Je n’arrive pas à faire fonctionner la touche extrusion manuelle sur l’écran TFT 35 BTT V3 , le menu est apparu une fois lorsque j’ai appuyer sur l’icône buse mais impossible de le refaire.
je presice que sur la photo la température de la buse est de 20• c mais j’ai fais l’essai avec la buse à plus de 180 qui est le seuil de déclenchement.
config Marlin 2 carte rumba 32 Btt
un parametrage dans Marlin ? Dans le TFT ?
merci pour votre aide
Va sur le github, tu as toute la liste des fonctions à activer dans Marlin pour bien faire fonctionner le TFT.
General options which MUST be always activated:
EEPROM_SETTINGS (in Configuration.h)
BABYSTEPPING (in Configuration_adv.h)
AUTO_REPORT_TEMPERATURES (in Configuration_adv.h)
AUTO_REPORT_POSITION (in Configuration_adv.h)
M115_GEOMETRY_REPORT (in Configuration_adv.h)
M114_DETAIL (in Configuration_adv.h)
REPORT_FAN_CHANGE (in Configuration_adv.h)
Options to support printing from onboard media:
SDSUPPORT (in Configuration.h)
LONG_FILENAME_HOST_SUPPORT (in Configuration_adv.h)
AUTO_REPORT_SD_STATUS (in Configuration_adv.h)
SDCARD_CONNECTION ONBOARD (in Configuration_adv.h)
Options to support dialog with host:
EMERGENCY_PARSER (in Configuration_adv.h)
SERIAL_FLOAT_PRECISION 4 (in Configuration_adv.h)
HOST_ACTION_COMMANDS (in Configuration_adv.h)
HOST_PROMPT_SUPPORT (in Configuration_adv.h)
HOST_STATUS_NOTIFICATIONS (in Configuration_adv.h)
Options to support M600 with host & (Un)Load menu:
Options to support dialog with host (as pre requisite)
NOZZLE_PARK_FEATURE (in Configuration.h)
ADVANCED_PAUSE_FEATURE (in Configuration_adv.h)
PARK_HEAD_ON_PAUSE (in Configuration_adv.h)
FILAMENT_LOAD_UNLOAD_GCODES (in Configuration_adv.h)
Options to fully support Bed Leveling menu:
Z_MIN_PROBE_REPEATABILITY_TEST (in Configuration.h)
G26_MESH_VALIDATION (in Configuration.h)
Z_STEPPER_AUTO_ALIGN (in Configuration_adv.h)
https://github.com/bigtreetech/BIGTREETECH-TouchScreenFirmware
