prusa3di3
    prusa i3
2 402 visualisations du profil
Récompenses de prusa3di3
Enthusiast
Enthusiast (6/14)
  1. parfait ca fonctionne grand merci
  2. 2 ca change rien 0 erreur de compilation
  3. merci c'est bien ce port la que j'utilise ca ne réagie pas
  4. ca compile sans erreur mais aucune réaction de l'imprimante pourtant quand je tape sur google MKS tft24 je tombe bien sur mon écran? #-------------------------------------------------------------------- ######### Printer type setting ################################## #mainboard firmware setting(marlin:1; repetier:2; smoothie:3) >cfg_firmware_type:1 #machine setting (Normal:1; Delta:2) >cfg_machine_type:1 #baud rate (9600:1; 57600:2; 115200:3; 250000:4) >cfg_baud_rate:3 #multi-language(enable:1, disable:0) >cfg_multiple_language:0 #languages setting(simplified (simplified Chinese:1; traditional Chinese:2; English:3; Russian:4; Spanish:5;French:6;Italian:7). #This configuration is valid when "cfg_multiple_language" is disabled. >cfg_language_type:3 #extruder number(one:1; dual:2) >cfg_sprayer_counter:1 #enable heated bed(yes:1; no: 0) >cfg_custom_bed_flag:1 #the max target temp of extruder and heated bed >cfg_max_sprayer_temperature:270 >cfg_max_hotbed_temperature:150 #pause position (-1 is invalid; Z-axis is relative position) >cfg_XPOS:-1 >cfg_YPOS:-1 >cfg_ZADD:5 #----------------------------------------------------------------------- ######### Advanced Function Option ################################## #enable UPS?(yes:1; no:0) >cfg_have_ups_device:0 #enable power detecting module(2:mks ups;1:mks 220det;0:mks pwc) >cfg_insert_det_module:0 #enable auto off after print finish function (no:0; Yes:1) >cfg_print_finish_close_Machine:0 #set PB0 signal when use it for sencond nozzle (high level:1; low level:0) >cfg_PB0_trigger_Level:0 #set PB1 signal (high level:1; low level:0) >cfg_PB1_trigger_Level:0 #set error range of Z-axis on breakpoints recovery >cfg_breakpoint_z_error:0.2 #--------------------------------------------------------------------------- ######### Filament Change Function ############################## #the speed to extrude filament(mm/min) >cfg_filament_load_speed:1200 #the lenght to extrude filament (mm) >cfg_filament_load_length:200 #the speed to retract filament(mm/min) >cfg_filament_unload_speed:1200 #the lenght to retract filament(mm) >cfg_filament_unload_length:200 #It is the minimum temperature for filament change. It will auto heat up if the current temp doesn't reach the target. >cfg_filament_load_limit_temperature:200 #The length of Load filament before unloader filament. >cfg_unload_retract_length:2 #The speed of load filament before unloader filament. >cfg_unload_retract_speed:1200 #--------------------------------------------------------------------------- ############ Leveling Function ######################################## #leveling mode(manual:0; auto:1; conceal leveling button:2) >cfg_leveling_mode:0 #the command of auto leveling (G29 is available for Marlin.While G32 is for Repetier and Smoothieware) >cfg_auto_leveling_cmd:G28;G29; #the point number of manual leveling:(3,4,5 point available) >cfg_point_number:4 #the coordinates of 5 point on manual leveling >cfg_point1:50,50 >cfg_point2:180,50 >cfg_point3:180,180 >cfg_point4:50,180 >cfg_point5:150,150 #the travel speed of leveling(mm/min) >cfg_leveling_z_speed:1500 >cfg_leveling_xy_speed:3000 #--------------------------------------------------------------------------- ############# WIFI Function ########################################## #wifi model(MKS WIFI TFT:0; MKS HLK-WIFI:1) >cfg_wifi_type:0 #wifi mode(0:sta;1:ap) >cfg_wifi_mode:0 #wifi name and password >cfg_wifi_ap_name:MKS_wifi >cfg_wifi_key_code:makerbase #0:disable cloud service 1:enable cloud service >cfg_cloud_enable:1 #cloud service adress >cfg_wifi_cloud_host:www.baizhongyun.cn #cloud service port >cfg_cloud_port:10086 #Dynamic access IP >cfg_ip_dhcp_flag:1 #IP/mask/gateway >cfg_ip_address:192.168.3.100 >cfg_ip_mask:255.255.255.0 >cfg_ip_gate:192.168.3.1 #-------------------------------------------------------------------------------- ############## Function Customization ####################################### #user-defined function1 and 2.(display this button . disable: 0; enable: 1) >cfg_function_btn1_display:1 #command of user-defined function >function_btn1_cmd:M84; #set number of "More" button >moreitem_pic_cnt:0 #edit command for 1~7 "More" button,each command must be separated by semicolon ";" >moreitem_button1_cmd:G28 X0; >moreitem_button2_cmd:G28 X0; >moreitem_button3_cmd:G28 Y0; >moreitem_button4_cmd:G28 Y0; >moreitem_button5_cmd:G28 Z0; >moreitem_button6_cmd:G28 Z0; >moreitem_button7_cmd:G28; #how many "More" button display on screen interface >morefunc_cnt:0 #command setting on button1~5 >morefunc1_cmd:G28; >morefunc2_cmd:G28; >morefunc3_cmd:G28; >morefunc4_cmd:G28; >morefunc5_cmd:G28; #--------------------------------------------------------------------------------- ##### Display Customization(button and logo customized see User's Manual) ####### #the color of screen background >cfg_background_color:0x000000 #the color of title text >cfg_title_color:0xFFFFFF #the color of temperature,fan,(etc) background >cfg_state_background_color:0x000000 #the color of temprature,fan,(etc) text >cfg_state_text_color:0xFFFFFF #the color of file button >cfg_filename_background_color:0x000000 #the color of file text >cfg_filename_color:0xFFFFFF #the color of background in printing >cfg_printingstat_word_background_color:0x000000 #the color of text in printing status >cfg_printingstat_word_color:0xFFFFFF #3D effects setting (disable: 0; enable: 1) >cfg_BUTTON_3D_effects:0 #The screen is flipped 180°(0: no flip, 0xEE: flip) >cfg_OVERTURN_180:0 #shield the function of detection power (0:no shield ,1:shield) >cfg_disable_PWR_det:0 #shield the function of detection filament (0:no shield ,1:shield) >cfg_disable_MT_det:0 #Whether to support the function of dual extruder single nozzle.(0: disable, 1: enable) #the extruder number need set to dual. >cfg_single_nozzle:0 #For the M110 command plus check, the version of Marlin 1.0.2 and below is set to 1, and the other versions are set to 0. >cfg_M110_add_checkSum:1 #Enable function of display error message. (no:0; Yes:1) >cfg_display_eeror_message:0 #Enable function of babastep. (no:0; Yes:1) >cfg_babystep_btn_display:1 #-----------------------------------------------------------------------
  5. bonjour je viens d installer une carte MKS tinybee avec écran tactile 2.4pouces l'écran s'allume je peux naviguer dans les différents menu mais l'imprimante ne réagie pas ci-joint les fichiers config et le message d'erreur quand je décommente la ligne 2649 #define MKS_ROBIN_TFT24 from Marlin/src/HAL/ESP32/../../inc/MarlinConfig.h:28, from Marlin/src/HAL/ESP32/HAL.cpp:24: Marlin/src/HAL/ESP32/../../inc/../HAL/ESP32/inc/Conditionals_LCD.h:25:4: error: #error "Sorry! TFT displays are not available for HAL/ESP32." #error "Sorry! TFT displays are not available for HAL/ESP32." ^ In file included from Marlin/src/HAL/ESP32/../../inc/MarlinConfigPre.h:52:0, from Marlin/src/HAL/ESP32/../../inc/MarlinConfig.h:28, from Marlin/src/HAL/ESP32/HAL_SPI.cpp:25: Marlin/src/HAL/ESP32/../../inc/../HAL/ESP32/inc/Conditionals_LCD.h:25:4: error: #error "Sorry! TFT displays are not available for HAL/ESP32." #error "Sorry! TFT displays are not available for HAL/ESP32." ^ In file included from Marlin/src/HAL/ESP32/../../inc/MarlinConfigPre.h:52:0, from Marlin/src/HAL/ESP32/../../inc/MarlinConfig.h:28, from Marlin/src/HAL/ESP32/Servo.cpp:24: Marlin/src/HAL/ESP32/../../inc/../HAL/ESP32/inc/Conditionals_LCD.h:25:4: error: #error "Sorry! TFT displays are not available for HAL/ESP32." #error "Sorry! TFT displays are not available for HAL/ESP32." ^ In file included from Marlin/src/HAL/ESP32/../../core/../inc/MarlinConfigPre.h:37:0, from Marlin/src/HAL/ESP32/../../core/serial_base.h:24, from Marlin/src/HAL/ESP32/../../core/serial_hook.h:24, from Marlin/src/HAL/ESP32/FlushableHardwareSerial.h:27, from Marlin/src/HAL/ESP32/FlushableHardwareSerial.cpp:25: Marlin/src/HAL/ESP32/../../core/../inc/../core/macros.h:64:0: warning: "FORCE_INLINE" redefined #define FORCE_INLINE __attribute__((always_inline)) inline ^ In file included from Marlin/src/HAL/ESP32/FlushableHardwareSerial.h:26:0, from Marlin/src/HAL/ESP32/FlushableHardwareSerial.cpp:25: Marlin/src/HAL/ESP32/../shared/Marduino.h:86:0: note: this is the location of the previous definition #define FORCE_INLINE inline __attribute__((always_inline)) ^ In file included from Marlin/src/HAL/ESP32/../../core/../inc/MarlinConfigPre.h:52:0, from Marlin/src/HAL/ESP32/../../core/serial_base.h:24, from Marlin/src/HAL/ESP32/../../core/serial_hook.h:24, from Marlin/src/HAL/ESP32/FlushableHardwareSerial.h:27, from Marlin/src/HAL/ESP32/FlushableHardwareSerial.cpp:25: Marlin/src/HAL/ESP32/../../core/../inc/../HAL/ESP32/inc/Conditionals_LCD.h:25:4: error: #error "Sorry! TFT displays are not available for HAL/ESP32." #error "Sorry! TFT displays are not available for HAL/ESP32." ^ cc1plus.exe: warning: unrecognized command line option '-Wno-register' *** [.pio\build\mks_tinybee\src\src\HAL\ESP32\FlushableHardwareSerial.cpp.o] Error 1 In file included from Marlin/src/HAL/ESP32/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/ESP32/HAL.cpp:24: Marlin/src/HAL/ESP32/../../inc/SanityCheck.h:2725:6: error: #error "TFT_COLOR_UI, TFT_CLASSIC_UI, TFT_LVGL_UI is required for your TFT. Please enable one." #error "TFT_COLOR_UI, TFT_CLASSIC_UI, TFT_LVGL_UI is required for your TFT. Please enable one." ^ In file included from Marlin/src/HAL/ESP32/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/ESP32/Servo.cpp:24: Marlin/src/HAL/ESP32/../../inc/SanityCheck.h:2725:6: error: #error "TFT_COLOR_UI, TFT_CLASSIC_UI, TFT_LVGL_UI is required for your TFT. Please enable one." #error "TFT_COLOR_UI, TFT_CLASSIC_UI, TFT_LVGL_UI is required for your TFT. Please enable one." ^ In file included from Marlin/src/HAL/ESP32/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/ESP32/HAL_SPI.cpp:25: Marlin/src/HAL/ESP32/../../inc/SanityCheck.h:2725:6: error: #error "TFT_COLOR_UI, TFT_CLASSIC_UI, TFT_LVGL_UI is required for your TFT. Please enable one." #error "TFT_COLOR_UI, TFT_CLASSIC_UI, TFT_LVGL_UI is required for your TFT. Please enable one." ^ cc1plus.exe: warning: unrecognized command line option '-Wno-register' *** [.pio\build\mks_tinybee\src\src\HAL\ESP32\HAL.cpp.o] Error 1 cc1plus.exe: warning: unrecognized command line option '-Wno-register' *** [.pio\build\mks_tinybee\src\src\HAL\ESP32\Servo.cpp.o] Error 1 cc1plus.exe: warning: unrecognized command line option '-Wno-register' *** [.pio\build\mks_tinybee\src\src\HAL\ESP32\HAL_SPI.cpp.o] Error 1 ========================================================================================= [FAILED] Took 15.70 seconds ========================================================================================= Environment Status Duration ------------- -------- ------------ mks_tinybee FAILED 00:00:15.697 ==================================================================================== 1 failed, 0 succeeded in 00:00:15.697 ==================================================================================== Configuration.h Configuration_adv.h
  6. c'était un câble qui était défectueux ,ca fonctionne maintenant grand merci
  7. ca fonctionne les paramètre sont bien enregistrer mais toujours pas le 3dtouch je vérifier mon câblage encore 1 fois j'ai bien câblé je comprends pas?
  8. merci pour ta réponse ca fonctionne pas ,le 3dtouch ne réagie pas quand je pousse avec le doigt j'ai un message d'erreur quand je décommente //#define PINS_DEBUGGING quand je téléverse le firmware sur la carte en wifi ou en usb les modifications ne sont pas prise en compte ? je voudrai essayer de téléversé avec l'Arduino ide, quelle type de carte il faut sélectionné?
  9. bonjour j'ai installer un 3dtouch sur ma hypercube Ngen nouvelle carte MKS tinybee ,écran TFT24 avant ramps 1.4 nouveau 3 dtouch avant touchmi fait maison dernier marlin 2.0.9.2 tous fonctionne sauf le 3dtouch il s allume mais ne réagie pas, la buse vient percuté le plateau j'ai remarqué aussi que quand je téléverse le firmware sur la carte, sur (ESP3D) les modifications( les réglages es pas en Z) ne sont pas prise en compte ,sauf si je les modifie sur ESP3D si je le fais en wifi les modif elle ne sont pas non plus prise en compte. je comprend pas? merci Configuration.txt.h Configuration_adv.txt.h
  10. J ai laissé de côté le 3dtouch et installer un touch-mi diy
  11. j ai cherché, j ai pas trouvé
  12. je viens de faire un test ,le palpage au centre ok ,demarage du G29 premier point ok second =erreur je trouve pas sur marlin 2 ou définir la zone de palpage par rapport au Ox et Oy?
  13. merci il palpe 2 fois une rapide et une doucement ,c est quand le g29 demarre qu il y a le message d erreur ca fais 2 jours que je bataille avec marlin et arduino ide et visual studio code,ras le bol
  14. bonjour j ai suivi le tuto https://3dwork.io/configurar-marlin-2-0-x-desde-cero pour installer un 3d touch sur mon hypercube avec marlin-bugfix-2.0.x avec une ramps 1.4 le home du z se passe bien et aprés message d erreur ? Configuration_adv.h Configuration.h
  15. bonjour je viens d installer un bltouch,avec une ramps 1.4 + marlin 2 sur mon imprimante 3d j ai un probleme l extrudeur ne fonctionne plus , il y a une modif a faire sur les pins ? Configuration.h
