bonjour à tous,
alors voila, j'ai fini par recevoir la nouvelle carte mks sbase v1.3 tout fonctionne , sauf, devinez quoi..... le bltouch smart v2.0!!!!
je n'en peux plus, j'ai essayé de multiple combinaison mais rien n'y fait;
branchement orange pin 1.23
marron pin gnd
blanc=S, noir=G, rouge=5V sur connecteur Z-
le code:
# Switch module for Bltouch control
switch.servo.enable true
switch.servo.input_on_command     M280 S3.0 # M280 S7.5 Would be midway
switch.servo.input_off_command     M280 S7.0 # Same as M280 S0 0% duty cycle, effectivley off
switch.servo.output_pin         1.23     # Must be a PWM capable pin
switch.servo.output_type         hwpwm # H/W PWM output settable
switch.servo.pwm_period_ms     20 # Set Period to 20ms (50Hz) - Default is 50Hz
endstops_enable                              true             # The endstop module is enabled by default and can be disabled here
#corexy_homing                               false            # Set to true if homing on a hbot or corexy
alpha_min_endstop                            1.24^!            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop                           nc            # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_homing_direction                       home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
alpha_min                                    0                # This gets loaded as the current position after homing when home_to_min is set
alpha_max                                    435              # This gets loaded as the current position after homing when home_to_max is set
beta_min_endstop                             1.26^!            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#beta_max_endstop                            nc            # Pin to read max endstop, uncomment this and comment the above if using max endstops
beta_homing_direction                        home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
beta_min                                     0                # This gets loaded as the current position after homing when home_to_min is set
beta_max                                     380              # This gets loaded as the current position after homing when home_to_max is set
#gamma_min_endstop                            nc           # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
gamma_max_endstop                           nc            # Pin to read max endstop, uncomment this and comment the above if using max endstops
gamma_homing_direction                       home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
gamma_min                                    0                # This gets loaded as the current position after homing when home_to_min is set
gamma_max                                    250              # This gets loaded as the current position after homing when home_to_max is set
# Z-probe
# See http://smoothieware.org/zprobe
zprobe.enable                                true           # set to true to enable a zprobe
zprobe.probe_pin                             1.28         # pin probe is attached to if NC remove the !
zprobe.slow_feedrate                         5               # mm/sec probe feed rate
zprobe.debounce_count                       100             # set if noisy
zprobe.fast_feedrate                         100             # move feedrate mm/sec
zprobe.probe_height                          5               # how much above bed to start probe
gamma_min_endstop                           nc              # normally 1.28, Change to nc to prevent conflict with BLTouch
j'ai même essayé de changer le pin de 1.23 a 3.25 du exp2 etant un PWM , avoir changé le code dans config, mais toujours rien.
test M119 bltouch broche rentrée met l'état de probe a 1 et si sortie à la main = état 0
aucune commande via M280 fonctionnent.
je sais que je déterre un sujet qui a déja fait coulé de l'encre..... mais j'ai re-flasher le firmware deux fois avec celui de: ‎mercredi ‎23 ‎mai ‎2018, ‏‎03:43:53 celui qui se trouve dans le dossier RAR mks-sbase-master.
voila, si des anciens ont une idée....
merci par avance
config.txt
 CA Y EST!!!! enfin reussi , encore un firmware essayé..... il marche.
j’essaye de regler l' offset  des axe , et j'ai l'impression qu'il faut faut aussi régler les pas ...sur y et z
bonjour j ai le même problème que toi avec mon bltouch et ma mks sbase 1.3 et smoothie pourrais tu si tu le veux bien me donné ton fichier config pour voir comment tu as paramétré ton bltouch merci
