Pouvez vous me dire sous cura par dagoma si je peux augmenter le nombre de tour de la couche de la surface d'adhésion.
Cordialement
oui dans le XML : brim_line_count
;Definition des caracteristiques du support
;_______________________________________________________________________________________________________________________________________________________
  <Config_Expert>
    <retraction_min_travel>1.5</retraction_min_travel>
    <retraction_combing>True</retraction_combing>
    <retraction_minimal_extrusion>0.02</retraction_minimal_extrusion>
    <retraction_hop>0</retraction_hop>
    <skirt_line_count>3</skirt_line_count>
    <skirt_gap>3</skirt_gap>
    <skirt_minimal_length>150</skirt_minimal_length>
    <fan_full_height>0.5</fan_full_height>
    <fan_speed>60</fan_speed>
    <fan_speed_max>100</fan_speed_max>
    <cool_min_feedrate>20</cool_min_feedrate>
    <cool_head_lift>False</cool_head_lift>
    <solid_top>True</solid_top>
    <solid_bottom>True</solid_bottom>
    <fill_overlap>25</fill_overlap>
    <support_type>Lines</support_type>
    <support_angle>50</support_angle>
    <support_fill_rate>20</support_fill_rate>
    <support_xy_distance>0.7</support_xy_distance>
    <support_z_distance>0.15</support_z_distance>
    <spiralize>False</spiralize>
    <simple_mode>False</simple_mode>
    <brim_line_count>10</brim_line_count>
    <raft_margin>5</raft_margin>
    <raft_line_spacing>3</raft_line_spacing>
    <raft_base_thickness>0.3</raft_base_thickness>
    <raft_base_linewidth>1</raft_base_linewidth>
    <raft_interface_thickness>0.27</raft_interface_thickness>
    <raft_interface_linewidth>0.4</raft_interface_linewidth>
    <raft_airgap>0.22</raft_airgap>
    <raft_surface_layers>2</raft_surface_layers>
    <fix_horrible_union_all_type_a>True</fix_horrible_union_all_type_a>
    <fix_horrible_union_all_type_b>False</fix_horrible_union_all_type_b>
    <fix_horrible_use_open_bits>False</fix_horrible_use_open_bits>
    <fix_horrible_extensive_stitching>False</fix_horrible_extensive_stitching>
  </Config_Expert>
