'est le cas, de la voir, que dois-je faire?
  6. Bonsoir fran6p, La première mise à jour c'est bien passée, avec les mêmes instructions que les tiennes. Mon souci est que cela a buger à un moment est plus possible de revenir à la normal malgré les nouveaux update qui ne sont pas pris en compte, et surtout coté écran
  7. Bonjour à tous, Suite à la mise à jour du firmware avec celui ci: https://www.ender5.fr/mise-a-jour-firmware-ender-5-plus-cr10max-ecran-tactile-en-francais/ Et en suivant les explications suivantes: L'imprimante a lancé un test toute seul , après réglage du bed. Pas de bol j'étais avec du fil ABS, alors que le test était réglé en température pour du PLA. Je décide de suspendre l'impression. Plantage de l'imprimante, j'éteins, je rallume et plus possible de Je lance une impression test pour réaliser le fameux cube, venant de ce site:https://www.ender5.fr/calibration.html Voyant que le cube commence à se décoller, je stop l'impression. Et la c'est le drame, le plateau est remonté vers la buse pour l'emplafonner, comme si il ne voyait plus la butée en Z. Stop direct en débranchant l'imprimante car pas moyen de contrôler l'imprimante par l'écran. Je rallume et là l'imprimante se retrouve avec le zero du Z la ou il le veut bien est impossible de le rerégler. Je décide de tout réinstaller CM+écran, rien a faire, même en essayant de réinjecter le firmaware original de chez CREALITY. Donc je me retrouve avec une imprimante qui a perdue sont Zéro, un écran ou l'on ne peu plus rien voir, car c'est comme si il n'était pas à la bonne fréquence de rafraichissement( que des lignes qui bougent) et impossible de faire un reset de tout cela. Quelqu'un aurait une idée pour ce reset général CM+écran? Merci pour vos retour si vous avez déjà été dans une situation similaire et que vous vous en êtes sorti.
  8. Bonjour RFN_31, Non plus moyen de voir quoi que ce soit sur l'écran même si je réinjecte le firmware de l'écran, cela ne s'arrange pas. c'est comme si il n'y avait pas d'effacement de l'ancien. c'est pour cela que je cherche comment je peux supprimer les anciens firmware avant de pouvoir remettre ceux d'origines et repartir de zéro
  9. Bonjour à tous, Suite à la mise à jour du firmware avec celui ci: https://www.ender5.fr/mise-a-jour-firmware-ender-5-plus-cr10max-ecran-tactile-en-francais/ Et en suivant les explications suivantes: L'imprimante a lancé un test toute seul , après réglage du bed. Pas de bol j'étais avec du fil ABS, alors que le test était réglé en température pour du PLA. Je décide de suspendre l'impression. Plantage de l'imprimante, j'éteins, je rallume et plus possible de Je lance une impression test pour réaliser le fameux cube, venant de ce site:https://www.ender5.fr/calibration.html Voyant que le cube commence à se décoller, je stop l'impression. Et la c'est le drame, le plateau est remonté vers la buse pour l'emplafonner, comme si il ne voyait plus la butée en Z. Stop direct en débranchant l'imprimante car pas moyen de contrôler l'imprimante par l'écran. Je rallume et là l'imprimante se retrouve avec le zero du Z la ou il le veut bien est impossible de le rerégler. Je décide de tout réinstaller CM+écran, rien a faire, même en essayant de réinjecter le firmaware original de chez CREALITY. Donc je me retrouve avec une imprimante qui a perdue sont Zéro, un écran ou l'on ne peu plus rien voir, car c'est comme si il n'était pas à la bonne fréquence de rafraichissement( que des lignes qui bougent) et impossible de faire un reset de tout cela. Quelqu'un aurait une idée pour ce reset général CM+écran? Merci pour vos retour si vous avez déjà été dans une situation similaire et que vous vous en êtes sorti.
  10. Je viens d'acquérir une Ender 6 et me lance dans le projet d'imprimer un avons radio commandé Pas facile de régler les paramètres pour avoir une impression complexe de parois fines, mais je ne désespère pas. Si d'autre se sont déjà lancer dans ce genre de projet je suis preneur de conseils. Merci pour votre accueil et aide précieuse.
