Bonjour a tous ,
J aimerais mettre a jour marlin sur une A20M que j ai reçu hier.
sur arduino ide j ai des erreur orange de librairie quelqu'un a déjà eu le probleme.
Le but final est de passer en français l imprimante et de mettre un écran boot personnel.
ci joint les differents erreur  :
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\Marlin_main.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\Sd2Card.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\endstops.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\planner.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\stepper.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\temperature.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_445803\sketch\ultralcd.cpp
et a la fin il arrive a compiler
Le croquis utilise 213086 octets (83%) de l'espace de stockage de programmes. Le maximum est de 253952 octets.
Les variables globales utilisent 5943 octets (72%) de mémoire dynamique, ce qui laisse 2249 octets pour les variables locales. Le maximum est de 8192 octets.
Apres , je suis a ma 6 eme impression, j ai un effet de stripping, j utilise cura
distance de retractation 0.8
vitesse 35 mm/s
merci a vous
yeah je vais tester ça de ce pas merci a toi
le 1.1.8 il y a le bt touch dessus je dois en recevoir un bientot
merci a toi
arduino me note 2 erreurs
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_380520\sketch\Sd2Card.cpp
Error while detecting libraries included by C:\Users\FREDDY~1\AppData\Local\Temp\arduino_build_380520\sketch\Marlin_main.cpp
je peux televerser ou pas
Moi je ne l'est pas installé car trop de problèmes pour ci peut
par contre j'ai tout le matos pour installer un capteur un inductif
Moi je suis resté sur la 1.8.10 pour le moment
n'oublie pas de mettre ton baud a 2500000
il y a 2 minutes, pafpaf a dit :
je peux televerser meme avec les 2 erreurs de librairire
apres le baud a 250000 c est si j utilise le moniteur serie
Autre question bete j ai regarde le marlin que tu ma filer la carte que j ai est une gt 2560 v4
et je vois celle ci MOTHERBOARD BOARD_ULTIMAKER
c est quoi les differences ??
il te faudra toujours ton port série et ton baud pour bien communiqué avec ton pc et ta machine pour bien téléverser
après tu peut imprimer en usb ou avec la sd  mais quand tu imprime avec ta sd ne laisse pas ta machine connecter en usb
il y a 1 minute, neomax59 a dit :
Oui ça ces l'appellation que j'ai je ne les pas changer et pour moi ça fonctionne
à l’instant, pafpaf a dit :
je vais imprimer qu en carte sd pour éviter d être emebeter
Aux début quand j'ai acheter ma geeetech i3 pro b j'ai hu beaucoup de mal pour trouver une bonne version de marlin qui fonctionnais bien j'ai du rester sur une version 1.0.1
et il n’y a pas longtemps on m’a donner cette version 1.1.8 qui vas très bien chez moi
par contre je fais très peu de mises à jour de marlin
il y a 4 minutes, pafpaf a dit :
ok je dois essayer de rester sur une gt2560 v3 a mon avis
Le 01/05/2020 at 10:52, pafpaf a dit :
hey bon pour te repondre j ai modifier l A20M bord en v3 meme si j ai une v4 , j ai parler un peu avec lolo et il ma conseiller le s3d je test a l heure ou je t ecrit je fait un test en normal 2mm de couche et mon filament sur la bobine craque ^^ je suis sur une version de marlin modifie en 1.1.18 je vais voir si je trouve une board 2560 v3 sur du marlin 1.1.9.1 voir au pire des cas en marlin 2.0 je vais pouvoir regler mon imprimante mais lolo a raison via le logiciel c est plus simple s3d
je reinjecte ma modif de marlin avec boot perso apres l impression du cube pour controler la precision de cette derniere
