Je souhaite mettre a jour le firmware d'une imprimante ctc A13, j'ai donc préparé le firmware à flasher sauf qu'a la compilation j'ai plusieurs messages d'erreurs tous les deux dans le bootscreen.h et je ne trouve pas le problème.
In file included from Marlin\src\lcd\dogm\dogm_Bootscreen.h:40:0,
                 from Marlin\src\lcd\dogm\marlinui_DOGM.cpp:46:
g:\marlin\marlin\_bootscreen.h:37:7: error: expected unqualified-id before 'unsigned'
 const unsigned char custom_start_bmp[] PROGMEM = {
g:\marlin\marlin\_bootscreen.h:37:7: error: expected constructor, destructor, or type conversion before 'unsigned'
In file included from Marlin\src\lcd\dogm\marlinui_DOGM.cpp:46:0:
Marlin\src\lcd\dogm\marlinui_DOGM.cpp: In static member function 'static void MarlinUI::draw_custom_bootscreen(uint8_t)':
Marlin\src\lcd\dogm\dogm_Bootscreen.h:53:49: error: 'custom_start_bmp' was not declared in this scope
     #define CUSTOM_BOOTSCREEN_BMPHEIGHT (sizeof(custom_start_bmp) / (CUSTOM_BOOTSCREEN_BMP_BYTEWIDTH))
Marlin\src\lcd\dogm\dogm_Bootscreen.h:60:57: note: in expansion of macro 'CUSTOM_BOOTSCREEN_BMPHEIGHT'
       #define CUSTOM_BOOTSCREEN_Y ((LCD_PIXEL_HEIGHT - (CUSTOM_BOOTSCREEN_BMPHEIGHT)) / 2)
Marlin\src\lcd\dogm\marlinui_DOGM.cpp:119:46: note: in expansion of macro 'CUSTOM_BOOTSCREEN_Y'
                             top = u8g_uint_t(CUSTOM_BOOTSCREEN_Y);
Marlin\src\lcd\dogm\dogm_Bootscreen.h:53:49: note: suggested alternative: 'start_bmp'
*** [.pio\build\sanguino1284p\src\src\lcd\dogm\marlinui_DOGM.cpp.o] Error 1
================================================================================================== [FAILED] Took 26.21 seconds ==================================================================================================
Environment    Status    Duration
sanguino1284p  FAILED    00:00:26.215
============================================================================================= 1 failed, 0 succeeded in 00:00:26.215 =============================================================================================PS G:\Marlin> echo "done" >C:\Users\steph\AppData\Local\Temp\ipc
Merci pour votre aie par avance
A tu testé de désactiver (ajouter "//" en début de ligne) dans Configuration.h
#define SHOW_CUSTOM_BOOTSCREEN
voir même de désactiver
#define SHOW_BOOTSCREEN
car là sans le fichier "_Bootscreen.h" en question pas vraiment possible de savoir d'où viens cette erreur qui ressemble a un défaut d'environnement de compilation... ou a une coquille/incompatibilité dans ce fichier.
