dago59 Posté(e) Novembre 4, 2020 Posté(e) Novembre 4, 2020 bonjour, je rencontre un probleme avec cncjs. une erreur je ne sais quoi c'est produit, et depuis je n'arrive plus à controller ma cnc. il m'indique GRBL ALARM et tout mes parametres sont à zéro. plus moyens de bouger les axes, j'ai réinstaller grbl sur mon arduino. mes toujours rien, si quelqu'un à deja eu le tour. pouvez vous m'aiser merci
dago59 Posté(e) Novembre 4, 2020 Auteur Posté(e) Novembre 4, 2020 voila la console maintenant CNCjs 1.9.22 [Grbl] Connected to COM21 with a baud rate of 115200 Grbl 0.9j ['$' for help] client> $$ ['$H'|'$X' to unlock] $0=10 (step pulse, usec) $1=65 (step idle delay, msec) $2=0 (step port invert mask:00000000) $3=0 (dir port invert mask:00000000) $4=1 (step enable invert, bool) $5=0 (limit pins invert, bool) $6=0 (probe pin invert, bool) $10=97 (status report mask:01100001) $11=0.000 (junction deviation, mm) $12=0.000 (arc tolerance, mm) $13=0 (report inches, bool) $20=0 (soft limits, bool) $21=0 (hard limits, bool) $22=1 (homing cycle, bool) $23=5 (homing dir invert mask:00000101) $24=0.000 (homing feed, mm/min) $25=2147483.648 (homing seek, mm/min) $26=7 (homing debounce, msec) $27=0.000 (homing pull-off, mm) $100=400.000 (x, step/mm) $101=400.000 (y, step/mm) $102=400.000 (z, step/mm) $110=0.000 (x max rate, mm/min) $111=0.000 (y max rate, mm/min) $112=0.000 (z max rate, mm/min) $120=2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=0.000 (x accel, mm/sec^2) $174=0.000 (x accel, mm/sec^2) $175=0.000 (x accel, mm/sec^2) $176=0.002 (x accel, mm/sec^2) $177=-0.044 (x accel, mm/sec^2) $178=110.940 (x accel, mm/sec^2) $179=0.000 (x accel, mm/sec^2) $180=0.000 (x accel, mm/sec^2) $181=0.000 (x accel, mm/sec^2) $182=0.000 (x accel, mm/sec^2) $183=0.000 (x accel, mm/sec^2) $184=0.000 (x accel, mm/sec^2) $185=0.000 (x accel, mm/sec^2) $186=0.000 (x accel, mm/sec^2) $187=0.000 (x accel, mm/sec^2) $188=0.000 (x accel, mm/sec^2) $189=0.000 (x accel, mm/sec^2) $190=0.000 (x accel, mm/sec^2) $191=0.000 (x accel, mm/sec^2) $192=0.000 (x accel, mm/sec^2) $193=0.000 (x accel, mm/sec^2) $194=0.000 (x accel, mm/sec^2) $195=0.000 (x accel, mm/sec^2) $196=0.000 (x accel, mm/sec^2) $197=0.000 (x accel, mm/sec^2) $198=0.000 (x accel, mm/sec^2) $199=0.000 (x accel, mm/sec^2) $200=0.000 (x accel, mm/sec^2) $201=0.000 (x accel, mm/sec^2) $202=0.000 (x accel, mm/sec^2) $203=0.000 (x accel, mm/sec^2) $204=0.000 (x accel, mm/sec^2) $205=0.000 (x accel, mm/sec^2) $206=0.000 (x accel, mm/sec^2) $207=0.000 (x accel, mm/sec^2) $208=0.000 (x accel, mm/sec^2) $209=0.000 (x accel, mm/sec^2) $210=0.000 (x accel, mm/sec^2) $211=0.000 (x accel, mm/sec^2) $212=0.000 (x accel, mm/sec^2) $213=0.000 (x accel, mm/sec^2) $214=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=0.000 (x accel, mm/sec^2) $174=0.000 (x accel, mm/sec^2) $175=392806.400 (x accel, mm/sec^2) $176=0.000 (x accel, mm/sec^2) $177=0.000 (x accel, mm/sec^2) $178=-0.000 (x accel, mm/sec^2) $179=-2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=-0.000 (x accel, mm/sec^2) $174=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=0.000 (x accel, mm/sec^2) $174=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=-0.000 (x accel, mm/sec^2) $174=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=-0.166 (x accel, mm/sec^2) $174=-2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=234730.320 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=-2147483.648 (x accel, mm/sec^2) $171=-6252.648 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=-506.821 (x accel, mm/sec^2) $174=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=15.893 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-60530.476 (x accel, mm/sec^2) $172=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=-2147483.648 (x accel, mm/sec^2) $171=1034587.776 (x accel, mm/sec^2) $170=0.000 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=-2147483.648 (x accel, mm/sec^2) $171=-0.000 (x accel, mm/sec^2) $172=-0.000 (x accel, mm/sec^2) $173=0.000 (x accel, mm/sec^2) $174=0.000 (x accel, mm/sec^2) $175=0.000 (x accel, mm/sec^2) $176=0.000 (x accel, mm/sec^2) $177=0.000 (x accel, mm/sec^2) $178=0.000 (x accel, mm/sec^2) $179=2.286 (x accel, mm/sec^2) $180=0.000 (x accel, mm/sec^2) $181=0.000 (x accel, mm/sec^2) $182=0.000 (x accel, mm/sec^2) $183=0.000 (x accel, mm/sec^2) $184=-0.000 (x accel, mm/sec^2) $185=0.000 (x accel, mm/sec^2) $186=0.000 (x accel, mm/sec^2) $187=-0.001 (x accel, mm/sec^2) $188=0.000 (x accel, mm/sec^2) $189=-0.013 (x accel, mm/sec^2) $190=0.000 (x accel, mm/sec^2) $191=0.000 (x accel, mm/sec^2) $192=0.000 (x accel, mm/sec^2) $193=0.000 (x accel, mm/sec^2) $194=-2147483.648 (x accel, mm/sec^2) $171=2147483.648 (x accel, mm/sec^2) $171=0.000 (x accel, mm/sec^2) $172=0.000 (x accel, mm/sec^2) $173=0.000 (x accel, mm/sec^2) $174=0.000 (x accel, mm/sec^2) $175=0.000 (x accel, mm/sec^2) $176=0.000 (x accel, mm/sec^2) $177=0.000 (x accel, mm/sec^2) $178=0.000 (x accel, mm/sec^2) $179=0.000 (x accel, mm/sec^2) $180=0.000 (x accel, mm/sec^2) $181=0.000 (x accel, mm/sec^2) $182=0.000 (x accel, mm/sec^2) $183=0.000 (x accel, mm/sec^2) $184=0.000 (x accel, mm/sec^2) $185=0.000 (x accel, mm/sec^2) $186=0.000 (x accel, mm/sec^2) $187=0.000 (x accel, mm/sec^2) $188=0.000 (x accel, mm/sec^2) $189=0.000 (x accel, mm/sec^2) $190=0.000 (x accel, mm/sec^2) $191=0.000 (x accel, mm/sec^2) $192=0.000 (x accel, mm/sec^2) $193=0.000 (x accel, mm/sec^2) $194=0.000 (x accel, mm/sec^2) $195=0.000 (x accel, mm/sec^2) $196=0.000 (x accel, mm/sec^2) $197=0.000 (x accel, mm/sec^2) $198=0.000 (x accel, mm/sec^2) $199=0.000 (x accel, mm/sec^2) $200=0.000 (x accel, mm/sec^2) $201=0.000 (x accel, mm/sec^2) $202=0.000 (x accel, mm/sec^2) $203=0.000 (x accel, mm/sec^2) $204=0.000 (x accel, mm/sec^2) $205=0.000 (x accel, mm/sec^2) $206=0.000 (x accel, mm/sec^2) $207=0.000 (x accel, mm/sec^2) $208=0.000 (x accel, mm/sec^2) $209=0.000 (x accel, mm/sec^2) $210=0.000 (x accel, mm/sec^2) $211=0.000 (x accel, mm/sec^2) $212=0.000 (x accel, mm/sec^2) $213=0.000 (x accel, mm/sec^2) $214=0.000 (x accel, mm/sec^2) $215=0.000 (x accel, mm/sec^2) $216=0.000 (x accel, mm/sec^2) $217=0.000 (x accel, mm/sec^2) $218=0.000 (x accel, mm/sec^2) $219=0.000 (x accel, mm/sec^2) $220=0.000 (x accel, mm/sec^2) $221=0.000 (x accel, mm/sec^2) $222=0.000 (x accel, mm/sec^2) $223=0.000 (x accel, mm/sec^2) $224=0.000 (x accel, mm/sec^2) $225=0.000 (x accel, mm/sec^2) $226=0.000 (x accel, mm/sec^2) $227=0.000 (x accel, mm/sec^2) $228=0.000 (x accel, mm/sec^2) $229=0.000 (x accel, mm/sec^2) $230=0.000 (x accel, mm/sec^2) $231=0.000 (x accel, mm/sec^2) $232=0.000 (x accel, mm/sec^2) $233=0.000 (x accel, mm/sec^2) $234=0.000 (x accel, mm/sec^2) $235=0.000 (x accel, mm/sec^2) $236=0.000 (x accel, mm/sec^2) $237=0.000 (x accel, mm/sec^2) $238=0.000 (x accel, mm/sec^2) $239=0.000 (x accel, mm/sec^2) $240=0.000 (x accel, mm/sec^2) $241=0.000 (x accel, mm/sec^2) $242=0.000 (x accel, mm/sec^2) $243=0.000 (x accel, mm/sec^2) $244=0.000 (x accel, mm/sec^2) $245=0.000 (x accel, mm/sec^2) $246=0.000 (x accel, mm/sec^2) $247=0.000 (x accel, mm/sec^2) $248=0.000 (x accel, mm/sec^2) $249=0.000 (x accel, mm/sec^2) $250=0.000 (x accel, mm/sec^2) $251=0.000 (x accel, mm/sec^2) $252=0.000 (x accel, mm/sec^2) $253=0.000 (x accel, mm/sec^2) $254=0.000 (x accel, mm/sec^2) $255=0.000 (x accel, mm/sec^2) $0=0.000 (x accel, mm/sec^2) $1=0.000 (x accel, mm/sec^2) $2=0.000 (x accel, mm/sec^2) $3=0.000 (x accel, mm/sec^2) $4=0.000 (x accel, mm/sec^2) $5=0.000 (x accel, mm/sec^2) $6=0.000 (x accel, mm/sec^2) $7=0.000 (x accel, mm/sec^2) $8=0.000 (x accel, mm/sec^2) $9=0.000 (x accel, mm/sec^2) $10=0.000 (x accel, mm/sec^2) $11=0.000 (x accel, mm/sec^2) $12=0.000 (x accel, mm/sec^2) $13=0.000 (x accel, mm/sec^2) $14=0.000 (x accel, mm/sec^2) $15=0.000 (x accel, mm/sec^2) $16=0.000 (x accel, mm/sec^2) $17=0.000 (x accel, mm/sec^2) $18=0.000 (x accel, mm/sec^2) $19=0.000 (x accel, mm/sec^2) $20=0.000 (x accel, mm/sec^2) $21=0.000 (x accel, mm/sec^2) $22=0.000 (x accel, mm/sec^2) $23=0.000 (x accel, mm/sec^2) $24=0.000 (x accel, mm/sec^2) $25=0.000 (x accel, mm/sec^2) $26=0.000 (x accel, mm/sec^2) $27=0.000 (x accel, mm/sec^2) $28=0.000 (x accel, mm/sec^2) $29=0.000 (x accel, mm/sec^2) $30=0.000 (x accel, mm/sec^2) $31=0.000 (x accel, mm/sec^2) $32=0.000 (x accel, mm/sec^2) $33=0.000 (x accel, mm/sec^2) $34=0.000 (x accel, mm/sec^2) $35=0.000 (x accel, mm/sec^2) $36=0.000 (x accel, mm/sec^2) $37=0.000 (x accel, mm/sec^2) $38=0.000 (x accel, mm/sec^2) $39=0.000 (x accel, mm/sec^2) $40=0.000 (x accel, mm/sec^2) $41=0.000 (x accel, mm/sec^2) $42=0.000 (x accel, mm/sec^2) $43=0.000 (x accel, mm/sec^2) $44=0.000 (x accel, mm/sec^2) $45=0.000 (x accel, mm/sec^2) $46=0.000 (x accel, mm/sec^2) $47=0.000 (x accel, mm/sec^2) $48=0.000 (x accel, mm/sec^2) $49=0.000 (x accel, mm/sec^2) $50=0.000 (x accel, mm/sec^2) $51=0.000 (x accel, mm/sec^2) $52=0.000 (x accel, mm/sec^2) $53=0.000 (x accel, mm/sec^2) $54=0.000 (x accel, mm/sec^2) $55=0.000 (x accel, mm/sec^2) $56=0.000 (x accel, mm/sec^2) $57=0.000 (x accel, mm/sec^2) $58=0.000 (x accel, mm/sec^2) $59=0.000 (x accel, mm/sec^2) $60=0.000 (x accel, mm/sec^2) $61=0.000 (x accel, mm/sec^2) $62=0.000 (x accel, mm/sec^2) $63=0.000 (x accel, mm/sec^2) $64=0.000 (x accel, mm/sec^2) $65=0.000 (x accel, mm/sec^2) $66=0.000 (x accel, mm/sec^2) $67=0.000 (x accel, mm/sec^2) $68=0.000 (x accel, mm/sec^2) $69=0.000 (x accel, mm/sec^2) $70=0.000 (x accel, mm/sec^2) $71=0.000 (x accel, mm/sec^2) $72=0.000 (x accel, mm/sec^2) $73=0.000 (x accel, mm/sec^2) $74=0.000 (x accel, mm/sec^2) $75=0.000 (x accel, mm/sec^2) $76=0.000 (x accel, mm/sec^2) $77=0.000 (x accel, mm/sec^2) $78=0.000 (x accel, mm/sec^2) $79=0.000 (x accel, mm/sec^2) $80=0.000 (x accel, mm/sec^2) $81=0.000 (x accel, mm/sec^2) $82=0.000 (x accel, mm/sec^2) $83=0.000 (x accel, mm/sec^2) $84=0.000 (x accel, mm/sec^2) $85=0.000 (x accel, mm/sec^2) $86=0.000 (x accel, mm/sec^2) $87=0.000 (x accel, mm/sec^2) $88=0.000 (x accel, mm/sec^2) $89=0.000 (x accel, mm/sec^2) $90=0.000 (x accel, mm/sec^2) $91=0.000 (x accel, mm/sec^2) $92=0.000 (x accel, mm/sec^2) $93=0.000 (x accel, mm/sec^2) $94=0.000 (x accel, mm/sec^2) $95=0.000 (x accel, mm/sec^2) $96=0.000 (x accel, mm/sec^2) $97=0.000 (x accel, mm/sec^2) $98=0.000 (x accel, mm/sec^2) $99=0.000 (x accel, mm/sec^2) $100=0.000 (x accel, mm/sec^2) $101=0.000 (x accel, mm/sec^2) $102=0.000 (x accel, mm/sec^2) $103=0.000 (x accel, mm/sec^2) $104=0.000 (x accel, mm/sec^2) $105=0.000 (x accel, mm/sec^2) $106=0.000 (x accel, mm/sec^2) $107=0.000 (x accel, mm/sec^2) $108=0.000 (x accel, mm/sec^2) $109=0.000 (x accel, mm/sec^2) $110=0.000 (x accel, mm/sec^2) $111=0.000 (x accel, mm/sec^2) $112=0.000 (x accel, mm/sec^2) $113=0.000 (x accel, mm/sec^2) $114=0.000 (x accel, mm/sec^2) $115=0.000 (x accel, mm/sec^2) $116=0.000 (x accel, mm/sec^2) $117=0.000 (x accel, mm/sec^2) $118=0.000 (x accel, mm/sec^2) $119=0.000 (x accel, mm/sec^2) $120=0.000 (x accel, mm/sec^2) $121=0.000 (y accel, mm/sec^2) $122=0.000 (z accel, mm/sec^2) $130=-0.000 (x max travel, mm) $131=-0.000 (y max travel, mm) $132=-0.000 (z max travel, mm) ok >
jonathan70 Posté(e) Novembre 4, 2020 Posté(e) Novembre 4, 2020 tien voila le mien regarde $0=10 (Step pulse time) $1=25 (Step idle delay) $2=0 (Step pulse invert) $3=2 (Step direction invert) $4=0 (Invert step enable pin) $5=0 (Invert limit pins) $6=0 (Invert probe pin) $10=1 (Status report options) $11=0.010 (Junction deviation) $12=0.002 (Arc tolerance) $13=0 (Report in inches) $20=0 (Soft limits enable) $21=0 (Hard limits enable) $22=1 (Homing cycle enable) $23=3 (Homing direction invert) $24=25.000 (Homing locate feed rate) $25=500.000 (Homing search seek rate) $26=250 (Homing switch debounce delay) $27=1.000 (Homing switch pull-off distance) $30=1000 (Maximum spindle speed) $31=0 (Minimum spindle speed) $32=0 (Laser-mode enable) $100=400.000 (X-axis travel resolution) $101=400.000 (Y-axis travel resolution) $102=400.000 (Z-axis travel resolution) $110=800.000 (X-axis maximum rate) $111=800.000 (Y-axis maximum rate) $112=800.000 (Z-axis maximum rate) $120=800.000 (X-axis acceleration) $121=800.000 (Y-axis acceleration) $122=400.000 (Z-axis acceleration) $130=290.000 (X-axis maximum travel) $131=170.000 (Y-axis maximum travel) $132=40.000 (Z-axis maximum travel) tu a des chiffres pas tres cohérent au 25 120 et plusieurs fois des chiffre aussi
jonathan70 Posté(e) Novembre 4, 2020 Posté(e) Novembre 4, 2020 c est quoi comme machine parce que moi c est une 3018
dago59 Posté(e) Novembre 5, 2020 Auteur Posté(e) Novembre 5, 2020 moi c'est une faite maison bon ça ne va plus du tout, je ne sais pas quoi faire . je cherche je cherche
Jean-Claude Garnier Posté(e) Novembre 5, 2020 Posté(e) Novembre 5, 2020 (modifié) Hola mais c'est quoi cette tétrachiée de paramètres ????? Surtout que des "x accel" y'en a autant que le Bondieu peut en bénir Faudrait ptêt faire une risette de l'Arduino Tu l'as trouvé où ton GRBL ? Modifié (le) Novembre 5, 2020 par Jean-Claude Garnier
