Propriétaire depuis quelques semaines d'une Anycubic Mega I3, j'ai imprimé plusieurs petits modèle sans trop de soucis et j'ai décidé d'essayer avant d'imprimer de plus gros pièces d'imprimer un modèle de benchmark (http://www.3dbenchy.com/)
Et malgré de nombreux essais avec divers réglages, impossible d'obtenir un résultat correct. Du coup, je craque un peu.
Le dernier test en date : DSC_0054.thumb.JPG.f1280f980428900ee61cede328ad8467.JPG
Pour cette impression, j'ai utilisé ces paramètres dans Cura:
layer_height = 0.1
wall_thickness = 0.8
retraction_enable = True
solid_layer_thickness = 0.8
fill_density = 10
print_speed = 50
print_temperature = 198
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 65
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 105
nozzle_size = 0.4
retraction_speed = 25
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 70
bottom_layer_speed = 20
infill_speed = 0.0
solidarea_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 50
fan_speed_max = 75
cool_min_feedrate = 10
cool_head_lift = True
solid_top = True
solid_bottom = True
fill_overlap = 15
perimeter_before_infill = False
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 20
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
Quelqu'un aurait-il une idée? Comme on dit Obiwan vous êtes notre dernier espoir...
c'est en effet pas terrible...! surtout pour une anycubic..! indique  la version  de ta mega et post plutôt dans le forum anycubic.
Si possible post les photos de tes réglages c'est beaucoup moins rébarbatif que ta liste
bonjour vintz,
As-tu vérifier le diamètre de ton filament, bien souvent le fournisseur indique du 1,75mm mais quand tu mesure en réalité il est plutôt au alentour des 1,78 ou 1,79mm. Après je pense pas que ton problème vienne de la. J'ai l'impression quelle passe jamais vraiment au même endroit, peut-être les courroies qui ne sont pas assez tendues.
J'ai résolu le souci avec l'aide des membres de la section Anycubic. (une erreur de paramétrage de la vitesse du ventilateur)
Merci tout de même.
