PETG Sakata
bonjour, je rencontre un probleme avec cncjs. une erreur je ne sais quoi c'est produit, et depuis je n'arrive plus à controller ma cnc.
il m'indique GRBL ALARM et tout mes parametres sont à zéro. plus moyens de bouger les axes, j'ai réinstaller grbl sur mon arduino.
mes toujours rien, si quelqu'un à deja eu le tour. pouvez vous m'aiser merci
Lien vers le commentaire
voila la console maintenant
CNCjs 1.9.22 [Grbl]
Connected to COM21 with a baud rate of 115200
Grbl 0.9j ['$' for help]
client> $$
['$H'|'$X' to unlock]
$0=10 (step pulse, usec)
$1=65 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=0 (dir port invert mask:00000000)
$4=1 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=97 (status report mask:01100001)
$11=0.000 (junction deviation, mm)
$12=0.000 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=5 (homing dir invert mask:00000101)
$24=0.000 (homing feed, mm/min)
$25=2147483.648 (homing seek, mm/min)
$26=7 (homing debounce, msec)
$27=0.000 (homing pull-off, mm)
$100=400.000 (x, step/mm)
$101=400.000 (y, step/mm)
$102=400.000 (z, step/mm)
$110=0.000 (x max rate, mm/min)
$111=0.000 (y max rate, mm/min)
$112=0.000 (z max rate, mm/min)
$120=2147483.648 (x accel, mm/sec^2)
$171=0.000 (x accel, mm/sec^2)
$172=0.000 (x accel, mm/sec^2)
$173=0.000 (x accel, mm/sec^2)
$174=0.000 (x accel, mm/sec^2)
$175=0.000 (x accel, mm/sec^2)
$176=0.002 (x accel, mm/sec^2)
$177=-0.044 (x accel, mm/sec^2)
$178=110.940 (x accel, mm/sec^2)
$179=0.000 (x accel, mm/sec^2)
$180=0.000 (x accel, mm/sec^2)
$181=0.000 (x accel, mm/sec^2)
$182=0.000 (x accel, mm/sec^2)
$183=0.000 (x accel, mm/sec^2)
$184=0.000 (x accel, mm/sec^2)
$185=0.000 (x accel, mm/sec^2)
$186=0.000 (x accel, mm/sec^2)
$187=0.000 (x accel, mm/sec^2)
$188=0.000 (x accel, mm/sec^2)
$189=0.000 (x accel, mm/sec^2)
$190=0.000 (x accel, mm/sec^2)
$191=0.000 (x accel, mm/sec^2)
$192=0.000 (x accel, mm/sec^2)
$193=0.000 (x accel, mm/sec^2)
$194=0.000 (x accel, mm/sec^2)
$195=0.000 (x accel, mm/sec^2)
$196=0.000 (x accel, mm/sec^2)
$197=0.000 (x accel, mm/sec^2)
$198=0.000 (x accel, mm/sec^2)
$199=0.000 (x accel, mm/sec^2)
$200=0.000 (x accel, mm/sec^2)
$201=0.000 (x accel, mm/sec^2)
$202=0.000 (x accel, mm/sec^2)
$203=0.000 (x accel, mm/sec^2)
$204=0.000 (x accel, mm/sec^2)
$205=0.000 (x accel, mm/sec^2)
$206=0.000 (x accel, mm/sec^2)
$207=0.000 (x accel, mm/sec^2)
$208=0.000 (x accel, mm/sec^2)
$209=0.000 (x accel, mm/sec^2)
$210=0.000 (x accel, mm/sec^2)
$211=0.000 (x accel, mm/sec^2)
$212=0.000 (x accel, mm/sec^2)
$213=0.000 (x accel, mm/sec^2)
$214=2147483.648 (x accel, mm/sec^2)
$171=2147483.648 (x accel, mm/sec^2)
$175=392806.400 (x accel, mm/sec^2)
$176=0.000 (x accel, mm/sec^2)
$177=0.000 (x accel, mm/sec^2)
$178=-0.000 (x accel, mm/sec^2)
$179=-2147483.648 (x accel, mm/sec^2)
$172=2147483.648 (x accel, mm/sec^2)
$171=-0.000 (x accel, mm/sec^2)
$172=-0.000 (x accel, mm/sec^2)
$173=-0.000 (x accel, mm/sec^2)
$174=-2147483.648 (x accel, mm/sec^2)
$172=-2147483.648 (x accel, mm/sec^2)
$171=-2147483.648 (x accel, mm/sec^2)
$174=2147483.648 (x accel, mm/sec^2)
$173=-2147483.648 (x accel, mm/sec^2)
$173=-0.166 (x accel, mm/sec^2)
$173=2147483.648 (x accel, mm/sec^2)
$171=234730.320 (x accel, mm/sec^2)
$171=-6252.648 (x accel, mm/sec^2)
$173=-506.821 (x accel, mm/sec^2)
$171=15.893 (x accel, mm/sec^2)
$171=-60530.476 (x accel, mm/sec^2)
$171=1034587.776 (x accel, mm/sec^2)
$170=0.000 (x accel, mm/sec^2)
$178=0.000 (x accel, mm/sec^2)
$179=2.286 (x accel, mm/sec^2)
$184=-0.000 (x accel, mm/sec^2)
$187=-0.001 (x accel, mm/sec^2)
$189=-0.013 (x accel, mm/sec^2)
$194=-2147483.648 (x accel, mm/sec^2)
$214=0.000 (x accel, mm/sec^2)
$215=0.000 (x accel, mm/sec^2)
$216=0.000 (x accel, mm/sec^2)
$217=0.000 (x accel, mm/sec^2)
$218=0.000 (x accel, mm/sec^2)
$219=0.000 (x accel, mm/sec^2)
$220=0.000 (x accel, mm/sec^2)
$221=0.000 (x accel, mm/sec^2)
$222=0.000 (x accel, mm/sec^2)
$223=0.000 (x accel, mm/sec^2)
$224=0.000 (x accel, mm/sec^2)
$225=0.000 (x accel, mm/sec^2)
$226=0.000 (x accel, mm/sec^2)
$227=0.000 (x accel, mm/sec^2)
$228=0.000 (x accel, mm/sec^2)
$229=0.000 (x accel, mm/sec^2)
$230=0.000 (x accel, mm/sec^2)
$231=0.000 (x accel, mm/sec^2)
$232=0.000 (x accel, mm/sec^2)
$233=0.000 (x accel, mm/sec^2)
$234=0.000 (x accel, mm/sec^2)
$235=0.000 (x accel, mm/sec^2)
$236=0.000 (x accel, mm/sec^2)
$237=0.000 (x accel, mm/sec^2)
$238=0.000 (x accel, mm/sec^2)
$239=0.000 (x accel, mm/sec^2)
$240=0.000 (x accel, mm/sec^2)
$241=0.000 (x accel, mm/sec^2)
$242=0.000 (x accel, mm/sec^2)
$243=0.000 (x accel, mm/sec^2)
$244=0.000 (x accel, mm/sec^2)
$245=0.000 (x accel, mm/sec^2)
$246=0.000 (x accel, mm/sec^2)
$247=0.000 (x accel, mm/sec^2)
$248=0.000 (x accel, mm/sec^2)
$249=0.000 (x accel, mm/sec^2)
$250=0.000 (x accel, mm/sec^2)
$251=0.000 (x accel, mm/sec^2)
$252=0.000 (x accel, mm/sec^2)
$253=0.000 (x accel, mm/sec^2)
$254=0.000 (x accel, mm/sec^2)
$255=0.000 (x accel, mm/sec^2)
$0=0.000 (x accel, mm/sec^2)
$1=0.000 (x accel, mm/sec^2)
$2=0.000 (x accel, mm/sec^2)
$3=0.000 (x accel, mm/sec^2)
$4=0.000 (x accel, mm/sec^2)
$5=0.000 (x accel, mm/sec^2)
$6=0.000 (x accel, mm/sec^2)
$7=0.000 (x accel, mm/sec^2)
$8=0.000 (x accel, mm/sec^2)
$9=0.000 (x accel, mm/sec^2)
$10=0.000 (x accel, mm/sec^2)
$11=0.000 (x accel, mm/sec^2)
$12=0.000 (x accel, mm/sec^2)
$13=0.000 (x accel, mm/sec^2)
$14=0.000 (x accel, mm/sec^2)
$15=0.000 (x accel, mm/sec^2)
$16=0.000 (x accel, mm/sec^2)
$17=0.000 (x accel, mm/sec^2)
$18=0.000 (x accel, mm/sec^2)
$19=0.000 (x accel, mm/sec^2)
$20=0.000 (x accel, mm/sec^2)
$21=0.000 (x accel, mm/sec^2)
$22=0.000 (x accel, mm/sec^2)
$23=0.000 (x accel, mm/sec^2)
$24=0.000 (x accel, mm/sec^2)
$25=0.000 (x accel, mm/sec^2)
$26=0.000 (x accel, mm/sec^2)
$27=0.000 (x accel, mm/sec^2)
$28=0.000 (x accel, mm/sec^2)
$29=0.000 (x accel, mm/sec^2)
$30=0.000 (x accel, mm/sec^2)
$31=0.000 (x accel, mm/sec^2)
$32=0.000 (x accel, mm/sec^2)
$33=0.000 (x accel, mm/sec^2)
$34=0.000 (x accel, mm/sec^2)
$35=0.000 (x accel, mm/sec^2)
$36=0.000 (x accel, mm/sec^2)
$37=0.000 (x accel, mm/sec^2)
$38=0.000 (x accel, mm/sec^2)
$39=0.000 (x accel, mm/sec^2)
$40=0.000 (x accel, mm/sec^2)
$41=0.000 (x accel, mm/sec^2)
$42=0.000 (x accel, mm/sec^2)
$43=0.000 (x accel, mm/sec^2)
$44=0.000 (x accel, mm/sec^2)
$45=0.000 (x accel, mm/sec^2)
$46=0.000 (x accel, mm/sec^2)
$47=0.000 (x accel, mm/sec^2)
$48=0.000 (x accel, mm/sec^2)
$49=0.000 (x accel, mm/sec^2)
$50=0.000 (x accel, mm/sec^2)
$51=0.000 (x accel, mm/sec^2)
$52=0.000 (x accel, mm/sec^2)
$53=0.000 (x accel, mm/sec^2)
$54=0.000 (x accel, mm/sec^2)
$55=0.000 (x accel, mm/sec^2)
$56=0.000 (x accel, mm/sec^2)
$57=0.000 (x accel, mm/sec^2)
$58=0.000 (x accel, mm/sec^2)
$59=0.000 (x accel, mm/sec^2)
$60=0.000 (x accel, mm/sec^2)
$61=0.000 (x accel, mm/sec^2)
$62=0.000 (x accel, mm/sec^2)
$63=0.000 (x accel, mm/sec^2)
$64=0.000 (x accel, mm/sec^2)
$65=0.000 (x accel, mm/sec^2)
$66=0.000 (x accel, mm/sec^2)
$67=0.000 (x accel, mm/sec^2)
$68=0.000 (x accel, mm/sec^2)
$69=0.000 (x accel, mm/sec^2)
$70=0.000 (x accel, mm/sec^2)
$71=0.000 (x accel, mm/sec^2)
$72=0.000 (x accel, mm/sec^2)
$73=0.000 (x accel, mm/sec^2)
$74=0.000 (x accel, mm/sec^2)
$75=0.000 (x accel, mm/sec^2)
$76=0.000 (x accel, mm/sec^2)
$77=0.000 (x accel, mm/sec^2)
$78=0.000 (x accel, mm/sec^2)
$79=0.000 (x accel, mm/sec^2)
$80=0.000 (x accel, mm/sec^2)
$81=0.000 (x accel, mm/sec^2)
$82=0.000 (x accel, mm/sec^2)
$83=0.000 (x accel, mm/sec^2)
$84=0.000 (x accel, mm/sec^2)
$85=0.000 (x accel, mm/sec^2)
$86=0.000 (x accel, mm/sec^2)
$87=0.000 (x accel, mm/sec^2)
$88=0.000 (x accel, mm/sec^2)
$89=0.000 (x accel, mm/sec^2)
$90=0.000 (x accel, mm/sec^2)
$91=0.000 (x accel, mm/sec^2)
$92=0.000 (x accel, mm/sec^2)
$93=0.000 (x accel, mm/sec^2)
$94=0.000 (x accel, mm/sec^2)
$95=0.000 (x accel, mm/sec^2)
$96=0.000 (x accel, mm/sec^2)
$97=0.000 (x accel, mm/sec^2)
$98=0.000 (x accel, mm/sec^2)
$99=0.000 (x accel, mm/sec^2)
$100=0.000 (x accel, mm/sec^2)
$101=0.000 (x accel, mm/sec^2)
$102=0.000 (x accel, mm/sec^2)
$103=0.000 (x accel, mm/sec^2)
$104=0.000 (x accel, mm/sec^2)
$105=0.000 (x accel, mm/sec^2)
$106=0.000 (x accel, mm/sec^2)
$107=0.000 (x accel, mm/sec^2)
$108=0.000 (x accel, mm/sec^2)
$109=0.000 (x accel, mm/sec^2)
$110=0.000 (x accel, mm/sec^2)
$111=0.000 (x accel, mm/sec^2)
$112=0.000 (x accel, mm/sec^2)
$113=0.000 (x accel, mm/sec^2)
$114=0.000 (x accel, mm/sec^2)
$115=0.000 (x accel, mm/sec^2)
$116=0.000 (x accel, mm/sec^2)
$117=0.000 (x accel, mm/sec^2)
$118=0.000 (x accel, mm/sec^2)
$119=0.000 (x accel, mm/sec^2)
$120=0.000 (x accel, mm/sec^2)
$121=0.000 (y accel, mm/sec^2)
$122=0.000 (z accel, mm/sec^2)
$130=-0.000 (x max travel, mm)
$131=-0.000 (y max travel, mm)
$132=-0.000 (z max travel, mm)
ok
tien voila le mien regarde
$0=10 (Step pulse time)
$1=25 (Step idle delay)
$2=0 (Step pulse invert)
$3=2 (Step direction invert)
$4=0 (Invert step enable pin)
$5=0 (Invert limit pins)
$6=0 (Invert probe pin)
$10=1 (Status report options)
$11=0.010 (Junction deviation)
$12=0.002 (Arc tolerance)
$13=0 (Report in inches)
$20=0 (Soft limits enable)
$21=0 (Hard limits enable)
$22=1 (Homing cycle enable)
$23=3 (Homing direction invert)
$24=25.000 (Homing locate feed rate)
$25=500.000 (Homing search seek rate)
$26=250 (Homing switch debounce delay)
$27=1.000 (Homing switch pull-off distance)
$30=1000 (Maximum spindle speed)
$31=0 (Minimum spindle speed)
$32=0 (Laser-mode enable)
$100=400.000 (X-axis travel resolution)
$101=400.000 (Y-axis travel resolution)
$102=400.000 (Z-axis travel resolution)
$110=800.000 (X-axis maximum rate)
$111=800.000 (Y-axis maximum rate)
$112=800.000 (Z-axis maximum rate)
$120=800.000 (X-axis acceleration)
$121=800.000 (Y-axis acceleration)
$122=400.000 (Z-axis acceleration)
$130=290.000 (X-axis maximum travel)
$131=170.000 (Y-axis maximum travel)
$132=40.000 (Z-axis maximum travel)
tu a des chiffres pas tres cohérent au 25 120 et plusieurs fois des chiffre aussi
Hola mais c'est quoi cette tétrachiée de paramètres ?????
Surtout que des "x accel" y'en a autant que le Bondieu peut en bénir
Faudrait ptêt faire une risette de l'Arduino
Tu l'as trouvé où ton GRBL ?
