loicbujard9 Posté(e) Janvier 17 Partager Posté(e) Janvier 17 (modifié) Bonjours je suis actuellement en train de modifier une Ender pro 3, j'ai remplacer la carte mère 1.1.4 par une bigtreetech E3 V3 est je lui ais ajouter un bltouch est un capteur de filament. je suis entrain de modifier le firmware pour paramétrer les diffèrent élément ajouter est a chaque fois que je passe a la compilation j'obtiens l'erreur In file included from Marlin\src\HAL\STM32\MarlinSPI.cpp:27: Marlin\src\HAL\STM32\MarlinSPI.h:99:3: error: 'spi_mode_e' does not name a type 99 | spi_mode_e _dataMode; | ^~~~~~~~~~ Marlin\src\HAL\STM32\MarlinSPI.h: In constructor 'MarlinSPI::MarlinSPI(pin_t, pin_t, pin_t, pin_t)': Marlin\src\HAL\STM32\MarlinSPI.h:64:5: error: '_dataMode' was not declared in this scope; did you mean '_dataSize'? 64 | _dataMode = SPI_MODE_0; | ^~~~~~~~~ | _dataSize Marlin\src\HAL\STM32\MarlinSPI.h:64:17: error: 'SPI_MODE_0' was not declared in this scope; did you mean 'SPI_MODE0'? 64 | _dataMode = SPI_MODE_0; | ^~~~~~~~~~ | SPI_MODE0 Marlin\src\HAL\STM32\MarlinSPI.h: In member function 'void MarlinSPI::setDataMode(uint8_t)': Marlin\src\HAL\STM32\MarlinSPI.h:83:23: error: '_dataMode' was not declared in this scope; did you mean '_dataSize'? 83 | case SPI_MODE0: _dataMode = SPI_MODE_0; break; | ^~~~~~~~~ | _dataSize Marlin\src\HAL\STM32\MarlinSPI.h:83:35: error: 'SPI_MODE_0' was not declared in this scope; did you mean 'SPI_MODE0'? 83 | case SPI_MODE0: _dataMode = SPI_MODE_0; break; | ^~~~~~~~~~ | SPI_MODE0 compilation terminated due to -fmax-errors=5. *** [.pio\build\STM32G0B1RE_btt\src\src\HAL\STM32\MarlinSPI.cpp.o] Error 1 ================================================================== [FAILED] Took 20.16 seconds ================================================================== Environment Status Duration --------------- -------- ------------ STM32G0B1RE_btt FAILED 00:00:20.156 ============================================================= 1 failed, 0 succeeded in 00:00:20.156 ============================================================= * The terminal process "C:\Users\Barto\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'STM32G0B1RE_btt'" terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it. est du coup je ne sait plus quoi faire. j'ai changer d'ordinateur pour un ordinateur don je viens de finir de réinstaller le system d'exploitation, j'ai bien fait attention a mètre un nom d'utilisateur sans espace (ceux qui na surment pas d'influence mais c'est pas grave je lais lu dans un forum est dans le doute je lais fait) puit pour le répertoire de marlin2.1.2.1 je lais crée dans la racine du disk ceux qui donne C:\Marlin-2.1.2.1 est sa na pas fonctionner ceux qui est bizzard c'est que avent de changer le configuration.h est configuration_adv.h j'arrivais a buildé est obtenir le .bin est des que je mets les fichier du dossier BigTreeTech SKR Mini E3 3.0 sa ne fonctionne plus. je ne comprend plus rien car avec la creality 4.2.2 j'arrivais a crée le .bin "bon jai quand même changer 3 fois d0ordinateur" si je ne me trompe pas mon je suis sur un STM32G0B1RE ou un STM32G0B0RE mais d'appret ce que j'ai vu sur la cm la deux emme possibilité est la plus propable mon bltouch est mon capteur de filament son connecter comme sur la photo qui suit pouvais vous m'aider a trouver une solution a ce souci ou voir meme si il y a quel q'un qui a une version du firmward qui correspond a ma configuration je suis preneur je vous remerci pour votre aide Il y a 2 heures, loicbujard9 a dit : Édit : j'ai supprimé la mauvaise photo Modifié (le) Janvier 17 par pascal_lb Lien vers le commentaire Partager sur d’autres sites More sharing options...
pommeverte Posté(e) Janvier 17 Partager Posté(e) Janvier 17 Salut, Je pense que la solution est donnée au début de ce message (lien reddit) Lien vers le commentaire Partager sur d’autres sites More sharing options...
loicbujard9 Posté(e) Janvier 17 Auteur Partager Posté(e) Janvier 17 il y a 38 minutes, pommeverte a dit : Salut, Je pense que la solution est donnée au début de ce message (lien reddit) super merci je regarderais demain je suis trop crever est je risquerais de faire des connerie. je veux aller dormir car j'ai commencer ma journée a 1h30 ce matin a cause d'une urgence dans mon travail, heureusement demain j'ai congé j'en profiterais pour le faire Lien vers le commentaire Partager sur d’autres sites More sharing options...
loicbujard9 Posté(e) Janvier 19 Auteur Partager Posté(e) Janvier 19 bonjours Jai réussi a faire fonctionner mon bltouch est mon capteur de filament merci pour votre aide maintenant il me reste plus que a la réglée Lien vers le commentaire Partager sur d’autres sites More sharing options...
