Bonjour à tous les Klippériens,
La version 0.10.0 est sortie depuis peu.
De nouvelles fonctionnalités, des corrections de bugs en attendant le support de Python3 qui devrait arriver incessamment sous peu d'après Kevin O'Connor :
Révélation
Klipper 0.10.0
Available on 20210929. Major changes in this release:
  • Support for "Multi-MCU Homing". It is now possible for a stepper motor and its endstop to be wired to separate micro-controllers. This simplifies wiring of Z probes on "toolhead boards".
  • Klipper now has a Community Discord Server and a Community Discourse Server.
  • The Klipper website now uses the "mkdocs" infrastructure. There is also a Klipper Translations project.
  • Automated support for flashing firmware via sdcard on many boards.
  • New kinematic support for "Hybrid CoreXY" and "Hybrid CoreXZ" printers.
  • Klipper now uses rotation_distance to configure stepper motor travel distances.
  • The main Klipper host code can now directly communicate with micro-controllers using CAN bus.
  • New "motion analysis" system. Klipper's internal motion updates and sensor results can be tracked and logged for analysis.
  • Trinamic stepper motor drivers are now continuously monitored for error conditions.
  • Support for the rp2040 micro-controller (Raspberry Pi Pico boards).
  • The "make menuconfig" system now utilizes kconfiglib.
  • Many additional modules added: ds18b20, duplicate_pin_override, filament_motion_sensor, palette2, motion_report, pca9533, pulse_counter, save_variables, sdcard_loop, temperature_host, temperature_mcu
  • Several bug fixes and code cleanups.
Pas encore mis à jour, la CR10-V2 imprimant actuellement et n'étant pas du genre aventureux, j'attendrai la fin de l'impression. J'ai commencé à participer à la traduction dans notre belle langue (il y a du boulot 😉 ).
Modifié (le) par fran6p
