Bonjour a tous
Je viens d'installer Klipper, mais je me heurte a un problème de dimension.
Quand je lui demande 100mm sur n'importe quel axe, celui ci bouge du double soit 200mm.
Les step/mm sont ceux que j'utilisé sous Marlin, et la conversion a bien été faites pour passer en mm/step.
Mon imprimante est une CR10 avec une SKR 1.4 Turbo et TMC 2208 en UART.
Voici mon fichier config de Klipper :
# SKR V1.4 Turbo Creality CR10
# Configuration Base
[mcu]
serial: /dev/serial/by-id/usb-Klipper_lpc1769_0D90001047084AAFF8D46C5DC62000F5-if00
[printer]
kinematics: cartesian
max_velocity: 400
max_accel: 500
max_z_velocity: 10
max_z_accel: 100
# Configuration AXIS
[stepper_x]
step_pin: P2.2
dir_pin: !P2.6
enable_pin: !P2.1
step_distance: .0125
endstop_pin: P1.29
position_endstop: 0
position_max: 300
homing_speed: 50
[stepper_y]
step_pin: P0.19
dir_pin: !P0.20
enable_pin: !P2.8
endstop_pin: P1.28
position_endstop: 0
position_max: 300
homing_speed: 50
[stepper_z]
step_pin: P0.22
dir_pin: P2.11
enable_pin: !P0.21
step_distance: .0025
endstop_pin: P1.27
position_endstop: 0.0
position_max: 400
[extruder]
step_pin: P2.13
dir_pin: !P0.11
enable_pin: !P2.12
step_distance: .010526
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: P2.7
sensor_type: EPCOS 100K B57560G104F
sensor_pin: P0.24
control: pid
pid_Kp: 27.317
pid_Ki: 1.445
pid_Kd: 129.075
min_temp: 0
max_temp: 260
# Configuration HEAT BED AND FANS
[heater_bed]
heater_pin: P2.5
sensor_pin: P0.25
control: pid
pid_Kp: 75.252
pid_Ki: 0.941
pid_Kd: 1504.093
min_temp: 0
max_temp: 130
[fan]
pin: P2.3
[heater_fan my_nozzle_fan]
pin: P2.4
#heater_temp: 50.0
# TMC2208 configuration
#[tmc2208 stepper_x]
#uart_pin: P1.10
#microsteps: 16
#run_current: 0.850
#hold_current: 0.500
#stealthchop_threshold: 250
#[tmc2208 stepper_y]
#uart_pin: P1.9
#microsteps: 16
#run_current: 0.850
#[tmc2208 stepper_z]
#uart_pin: P1.8
#microsteps: 16
#run_current: 0.650
#hold_current: 0.450
#stealthchop_threshold: 30
#[tmc2208 extruder]
#uart_pin: P1.4
#microsteps: 16
#run_current: 0.800
#stealthchop_threshold: 5
Si quelqu'un aurait une idée de comment régler cela ?
Merci a tous et bonne journée
Salut. Les UART sont désactivés dans ta config. (il faut retirer le #). En l'état les TMC2209 sont en standalone et sans les jumpers MS1 MS2 en dessous ils fonctionnent en 1/8 au lieu de 1/16  => déplacement doublé. Corrige ta config et tout devrait rentrer dans l'ordre.
il y a 31 minutes, Tircown a dit :
Quel boulet je suis. Je te remercie, cela fonctionne maintenant
